Any body going GPS Free?
Quoted: 1949 Post(s)
Liked 2,010 Times
It wasn't long ago when folks couldn't depend on GPS due to accuracy/battery life. Now many folks charge as they go with back up batteries or dyno charging. I'm planning on doing my first complete series next spring and wonder if anybody does that these days without GPS.
Quoted: 2975 Post(s)
Liked 1,181 Times
Cycling GPS units battery life is ~20 hours and you can't change batteries on them anymore. So back up batteries isn't an option and nobody really uses dyno charging for GPS units.
If for some reason you are riding beyond 20 hours then a portable charger or portable solar charger is all you need.
Quoted: 2333 Post(s)
Liked 2,097 Times
I used to get a 600k out of my 1030. I'd bring a lipstick battery for a longer one. I had never updated the firmware until buying a Garmin Radar taillight and it now seems my battery does not last nearly as long.
There are some riders who still navigate by cuesheet. I saw a couple on a 200k recently but they are in a minority.
I bring the cuesheet always as a backup and always use it at some point on a brevet.
Likes For GhostRider62:
Quoted: 2604 Post(s)
Liked 1,931 Times
Quoted: 3459 Post(s)
Liked 1,465 Times
A lot of the GPS units out there can be operated while they are plugged into an external battery pack.
I can't comment on cycling specific GPS units, i use a recreational grade GPS that uses AA batteries that I can also use for backpacking, canoeing, kayaking, etc. So, I won't elaborate more on GPS brands or models. I can charge my AA batteries with a pass through cache battery and dynohub, but that is off topic.
I would suggest you not get a dynohub and USB charger for the sole purpose of charging a GPS. You should be able to run a GPS for four consecutive days off of a good powerbank or maybe a couple of them, but how many watt hours of capacity that powerbank(s) would need would depend on which GPS and how much you used the backlighting. And I think you would want to bring spare capacity along too.
That said, if you want a dyno powered lighting system and you wanted to use excess power from that during daytime hours to recharge a power bank, that would be viable.
While rolling on an exercise ride, I usually average about 2.5 watts of power out of my Sinewave Revolution USB charger that draws power from an SP PV8 dynohub. That is while rolling and that is on flat ground. If I am stopped, nothing comes out of the dynohub. If I am going slow up hills and fast downhills, that average will be less power, could be less than 2 watts. That is with lights off.
But, if I have my lights turned on (B&M IQ-XS and Spanninga Pixeo), on flat ground on an exercise ride, I only measured 0.6 watts out of the USB charger. In other words, assume you get nothing for power out of a USB charger powered by dynohub when your lights are on, you can get something but it is minimal. So, if you wanted to charge up batteries during daytime, turn your lights off.
I described my dyno powered lighting system on my rando bike in another thread if you are curious, that is at:
https://www.bikeforums.net/electroni...b-charger.html
My expedition touring bike, I only use the dynohub for battery charging, I do not even use dyno powered lights on that bike when on a bike tour. I have been self sufficient when camping for weeks with a dynohub for all of my power needs with that bike, but that was daytime riding and only battery powered flashers for taillights.
To reiterate, for up to four days of riding, I think batteries are a better way to charge a GPS than a dynohub if the sole reason for considering a dynohub was for GPS operation. If you also wanted dyno powered lighting, then it might be something to consider.
When I started doing brevets back in 2015 I didn't have a GPS, but I ended up missing a turn on my first 300 and that turned into a 320km ride... then I DNF'd my first 400 when I did an extra 30km at the 300km point when I missed a turn... more of a broken spirit at that point than anything else. Silly mistakes but any decent GPS would have alerted me when I was off-course and I could have figured it out. I'd even have been okay running rwgps on a phone, it'd likely have off-course alerts. I download the route to rwgps app on my phone so I have an electronic backup as well a cuesheet tucked away too.
Likes For clasher:
Randomhead
Liked 3,696 Times
I would get a gps. I have seen too many cue sheets with errors to totally rely on them. And at night, it's just too stressful to try to follow a cue sheet with no backup.
It really depends on the promoter and how well they do quality control on the cue sheet. If there was no pre-ride or it was done by people who used a gps, give in and get a gps. I have also seen major problems with cue sheets if the person that did the pre-ride knew the course too well and didn't have to use the cue sheet. I like to follow a cue sheet and if a promoter releases one soon enough then I will use street view to do quality control on it.
My 830 will run for something like 48 hours on battery saver mode. Particularly if I don't display the map. I generally just use an external battery and display the map though.
Likes For unterhausen:
Liked 2,097 Times
Another potential cuesheet issue is if your lights are aimed low, you can't see the street sign name if it is up high on a pole. The GPS popup is just so incredible at night. I change the warning from 100m to 150 meters. I also put a field, "Distance to Next" on my standard screen. If I am going along, I can just look down and see how far to the next turn. This does not always work but I would say that one field has saved me more bonus miles than anything. OTOH, GPS can get confused and the cuesheet is my tiebreaker.
Liked 2,010 Times
If route designers assume that riders will have GPS, and design accordingly, it is wise to have GPS. I was trying to keep it simple by avoiding unnecessary technology but my plan now is to research and acquire a GPS before next spring.
Randomhead
Liked 3,696 Times
Also, even if we're very careful about reviewing our cue sheets, as GPS has become nigh-universal, route design (at least in areas like New England where there are a lot of roads and nothing remotely resembling a grid system) is favoring the best roads rather than the simplest navigation.
That's a good idea. I just downloaded a garmin plugin that allows you to put more data on the map, I'll have to add this.
Liked 2,097 Times
I gave it a lot of thought once. My old 810 Garmin used to crash but the new 1030 has been perfect. I almost went Wahoo.
Garmins cost more, have more navigation features, and have way more memory for an onboard map whereas the Wahoo relies more on you having a cell phone with you, but it is cheaper and also has good navigation. Garmin takes some effort to learn whereas the Wahoo is more straightforward. Garmin has a little longer battery life. You see both on brevets and I doubt one is much better than others. For me, it came down to screen resolution and the ability to have a map loaded on the device rather than having to perhaps rely upon a cell connection.
There are quite a few youtube video comparisons out there, your preference might be Wahoo. The only thing I dislike about my Garmin is size, it doesn't matter with randonneuring but if I am doing a time trial, it is a brick
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
I still print my own cuesheets and bring them along. Though I normally use my Garmin, things can go wrong, that's all. I also use the "Distance to Next" field, very important. I've seen instances where the designer didn't post a digital file and I had to draw and check the route in RWGPS for myself so I could use my Garmin. I used to also run a old-fashioned Cateye device, also a just-in-case, but the Garmin has been so reliable that I've given that up.
Results matter
Results matter
Quoted: 896 Post(s)
Liked 2,063 Times
Rando is supposed to be an audacious adventure, right?
Liked 1,465 Times
I was maybe a half mile after a control, ran across someone that was totally lost that was using a cue sheet. I backtracked with him to the control so that he would know exactly where he was to reset his bearings and start fresh knowing where on the cue sheet he was at.
I have never tried cue sheets, but I am a geological engineer (retired) and worked with maps every day of my professional career. I bought my first of many GPS units over two decades ago. My brain is not wired right to do cue sheets. I want to see a map, and better yet if the electronics can say exactly where I am on that map.
Randomhead
Liked 3,696 Times
It certainly adds to the adventure.
There are some places where making a cue sheet where it engenders confidence in a very tired rider is nearly impossible. In pennsylvania, the farm roads are on a grid, but the grid usually isn't complete. So you might go a short distance, turn 90 degrees, and so on. The road names change with each turn. There was one stretch on my fleche route where there were many such turns in a row. I borrowed this section of the route from Endless mountains 1200k, and I was very confused after all the turns when I rode that. And then when you're really feeling lost, there is a long downhill. Nobody wants to climb back up if it's not the right way. It happens that at the top of the hill there is a road off to the left that you don't go on. No reason to have it on the cue sheet, right? Except the next turn on the route is a left. So on EM, I stopped to make sure I didn't want to go that way, and then a couple of years later on the fleche we had a big argument about not going that way. Apparently having ridden it 3 times wasn't enough to convince some people on the team. So finally I just started riding the right way. Absent a map, you aren't going to be able to cue sheet yourself out of that level of confusion.
Quoted: 896 Post(s)
Liked 2,063 Times
I'm pretty good with dead reckoning, but if there is a 10 mile stretch I used to get really anxious. I didn't use a computer, I found that to make me nervous because it never matched up to the cue sheet. I think the worst is a long stretch at night. I recall one long stretch of about 15 miles with a defective cue that was followed by a very long, steep climb. The other problem with cue sheets is you might be riding on a road that changes names ever few miles. Lots of people mess this one up when the do cue sheets. Each road name should be on the cue sheet. A gps totally gets rid of this problem.
Like most people who rode in that era, i have my stories. Some whoppers. I don't miss the confusion or bonus miles, but i do miss being more aware of where i am.
Zircon Encrusted Tweezers
Quoted: 261 Post(s)
Liked 131 Times
Following the cue sheet (even when you have a reliable GPS on hand) can alleviate boredom, which is a problem for me when randonneuring.
Randomhead
Liked 3,696 Times
OTOH, I did dnf a 200k a couple of years ago because the 830 gps doesn't have a loud warning about being off route, it was windy, and my hearing isn't the best. The off-route warning doesn't stay on the screen long either. I got confused because the road I was looking for showed up in multiple places. Nice road, I just took the wrong branch. Turns out that rwgps isn't great at getting you back on track either.
Liked 2,097 Times
My story was from not that many years ago. You too can re-live those bygone days by forgoing your gps. If you get lost with a cue sheet, it can be awful to get back on route. I recommend off-line google maps as a backup.
That little beep and short warning is one reason I ditched the 810. I knew I had to make a left on a 300K down in Florida but then this pit bull meaning serious business comes after me and recumbents don't like to sprint. I got it up to speed and just barely stayed ahead of the dog. The speed was so nice, I forgot about the left turn.....for like 5 miles. Then, I had 5 miles to worry about making a right hander onto a sharp acute angle (50 degrees on a 55 inch wheelbase)with an aggressive dog across the road and of course, teeth are about facial cheek level on my recumbent.
Randomhead
Liked 3,696 Times
I think you were on the NJ 600k that went to the beach in 2019. There was a section after one of the early controls that had a big tailwind. There was also some kind of large organized ride on that section. I hadn't gotten my garmin 800 started up right and missed a turn, and I was enjoying the large shoulder and tailwind. Which later turned into a huge headwind when I realized my mistake. I did something like 8 bonus miles, so 4 of them with a huge headwind. Fortunately the other side of the road also had a nice shoulder.
Quoted: 4257 Post(s)
Liked 1,354 Times
I might have to switch. At least on the 800, the warning stayed up until you were back on course. Granted, that could sometimes be annoying if you were off course on purpose.
No. Garmin doesn't provide the hooks for that.
Liked 1,354 Times
You'll often know about upcoming turns well before the notification and, if you miss a turn, you'll generally see you are no longer following the track. It's fairly common to miss the turn notifications and, sometimes, some turns won't even have an associated notification. Paying attention to the map is the only way to handle this.
Another thing to try to do is look at the map after turns to verify that you are still following the track. If the device is set-up properly and you are paying attention, you shouldn't get that far off-course before knowing about it. Of course, scanning the map is harder to do at night.
The Garmins have an option to use your phone to announce turns. This requires Garmin Connect Mobile to be running on the phone. It will consume more of the phone battery but, maybe, not that much. This might be something one could use at night (when the Garmin is harder to look at).
It's not easy to keep of the "active" line of the cuesheet and you have to (often) keep track of your distance (typically using a computer anyway). And you have to look for street signs (which might not match, be in a standard location, or even exist). Outside of at turns, you have no confirmation that you are on the track.
As long as it's basically working and you are paying attention to it, you can't really get "lost" with a GPS since you can see where you are relative to the track you are supposed to be on.
The GPS puts all the stuff you need to know for navigation in one small place that works the same for every ride and it provides continual confirmation that you are on track (you just have to look at it).
With cuesheets, you basically have one chance to make the turn. With a GPS, you have at least four: before (observation), at (observation and notification), after (observation), and off-course warning (notification)..
If one gets confused by the GPS, one trick is to slow down.
The principle downside of GPS units is that they require power. (They are also kind-of expensive.)
Liked 2,097 Times
The warning isn't red. The 1030+ generally tries to give you rerouting options (which makes it clear you are off course). The 1030 does something similar (but not quite as well). I would think the 830 does the same thing. (The firmware of the 1030+ and the 830 are very similar). The problem I have is that the devices don't figure out that you are back on courses as quickly as they should (I think they used to be faster).
The climb screen popup is very, very annoying. I don't want it at all. This seems to only have showed up since my FW upgrade. I don't know. Is there a way to exterminate it? I already have the relevant information on my screen, % incline and power. All these new screens probably explain less battery life. Any tips getting rid of the climbing stuff, cuesheet, and other garbage when I load a file on a ride? Is this the file or the device? Sorry for the dumb question, I have no idea.
Liked 1,354 Times
(This is from a 1030+. The 1030 should be the same.)
https://apps.garmin.com/en-US/apps/8...f-9f10113b5276
Probably, not by much (especially, if they aren't being displayed). Updating the map takes a fair amount of CPU time but the map isn't updated if it's not being displayed (I typically have the map displayed). Garmin knows battery life is an important feature.
By "cuesheet", I suppose you mean the "course points". Disable those with Settings -> Course Points -> Off (after selecting the course; the settings item might be off the bottom).
You won't get course points if you use GPX format files (course points are only present in FIT and TCX files).
Might need more detail.
Likes For njkayaker:
