35mm tires on 18mm CR-18 wheels?
Old 10-04-21, 12:06 AM
polymorphself
Quoted: 837 Post(s)
Liked 1,080 Times in 521 Posts
Is 35mm pushing it for an 18mm wheel? The CR-18s seem to be well regarded for their price and I’m considering picking a set up but have never thought much about rim sizes until now. The charts and articles I’ve looked at have been a bit contradictory.
polymorphself is offline
Old 10-04-21, 05:10 AM
T-Mar
Quoted: 4722 Post(s)
Liked 3,036 Times in 1,874 Posts
The CR-18 is a hooked edge rim and should be good for tyres with even a 38mm section width. You've got a bit of extra safety factor with 35mm. If this was a non-hooked rim with the measurement across the inside of the flanges, a 35mm tyre would be right at my rule of thumb upper limit.
T-Mar is offline
Likes For T-Mar:
Old 10-04-21, 05:15 AM
mechanicmatt
Hoards Thumbshifters
mechanicmatt's Avatar
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 245 Post(s)
Liked 327 Times in 191 Posts
Absolutely
Sun Cr-18's with 35c Pasela's. I think they're good to go much bigger too. CR-18's were originally MTB rims when they came out. I've run upwards of 2.2's on them, no problem.
mechanicmatt is offline
Likes For mechanicmatt:
Old 10-04-21, 05:27 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,390 Times in 1,927 Posts
I've been running 38mm tires on CR-18 rims for years now, with no problems.
JohnDThompson is offline
Likes For JohnDThompson:
Old 10-04-21, 05:55 AM
nlerner
Quoted: 3800 Post(s)
Liked 6,614 Times in 2,592 Posts
I’ve done it with no problems.
nlerner is offline
Likes For nlerner:
Old 10-04-21, 06:39 AM
rustystrings61
Quoted: 823 Post(s)
Liked 1,392 Times in 694 Posts
Here's my 1973 Raleigh Competition with the Surly Dingle/Dos Eno combo - Sun CR-18s laced to Surly New Track (rear) and Ultra New Track (front) hubs with Continental Cyclocross Speed 35 mm tires.
rustystrings61 is offline
Likes For rustystrings61:
Old 10-04-21, 07:43 AM
majmt
majmt's Avatar
Quoted: 225 Post(s)
Liked 1,101 Times in 327 Posts
This summer, I’ve been running 35mm Rene Herse tires on over 40 year old Super Champion Gentleman rims having an id of around 15mm. About 500 mostly gravel miles, including this year’s Cino ride, with no death or destruction.
Montana, where men are men and sheep are lying little tramps.
majmt is offline
Likes For majmt:
Old 10-04-21, 09:29 AM
polymorphself
Quoted: 837 Post(s)
Awesome. Thanks all. Was reading reports of tires getting squishy on the rim when you get too far away from the rim size and it got me wondering. Although I’d never measured any of the rims I’ve used in the past, I just used them with 28-35mm tires and they worked so I didn’t have much perspective.
Old 10-04-21, 09:53 AM
Sluggo
Sluggo's Avatar
Quoted: 51 Post(s)
Liked 130 Times in 58 Posts
Many (most?) early vintage MTBs had 22 mm rims and held 60 mm tires fine. You have a lot more flexibility than some would have you believe, although if you are starting from scratch, there are advantages to wider rims for for wider tires.
Sluggo is offline
Likes For Sluggo:
Old 10-04-21, 10:03 AM
SJX426
SJX426's Avatar
Quoted: 1606 Post(s)
Liked 2,209 Times in 1,102 Posts
Not CR-18 but rather the stock rims on the 97 Rock Hopper. 2.2 tires If IIRC.
P1000217 by superissimo_83, on Flickr
Bit of a challenge getting the wheel removed with the brake noodle unhooked.
RockHopper_Sprung_2012_05 by superissimo_83, on Flickr
Getting the fender to not rub was a challenge
Wide Tire Commuter with Fenders by superissimo_83, on Flickr
SJX426 is offline
Likes For SJX426:
Old 10-04-21, 10:58 AM
stevel610
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 365 Post(s)
Liked 457 Times in 240 Posts
My Raleigh C500 came with 35c Randonneur Cross tires on CR-18's. As others mentioned I have fit larger tires as well.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
stevel610 is offline
Likes For stevel610:
Old 10-04-21, 11:01 AM
rustystrings61
Quoted: 823 Post(s)
Wait. Is that a 1st generation Austro-Daimler Vent Noir I see there? Richard Ballentine was right to call those sexy in his book all those years ago ...
Old 10-04-21, 12:16 PM
majmt
majmt's Avatar
Quoted: 225 Post(s)
Not much escapes this crowd. Very sharp eyes, sir! I generally run fairly narrow tires but I like the still sexy look of the fatter tires on this bike and I like the ride even better.
majmt is offline
Likes For majmt:
Old 10-04-21, 12:42 PM
rustystrings61
Quoted: 823 Post(s)
I have its kissing cousin, a 1976 Puch Royal X, which is currently riding on an almost stock set of 27 x 1 1/4. In its salad days I ran it with Hutchinson Supersprint tubulars, but I bet it would work beautifully with 35 mm tires, if I ever put together a 700C wheelset for it ...
... and to keep it semi on-topic, those are relatively narrow Mavic Module E 27-in rims shod with Panaracer Pasela 603/32 aka 27 x 1 1/4 tires.
Old 10-04-21, 01:04 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1560 Post(s)
Liked 1,282 Times in 853 Posts
The "squishy" feel of very wide tires on narrow rims is mostly going to be limited to users of tubeless tires, where pressures can be low enough to cause tire-roll during hard cornering.
That's not to say that the use of wider rims won't improve the steering feedback feel, it will tighten up the lateral stiffness of the tire carcass, to good effect.
I used to race XC using 700c MA40 rims with 13mm inside width and with 45mm Panaracer Smoke tires installed.
Never had an issue since I was running inner tubes and pressures no lower than low 40's, with me weighing only 155# or so.
dddd is offline
Likes For dddd:
Old 10-04-21, 01:45 PM
DorkDisk
Quoted: 576 Post(s)
Liked 1,000 Times in 488 Posts
CR18 was a straight up MTB rim in 26" form in the early 90's. 2.1" were common back then. You can see it listed in the online Bikepro catalog.
DorkDisk is offline
Likes For DorkDisk:
Old 10-04-21, 09:33 PM
etherhuffer
etherhuffer's Avatar
Bikes: Surly Long Haul Trucker,81 Fuji Gran Tour SE, 83 Fuji S12S LTD, Voyageur 11.8 chrome, Raleigh R300 Touring, Voyageur 11.8
Quoted: 283 Post(s)
Liked 500 Times in 226 Posts
I have built up 4 sets of CR18. Can't beat the price, looks good. But....every build was different. Two trued up right away, one I spents hours on and could not true and tension well. More modern rims seem more rigid and easier to build. The type of cross section profile affects rigidity
etherhuffer is offline
Likes For etherhuffer:
Old 10-05-21, 03:31 PM
SuperLJ
"part timer"
SuperLJ's Avatar
Bikes: 1975 Raleigh Gran Sport, 1978 Bertin C35, 1982 Trek 614, 1983 Trek 620, 1984 Nishiki Seral, 1995 Mercian Ko’M, 1998 Fisher HKEK, 2000 Rivendell RS, 2001 Heron Touring, 2016 Nobilette Custom
Quoted: 114 Post(s)
Liked 160 Times in 61 Posts
I’ve been using CR18’s with 35-38mm tires on my loaded touring bike for years with no issues. Here’s a handy chart courtesy of Sheldon: https://www.sheldonbrown.com/tire-sizing.html#width
SuperLJ is offline
Likes For SuperLJ:
Old 10-05-21, 05:48 PM
panzerwagon
Garage tetris expert
panzerwagon's Avatar
Bikes: A few. Ok, a lot
Quoted: 385 Post(s)
Liked 689 Times in 327 Posts
That Sheldon Brown chart has always appeared far too conservative, and seemingly at odds with how some new bicycles were specified back in the day.
For example, my Trek 750 from 1990 came stock with Matrix Titan Tour II hard anodized rims. They are currently on my bench for hub maintenance, and I just measured their inner width at 13.5mm. They were originally specced with 35mm tyres. See the catalog page here: https://vintage-trek.com/images/trek/...tainspecs2.jpg. I'm about to mount new Gravel King SS tyres on those rims. I'd hoped to go as far as 32mm or 35mm, but sadly, their recipient frame (not the Trek 750) is limiting me to 28mm. The 750 frame would probably allow > 42mm, which makes that stock choice of rim width even more odd.
On another bike, I'm preparing a wheelset with Mavic 195 rims (inner rim width 13.4mm) to mount new Pasela 32mm tyres, and I don't anticipate any issues.
panzerwagon is online now
Likes For panzerwagon:
Old 10-05-21, 07:32 PM
polymorphself
Quoted: 837 Post(s)
Hence my apprehension when I started actually looking into this. Your sentiment was shared in most posts/articles I read in relation to not only that chart but others as well. Nice to have some of these good anecdotes though.
Old 10-05-21, 07:33 PM
Ironfish653
Dirty Heathen
Ironfish653's Avatar
Quoted: 889 Post(s)
Liked 906 Times in 534 Posts
^^ This. Also, DorkDisk , dddd and a couple of others.
There is a wealth of information on the Sheldon site, and BF, but it seems to have a big blind spot in that there actually were high-performance 26" MTB's back in the 90's, and that, yes, 1.95-2.1" (50-52mm) on 17-19mm rims was the de rigueur setup on XC bikes, which were the predominant form of MTBs in that era.
For those of us who were young enough to have been riding and racing in that era, it's always worth a chuckle when someone worries if 37's are "too wide"
Ironfish653 is offline
Old 10-05-21, 07:36 PM
52telecaster
ambulatory senior
52telecaster's Avatar
Quoted: 1954 Post(s)
Liked 3,656 Times in 1,677 Posts
I have 35s and 38s on those rims. I love cr18s for the value and I have toured many miles on them.
52telecaster is offline
