Looking for N=1 -- 85% pavement. And no Grails to be found...
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 310 Times
You might like this. It''s on my radar.
https://fezzari.com/products/shafer
https://cyclingtips.com/2021/09/fezzari-shafer-review/
https://www.feedthehabit.com/gear-re...-build-review/
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
The new Scott Addict Gravel has my eye, looks like an aeroish road bike, but has gravel geo and clearance for 45s.
$4k for the 30 model with mechanical GRX 2x.
Likes For Rides4Beer:
Quoted: 427 Post(s)
Liked 339 Times
The new Scott has a beautiful paint job!
Likes For dwmckee:
Quoted: 2975 Post(s)
Liked 1,180 Times
You probably don't and neither do the people you ride with. Not any different than Trek, Specialized or Cannondale being displayed on the downtube.
Sunshine
Quoted: 10954 Post(s)
Liked 7,481 Times
Compare that to a common offering like the Trek Checkpoint where 609mm of stack height means a 391mm reach which is in their second largest size. The Checkpoint in the largest size is 638mm stack and 397mm reach. So it is 2cm taller stack and 1cm shorter reach.
The Trek Domane endurance bike with 611mm of stack has 380mm of reach which is significantly more upright than the Scott gravel bike. Even the largest Domane with 646mm of stack only has 385mm of reach.
The Scott is definitely on the aggressive side of things when it comes to stack and reach.
It also inexplicably doesnt show the fork rake or overall bike's trail measurement. That is just something I cant stand- there is no justification for not including such numbers at this point- its 2022. How a bike is expected to feel when steering should be given in the geometry tables. Its kind of important.
Quoted: 733 Post(s)
Liked 815 Times
Nah, that's just a promo shot, in fact, that's the 30 model frameset, but it doesn't come with the one piece cockpit or SRAM, so they just threw it together for the pic. They come with the usual huge stack of spacers.
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
So ... no decision yet. Probably a good thing that there's a supply chain shortage.
That Scott looks pretty nice, though I'd be riding around with a freaking nameplate
I've narrowed down to the Exploro or Aspero (or Calendonia. Maybe.) I think. Canyon now shows Grails as "Summer 2022" and I got word from the US distributor of Ridley that they're looking at December 2023 for Kanzos. Yikes.
On sizing, the L Exploro looks more like a M (56). The numbers on the XL are much closer to the Cervelos in a 58. Courtesy of our fine folks at 99spokes.com --
Aspero 58 is light green; Exploro L is red. Hiding behind the green is the Caledonia
Same size Aspero (58) and the Exploro is now XL. Lines up almost exactly
Looks like I'm an XL in the Exploro.
For reference, my current road bike (Fairdale Goodship) is 593/399. I like the reach and going a little taller is a good thing.
So yeah, after Spring Break I'll take a day-trip to Boulder and check the two out. Fingers crossed!
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
Sunshine
Liked 7,481 Times
https://www.scott-sports.com/us/en/p...gravel-30-bike
That looks like the bars are at their max height and there is 20mm of spacers underneath that could be removed(the last spacer stays since that is how the cheap integrated cable solution requires, I believe).
$70 for a different stem length because the stem is proprietary, and you better like -6deg for the stem angle because you arent getting anything else.
Fully internally routed cables thru the headset that make maintenance a pain.
Fully integrated cockpit on higher level models that make the rider fit the bike instead of vice versa.
Proprietary seatpost that limits options.
'Aero' tubes that are totally negated the moment you toss on a handlebar bag and/or a race number.
Cool paint jobs though.
Quoted: 2601 Post(s)
Liked 1,925 Times
Likes For pdlamb:
Quoted: 232 Post(s)
Liked 146 Times
I'm also a mainly road and sometimes turn off to the trail type of rider (esp when bike touring)
Wanted a bike that I can easily take overseas for faster ride events too, and not be too slow with a full touring bike.
So I decided to get a custom Ti bike for my needs with the Ritchey Breakaway system.
Takes up to 32mm,700c tires and 42mm for 650b
7.8kg all in.
7.8kg all in.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
What is too “gravel” about the Warbird? Swap for a set of 38-40ish slicks and you have a perfect bike for what you are describing. Two friends have bought them and use them for what you are describing.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
The new Specialized Crux would fit the bill nicely. Its an endurance road bike that fits wide tires. Basically an Aethos with larger tires. I'm guessing anything with the "S" is out of your price range.
What tire size is your primary, and what is the range you would like to accomodate?
Personally, the Crux is pretty similar to the Canyon I bought actually (Inflite). Its my do everything bike (from road racing to gravel racing, commuting, single track (non technical)).
I don't know canyon's latest availability, but there are 3 choices - somewhat separated by tire size and geometry (race to endurance)
Sporty/racy and super fast: Inflite
All around gravel: Grail
Endurance, touring, fatter tires: Grizzl.
Likes For chas58:
Quoted: 733 Post(s)
Liked 815 Times
https://geometrygeeks.bike/compare/s...-5-2022-56-cm/
Liked 1,180 Times
Not really, comparing 56cm sizes, the Scott has 1* slacker ht angle, 7mm less bb drop, 5mm longer chainstays, 40mm longer overall wheelbase (most of that from the increased front center). Those things make a difference when you're off road. Stack is about the same, but the reach on the Scott is 20mm longer, so you'll be a lil lower being stretched out, it's meant for racing.
Having done a few gravel races myself...I think these gravel bikes with ~71 degree HTA are too steep. I think Fezzari nailed the correct HTA at 68.9.
I just picked up one of these: https://www.giant-bicycles.com/us/re...dvanced-2-2022
I haven't had it out more than a couple of times and just on pavement but I'm really pleased with it's road manners. It has a lot of snap when you pedal and the handling is sharp but secure. It rides well too, some complance but not too flexy. Honestly, it's exceeded my expectations so far! I put lighter wheels and tires on (44mm Rene Herse slicks) and full fenders and it's just over 21 pounds. It is a good value, even with my upgrades it was around 4 grand. Here 'tis prior to bartape:
Likes For 5teve:
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 334 Times
Liked 415 Times
Quoted: 1455 Post(s)
Liked 1,477 Times
Really tough, superdex should buy an older SuperX... which also happens to fit the bill nicely and the names match.
