Swapping out to a lightweight frame for the purpose of hill climbing?
ignominious poltroon
Quoted: 2185 Post(s)
Liked 3,337 Times
Tubeless might also be an inexpensive upgrade (depending on your current wheels) to help ride up grades, along with some low rolling-resistance tires.
Bikes: Bicycles? Yup.
Quoted: 465 Post(s)
Liked 1,452 Times
Did this when I could see my friend's hillside house, the final push of a decent Vermont climb last month. I was pretty close to gassed and the psychology of dumping 20 ounces must have overwhelmed the physics of it, the bike felt so much lighter!
Likes For BTinNYC:
Quoted: 167 Post(s)
Liked 291 Times
In 2019 I bought a Wilier Zero6, their lightest bike specifically designed as a showcase for how light they could go at the time. The bike had an RRP of £11000 in the UK and I got it for £4900 new in the annual sales (due to its small size not selling)...it weighed 13lbs. Full carbon, sub-700g frameset and SRAM Red.
I've almost immediately increased the weight by adding ZIPP 303 wheels and more recently Wahoo Speedplay Powermeter pedals. I cancelled out the PM pedals additional weight over titanium by changing to Tubolito tubes. The bike is more aero than original thanks to the deeper wheel set and still only weighs in at 13.7lbs.
I also have a 17.5lb Trek Madone SLR.
The difference between them is very noticeable on climbs, especially steeper, longer climbs, obviously. The Wilier accelerates faster and is more agile, nimble. I also find it is more comfortable for longer rides.
The Trek carries its speed better on the flat due to being even more aero and I prefer it for sprinting.
The idea of a lightweight climber is a good one, in my opinion, since regardless of theory and what people who have not ridden very light bikes say, they actually do make a tangible difference to how you feel on a climb. My PR's for all my local long climbs are on my Wilier and my training partner has commented that I am faster on it than my Trek when we do a hills day; which is often, I live in a hilly area!
Likes For AlgarveCycling:
Quoted: 439 Post(s)
Liked 999 Times
I'm running 33g TPU tubes, they practically feel like tubeless. The perks is that they're easy to mount and swap out with decent clincher tires while being significantly lighter. Downside is that they're still tubes and don't have the potentially better puncture resistance of tubeless.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1877 Post(s)
Liked 1,413 Times
Sounds like you need a CF handlebar or a one-piece CF handlebar with stem!
Likes For SoSmellyAir:
Quoted: 439 Post(s)
Liked 999 Times
Likes For jonathanf2:
Quoted: 1272 Post(s)
Liked 1,382 Times
Otherwise, I completely agree with you. Anything to reduce the effort on climbs can help significantly, even better aero (in case of headwinds)
It can only take a few watts difference at the lactate threshold to mean the difference between bonking or sustaining power without great difficulty. Of course, you can also get a few more watts with training or simply improved technique or even fit. But I doubt you'll get a big difference in feel between different performance-oriented tires unless you're changing from a touring or gravel tire into low resistance road or race tires.
Quoted: 4746 Post(s)
Liked 3,861 Times
I used to save weight on freewheel teeth. Found the fewer teeth I was burdened with, the faster I went uphill. 78 teeth on a 5 speed FW worked out pretty well when the hills were hills, not mountains. (I burdened myself with 89 teeth for Smuggler's Notch.)
Smuggler's Notch and my "23". 14, 15, 17, 20, 23. Added up = 89. The rest of the time: 13, 14, 15, 17, 19 = 78. Much of hill climbing is in the head. Stay away from those comfortable gears and you know you have to go faster or that hill's gonna be a drag. Can't do that now; I'm 45 years older but I still limit my gearing. Smuggler's Notch on the 14-23 because the shop's Winner board didn't have a 23. Knew others would be on 24s. Wanted to be a tooth higher and didn't care about the downhills. 54-14 meant nobody was going to ask me to work!
Quoted: 1107 Post(s)
Liked 1,197 Times
I'm currently using a carbon gravel/endurance type frame as my road bike. It's not the lightest, but with almost full carbon components except alloy stem and drop bar, it weighs-in around the 17-18 lbs. range. I don't have many complaints about the frame and I have the option of going with wider tires if I choose, but I'm currently using 28-30c road tires (frame accommodates 45c tires). Though I do like road climbing and I've been entertaining the thought of getting a dedicated carbon road frame especially for hills. I don't do any competitive racing and I do alright keeping up on group rides. I would most likely do a parts swap to the new frame and use the older carbon frame as a dedicated gravel bike (my current gravel bike is alloy). Another option I was thinking was doing more weight cutting on the current frame maybe going with an integrated carbon stem/drop bar combination plus other weight cut measures, but I'm not sure it would make that much of a difference.
Anyways, just looking to get opinions if getting a lighter road frame would make sense for my intended purpose. Also I would do the work myself and I think the swap would be fairly straight forward. Thanks!
Maybe a second set of wheels with skinnier (i.e. 25mm), lighter tires and tubes. You probably have nice wheels already, but maybe can get even lighter wheels as a second set. Depending on what you have, you can also save some weight in tires, tubes, handlebars, saddle and seat post - maybe a half pound or more combined - without getting into a whole new groupset, for example.
The second set of wheels, even if they dont differ radically in weight from what you have, are a vehicle for lighter, road-specific tires and tubes and the combination will be lighter and subjectively (maybe even slightely objecively) faster. Two wheels means you have full-on road bike with the right tires and tubes, and a full-on gravel bike if you put 35-40mm on one set of wheels.
What you have is plenty light for staying with a group ride, imho. but instead of the middle ground of 28-30 mm tires, get a set of wheels with really nice road tires and tubes and some actual gravel tires on the other set.
Quoted: 3192 Post(s)
Liked 2,461 Times
Don't stop at a hill climbing bike. You'll also need a TT bike for those long flat sections.
Quoted: 1360 Post(s)
Liked 1,805 Times
but I'm using the Endurance (700x28-35) and Allround (700x35-40) tubes -- maybe you are using different size tube and there are issues ?
gotta be careful with the valve stem / cores though
and due to the valve stem - had to upgrade one of my Silca pumps with a Hiro head ($)
Quoted: 2430 Post(s)
Liked 2,891 Times
Likes For Trakhak:
Liked 1,805 Times
My favorite type of climbs are hitting those final uphill segment sprints while everyone is spinning their low gears. I'm probably not going full weight weenie, but I was thinking I could probably cut a few more grams going to a dedicated lightweight road frame as opposed to using my bulkier gravel frame as a road bike. I doubt I'll have the funds to go down to 13 lbs., but I was thinking going down to the 16 lbs. range might be doable. I also live in a hilly area which requires me to climb in every direction I ride. Even when I'm in the gym, I warm up on the cycle machine just to practice my out of saddle riding. All I think about are hills!
back in the early 90's full weight weenie barely got you to 18 lbs or so (!) ... carbon frame, ti bb spindle, ti cogs, 15/16 butted spokes w/alloy nipples, ti post, flite saddle
Liked 1,805 Times
before Lance Armstrong discovered EPO (?) and whatever else - he 'discovered' the advantage of spinning ... (and lean body mass etc)
Liked 1,805 Times
Quoted: 4274 Post(s)
Liked 4,718 Times
For big mountainous rides I try to look at the bigger picture for weight reduction. Think about clothing weight, helmet, shoes, saddle packs, tools etc. Those can vary by as much or more than frame weights. Of course they are not mutually exclusive savings, but I wouldn't focus on any one particular component - especially a very expensive one! For a major mountainous event I focus mostly on reducing my own bodyweight. I can typically lose 10 lbs over a couple of months if I really want to perform better on the climbs. My bike is in the 16-17 lb range and I don't worry about it. At major expense I could lose maybe 1lb at best, or maybe 3 lbs with a dedicated climbing bike and even more expense. Just not worth it unless competing at a high level.
Likes For PeteHski:
don't try this at home.
Quoted: 964 Post(s)
Liked 496 Times
Two full Camelbak 24 ounce water bottles are 1600 grams. It would be interesting to use opaque bottles in a blind test climb, either empty or full. Is it immediately obvious, or extremely subtle?
But don't let that stop you from getting a dream bike!
Likes For rm -rf:
Liked 1,805 Times
1600 gms ?
600 would be obvious
Perceptual Dullard
Quoted: 900 Post(s)
Liked 1,122 Times
[Edited to add] "Can you feel the difference?" is often not as reliable a metric as we'd want. Years ago I used to ride on stiff frame skinny tire bikes, and they felt fast fast fast. However, stopwatches and speedometers are pretty reliable, and they reliably showed that a bike and tires that "felt" slower was actually faster. I had been perceiving "chatter" as fast and "smooth" as slow.
Not that smooth is always faster: sometimes smooth turns out to be slow. So I try to measure rather than rely on feelings. As I said, I'm a perceptual dullard.
Quoted: 20791 Post(s)
Liked 9,436 Times
Likes For RChung:
Liked 3,861 Times
Giovanni's tactic wouldn't have worked for me unless everyone else was overgeared. I climbed best doing a lot of standing and riding higher gears. Spinning was never my forte. Yes, I paid the price but I made "the cut" in my hardest race where losing 2 feet to the wheel in front of my would have cost me 10 minutes. I could not have stayed on in a 21 tooth cog.
Quoted: 929 Post(s)
Liked 1,595 Times
Got my ridding gear on...
Pre-flight Check List is done...
RATS!
Gotta go inside and make a deposit...
Leaving the Loo and readjusting my Helmet and Gear I realize...
I just lightened my load by at least a half pound or more....
Happy Happy... Joy Joy...
RATS!
Likes For zandoval:
