Cantilever brake pad length
Bikes: Peugeot PR-10, Peugeot UO-8, Boeris racing bike, AMF Roadmaster Renegade, Gitane Gypsy Sport, various Schwinn muscle bikes, Schwinn Super Sport, Panasonic DX-4000, Palo Alto Campy equipped bike
Quoted: 48 Post(s)
Liked 7 Times
I replaced the cantilevers on an old cross bike I'm re-building with some Radius brand ones. They came with very long 70mm brake pads which look like they would have to ride partly inside the fork blades and seat stays since they are too long to clear them. This means when the brakes are released to remove a wheel the cantilevers would be caught by the inside of the blades/stays rather than being able to flop all the way open like the original ones on the bike did which had shorter 50mm pads. Is this the ideal set-up for this type of bike or is it better to have the shorter 50mm pads so the cantilevers can open all the way up when they are released? The concern I have running longer pads inside the fork blades and seat stays is that when released to remove a wheel the tires wouldn't clear them since they are so wide (38mm). Also installing the pads would be a major pain since they would have to be installed after the brakes were already set to an approximate position which seem like a lot of trial and error.
Thanks for any insight into this.
Randomhead
Liked 3,686 Times
You are better off with shorter pads.
Quoted: 48 Post(s)
Liked 7 Times
Quoted: 427 Post(s)
Liked 339 Times
You can deflate the tire to get the wheel off and on, then reinflate. I'd go with shorter pads though.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Mine are like that, and yes, it's a PITA to remove the front wheel. But the pad installation/adjustment isn't any more difficult than with shorter pads; I use a "fourth hand" tool to help.
Quoted: 48 Post(s)
Liked 7 Times
The only "cantilever" brakes I've done up until now are the Mafac centerpulls on my two Peugeot road bikes and they both have standard length road brake pads on them.. I use a 3rd hand brake tool to hold the pads close to the rim and adjust the straddle and brake cables by hand, trial and error style until I get them how I like them.
The Radius cantilever brakes take brake pads with threaded studs and nuts like a road bike but I believe need spacers to hold them proud of the rim side mounting surface I believe which most shorter road brake pads don't have.
Guest
Liked 3,270 Times
A fourth hand tool, or a 3rd hand tool? A 4th hand tool just pulls the cable tight whereas a 3rd hand tool holds the brake calipers (or cantilevers) up against the rim. If you would use a 3rd hand tool to hold the cantilevers while you slid the long brake pads under the fork blades/set stays to install them, you would have to find a tool with just the right amount of tension to hold the cantilevers far enough away from the rims to allow the brake pads to be installed, unless I'm missing something.
Thread Killer
Quoted: 3129 Post(s)
Liked 1,697 Times
Haha! **** cantis!
Guest
Liked 3,270 Times
Someone needs a nap. Again.
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
Thread Killer
Liked 1,697 Times
It’s pitiful to see people struggling to solve bike issues were solved literally 30 years ago…then solved again about 18 years ago. Super sad.
Seriously, slap some V-brakes on that thing at least and start enjoying the fruits of progress.
Randomhead
Liked 3,686 Times
If anything, I hate v brakes more than I hate cantis. OP, there are brake shoes that aren't as long on the frame side. I think they must be koolstop, but I'm not sure what they are called.
Thread Killer
Liked 1,697 Times
Lemme guess, “and you know what’s worse than Vs? Discs.”
Guest
Liked 3,270 Times
This forum is so hashtag blessed to have Chodester and all of his infantile infinite wisdom. What an asset.
Quoted: 1455 Post(s)
Liked 1,477 Times
As long as we're trolling about brake types, I tried mini-v's for a while on my canti cross bike, and the brake feel was super mushy, and the pads had to be run super close to the rims which means any hint of mud or dirt messes them up. I switched back to traditional cantilevers.
My other bike has hydro disc, which is substantially better.
Randomhead
Liked 3,686 Times
The op isn't going to be throwing away his canti equipped bike any time soon, so I'm confused why we're having a discussion of the relative merits of brake types in here. Except maybe between cantis and vee brakes. If they were buying a new bike, it would be different.
Mushy vee brakes sounds like a lever/brake mismatch, maybe.
Liked 1,477 Times
Standard road levers don't pull enough cable to properly set up a regular V brake. There are a few options to work around this problem:
1. Several manufacturers make "mini-V" brakes on the market that have a shorter arms and therefore shorter cable pull than a standard V-brake. These brakes are specifically marketed for use with road levers and offer more power than a cantilever setup, but require the pads to be run really close to the rims and the brakes require all of the available lever pull to engage, so the brake feel is mushy in comparison to a traditional cantilever. This setup also leaves little room for mud/dirt clearance.
https://trpcycling.com/product/cx-8-4/
2. Standard V-brakes can be used with road levers and an adapter that pulls more cable. There is a product called "Travel Agent" that can be used for this. Because it's pulling more cable, you have to apply a lot more force on the lever to get the same amount of brake power. In my experience you end up with roughly the same brake power as a traditional canti, but this setup works if you can't run the center cantilever hanger for some reason (like suspension, or an incompatible stem/steer tube).
https://problemsolversbike.com/index...ch-your-brakes
None of this answers the OP's question though. They should use the shorter pads, which will be easier to set up... and deflate the front tire to get it off.
