Walmart's best!
#101
Quoted: 259 Post(s)
Liked 346 Times
I pretty much have the same bike. The brakes don't work very well so there's no way you're gonna go over the handlebars if you hit the front brake all the sudden. The only thing that's gonna happen is you coming to a slow stop.
#102
Quoted: 259 Post(s)
Liked 346 Times
Not bad, although I'm definitely needing strong brakes especially at the front since I ride at bike courier speed in the city, just a bit faster than commuter but not suicidally fast. My $200 gravel bike (Walmart quality) has stock mechanical disc brakes which is strong enough to lift the rear wheel. But I've setup the saddle to have geometry like "crank forward" beach cruiser or semi-recumbent. Halfway through there using a modified Rinsten spring seat suspension. Makes it considerably more resistant to end over and reduces chance of locking the rear brakes too, overall shorter braking distance, good for urban safety.
Likes For grant40:
#103
Quoted: 346 Post(s)
Liked 394 Times
Grant is not correct about the simple old style side pull caliper brakes that are featured on the Kent GENESIS SABER / Kent GMC DENALI 700C 21 speed bicycles.
Properly adjusted, they do stop the bicycle better than the typical Raleigh, Schwinn, or any other marque employing Weinmann side pull calipers and the typical 40mm pad on their factory steel wheels. These Kent GENESIS SABER & Kent GMC DENALI bikes are the exact same as already mentioned, as the licensing deal with General Motors ended. Grant does not know what he's talking about regarding these specific no-name side pulls seen on these particular Kent Genesis Saber & Kent GMC Denali bikes. Perhaps Grant himself does not know how to properly set-up a side pull caliper. I don't think this is the case. I believe is that Grant is only telling you half-truths to further bash without merit, the otherwise reasonably good quality at the lowest price spectrum, Kent GENESIS SABER & Kent GMC Denali 700C 21 speed bicycles. Grant knows that the brake pad surface area on GMC Denali & GENESIS SABER bikes are considerably larger in surface area than the old 40mm size pads seen on ancient Vintage bikes. I contend that with decent pads installed and properly adjusted, the no-name side pull calipers WILL STOP Those Kent bikes as good or better than any 1970's era sidepulls with 40 mm size pads did on any aluminum wheel!! Sure, perhaps how the doofuses at Wallyworld assembled & set up the bike might not provide decent enough braking, but that isn't the fault of the equipment, as it is simply due to the imbecile who may have assembled the bike from the carton. Now, certainly the quality of the brake pads that come with the bike from the factory may be inexcuseably bad, compared with other potential replacement pads, or what they could have provided as original equipment pads. Certainly only a complete numbskull does not realize that better replacement brake pads can be obtained for about $15.
That is certainly less costly than changing the pedals or the seat. The Kent GMC Denali/ Kent Genesis Saber is a very durable, quality bicycle which provides a nice ride with good braking and excellent stable handling. Certainly at approx. 31 pounds total weight, it is not light but it does weigh about the same or less than some very popular 1970's Raleigh, Peugeot, and SCHWINN Le Tour models. The KENT Genesis Saber (formerly known as the Kent GMC Denali) is a great value and a very solid bicycle which will last. Yes, it is incredible that WALLYWORLD does sell such a bicycle. Fifteen consecutive years of this bicycle being offered and hundreds of thousands sold, with most of them still in operation. It has proven to be the near-perfect bicycle for those who want to ride anywhere. Certainly, you can say that this bicycle is the 21st Century VARSITY, without the relatively expensive price tag of visiting the Schwinn dealer to purchase the VARSITY back then. Basic bicycles are relatively simple You don't need a weatherman to know which way the wind blows. You don't need a 23 pound or less bicycle if you're not needing to fly in a tri, or really feel the need for speed. Yeah, you might want a detailed weather report if you're planning on piloting your Cessna to Dallas later today, but if you're just needing to drive to the grocery store to buy milk, bananas, eggs, bread, and paper towels, you can usually just look out the window or step out on to the porch and look at the sky and see if any threatening weather is likely to impact during your drive to and from.
Those KENT Genesis Saber (formerly known as Kent GMC Denali) bicycles do everything that any new basic bicycle from a LOCAL BIKE SHOP will do for the bicycle rider that is not intending to ride fast, and not trying to dance like Lance. For those bicycle consumers, the Kent Genesis Saber and Kent GMC Denali cannot be beat. It is an extraordinary value and a very decent bicycle at an incredible price and it is from WALLYWORLD!!
Likes For Vintage Schwinn:
#104
Expired Member
Quoted: 3649 Post(s)
Liked 5,382 Times
Properly adjusted, they do stop the bicycle better than the typical Raleigh, Schwinn, or any other marque employing Weinmann side pull calipers and the typical 40mm pad on their factory steel wheels. These Kent GENESIS SABER & Kent GMC DENALI bikes are the exact same as already mentioned, as the licensing deal with General Motors ended.Grant does not know what he's talking aboutregarding these specific no-name side pulls seen on these particular Kent Genesis Saber & Kent GMC Denali bikes. Perhaps Grant himself does not know how to properly set-up a side pull caliper. I don't think this is the case. I believe is that Grant is only telling you half-truths to further bash without merit, the otherwise reasonably good quality at the lowest price spectrum, Kent GENESIS SABER & Kent GMC Denali 700C 21 speed bicycles. Grant knows that the brake pad surface area on GMC Denali & GENESIS SABER bikes are considerably larger in surface area than the old 40mm size pads seen on ancient Vintage bikes. I contend that with decent pads installed and properly adjusted, the no-name side pull calipers WILL STOP Those Kent bikes as good or better than any 1970's era sidepulls with 40 mm size pads did on any aluminum wheel!! Sure, perhaps how the doofuses at Wallyworld assembled & set up the bike might not provide decent enough braking, but that isn't the fault of the equipment, as it is simply due to the imbecile who may have assembled the bike from the carton. Now, certainly the quality of the brake pads that come with the bike from the factory may be inexcuseably bad, compared with other potential replacement pads, or what they could have provided as original equipment pads. Certainly only a complete numbskull does not realize that better replacement brake pads can be obtained for about $15.
#105
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,095 Times
Likes For livedarklions:
#106
Quoted: 259 Post(s)
Liked 346 Times
Wow, is yours an old model bike? Looks like new. Yes, the caliper rim brakes on cheaper bikes tend to be weak, unless it's V-brake.
Cheap mechanical disc or V-brakes still gives strong braking. The only problem with cheap mechanical disc brakes, is the dangerous and unpredictable "unsqueeze" behavior when the caliper bearings leave the slots (you suddenly lose the brake without warning).
All the cheap Walmart quality all-mechanical disc brakes have the same problem. There is of course a simple solution to the problem, the caliper housing should be adjusted so the side with the lever is much closer to the disc rotor and replace the brake pads when the lever arm is only 20mm away from the barrel adjuster when you press the brake lever to apply the brakes. Also buy the thickest replacement pads you can find.
Not sure if the mechanical Shimano disc brakes have the same problem but pretty sure the full hydraulic or mechanically actuated hydraulic caliper disc brake should not have this dangerous problem.
#107
Quoted: 259 Post(s)
Liked 346 Times
#108
Quoted: 259 Post(s)
Liked 346 Times
#109
As with the previous post... TLDR
Likes For teejaywhy:
#110
Quoted: 507 Post(s)
Liked 237 Times
I will ridicule the bike, the people who made it, the people who sort of wrote and almost translated the ad copy----because the whole thing was a pure crap job. Anyone who laid out the money to actually build the thing wasted that money, and anyone who bought one .... nothing good to say about that person. Anyone who tried to ride that bike would know in an instant that it is unsafe at any speed.--- that "instant" being when they wanted to stop and get off.
I will heap mockery on anyone in any way associated with the product,. including the "reviewers on this site---including myself. Why not? As you can all attest, I am a humble man.
Like this but applied to the bike:
Likes For autonomy:
#111
Tragically Ignorant
Liked 9,095 Times
Like this but applied to the bike: https://www.youtube.com/watch?v=5hfYJsQAhl0
We are all a little bit dumber now for having even looked at this bike
So, I'll ask you the same question I asked Maelochs -- do you laugh at old people who pay money to scammers? If this bike is as bad as we all think it is, the buyers are victims, why would we want to make fun of them?
#112
Quoted: 7648 Post(s)
Liked 3,465 Times
Dude ... I am laughing at YOU right now.
Untwist your panties if you find they are cutting off blood flow or causing other discomfort.
I have seen you get into numerous petty urinating matches here ... you cannot claim the moral high ground in a septic tank and be surprised no one wants to jump ion and worship you.
Some days you just need a good bowel movement or something .... instead you come here and decide to tell everyone else how great you are. We tolerate it, are sometimes mildly amused and sometimes mildly frustrated, because when you finally get whatever it6 is you need or get whatever was bothering you out of your system, you have a lot of good stuff to say.
Likes For Maelochs:
#114
Tragically Ignorant
Liked 9,095 Times
Gotta say, I can't imagine anything that screams "I need people to know I'm great" more than picking on people for buying something "smart guys" don't approve of.
Well, that and posters who can't resist using the royal "we" when they're speaking only for themselves.
#115
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
The outrage hasn't calmed. Maybe by next week it will have subsided.
Likes For mstateglfr:
#116
Tragically Ignorant
Liked 9,095 Times
#118
Administrator
Quoted: 11952 Post(s)
Liked 6,600 Times
And the rest of you guys need to stop this constant squabbling, we are not giving out cookies for the winner of these passing contests.
Likes For BillyD:
#119
Tragically Ignorant
Liked 9,095 Times
The wasteland bike concept requires quite a bit of adaptability to different forms. Some are going to require radiation shielding, others will have to be protected from corrosive agents.
The teenage wasteland tires could have a compartment built in to carry Narcan.
#120
Quoted: 1081 Post(s)
Liked 681 Times
You're going to have to have different subcategories, based on the type of wasteland.
