1977 Raleigh Grand Prix
Rider
Hello all! I couldn't pass up buying this Raleigh last December as it was in such good shape. Only have a few "before" pictures - I always forget. I can't stress what great shape this bike is in. Owner said it was a 1976 - no serial number tag but it seems to me to be a 1977.I'm about 1/2 through cleaning, re-greasing everything, etc. I'd like to sell the bike once done. My question to the group is am I better off using the orignal shifter/derailleur cable housings and handle bar tape or replacing with new? They "aged" in coloring but are in perfect shape and do not bind sables at all. I am replacing the cables for cosmetic reasons really. Have to buy new tires. Originals were completely dry rotted.
I've added pictures below.
Quoted: 3810 Post(s)
Liked 3,335 Times
congratulations on this fun find!
it was assembled (not built) in the Enid Oklahoma facility which closed about two years later
the Maeda gear ensemble and alloy cotterless chainset from Sakae Ringyo are both big improvements over the Gran Prix models of earlier years
a bit of a clean and polish and you will have it looking positively showroom!
Likes For juvela:
Rider
Serial Number
I did find the serial number and it is a 1976 model after all. Frame built in September 1976 according to serial number.
Rider
So what do you think about leaving original cable housings and handlebar wrap?
Liked 3,335 Times
frame made 9/76
keep in mind it had to travel via lorry from Nottingham to a port such as Liverpool, thence via ship to Houston and again via road to Enid
that would have taken some time
would think seller correct in calling it a nominal 1977 model
there should be date codes on some of the machine's fittings
in case you are interested there is a guide to their decoding here -
Date of Manufacture of Bicycle Components can be used to date a bike: component dating
Likes For juvela:
Liked 3,335 Times
you could give them a clean with a product such as Soft Scrub
this will remove much of the yellowing visible in the "as found" images
then you can decide whether to leave them be or replace...
Rider
I'll give that a try. Have tried some other mild non abrasive cleaners to no avail.
Liked 3,335 Times
have found the Soft Scrub product to be excellent for "ground in" dirt on plastic surfaces
Likes For juvela:
Bikes: A bunch of old bikes.
Quoted: 278 Post(s)
Liked 869 Times
If you replace the cable outers with new white cables, then the white plastic ferrules on the brake levers will look terrible.
Since you are not keeping it, I'd just clean up what you have now.
Likes For daverup:
Edumacator
Quoted: 2436 Post(s)
Liked 3,119 Times
If the cables work, use simple green and see if that makes any headway. Are they lined?
Personally, I’m big fan of replacing cables for bikes someone else will be riding.
Likes For jdawginsc:
Quoted: 790 Post(s)
Liked 1,760 Times
I would replace the cable and housing and furrels it would be great to keep them but I can see at least one cable and furell look brokren cracked which cleaner won't fix. All cleaned up looking nice I could see $200 or so for this bike really nice frame for lower end and the Raliegh Branded Vx group set is great almost worth the price of the whole bike on evil bay. The weak point on these is the so-so steel 27" chrome wheels and junk tires. Mostly OEM if it wasn't for the wheels I could see $300 or so. I rebuilt and sold one for $200 a while back with some not so grreat non original alloys and some random parts except for the Raliegh branded crank and shifter's.
Likes For zukahn1:
Rider
Good point. The ferrules are "aged" looking too.
Quoted: 3464 Post(s)
Liked 2,828 Times
These were popular machines way back.
I am actually surprised that there are not more of them to be found on CL, garage sales, etc.
Likes For repechage:
Bikes: Trek 970, Bianchi Volpe,Casati
Quoted: 357 Post(s)
Liked 122 Times
Nice find
I have one in white I found at Play It Again Sports store. I bought it because I like the way the rear stays curve around the seat tube ...
Likes For rossiny:
Rider
FInished the project a couple of months ago. Here's a few finished pictures just for fun....
Likes For crobertrose:
Quoted: 790 Post(s)
Liked 1,760 Times
Really like the build great job still 90 percent original and looks better than new nice touch that you kept and polished the original rims with good original looking tires.
Likes For zukahn1:
Rider
