Wahoo bar mount for 26mm
Does anyone have a source for Wahoo Elemnt handlebar mounts for older, 26mm? Nothing online with either Wahoo or K-edge. I have a couple of old bikes that I'd like to use the computer on.
Quoted: 6956 Post(s)
Liked 10,959 Times
Weird. Tried to mount my Bolt on my '03 LeMond today, and I've got the same question.
I sent an inquiry to both Wahoo and K-edge but have not heard back. My LBS was puzzled too about the size, but there must be tons of riders out there with less than current bikes. Frustrating.
Quoted: 3230 Post(s)
Liked 2,079 Times
The mounts are usually sized for the newer bar standard of 31.8. Typically I use rubber shims to make it work on older bars.
I tried that, but it flopped around too much. On a bumpy road it was all over the place. Maybe I need to use something not so flexible, like the old tube or bar tape that I tried.
Liked 2,079 Times
Or a thicker shim. I use the shims that come with assorted lights, I add electrical tape as needed. Old inner tube works as well.
Likes For Steve B.:
From Wahoo:
"Thanks for contacting Wahoo Fitness. Our out the front mounts are only compatible with 31.8mm handlebars, however you can still use the stem out with the zip ties on other diameter bars. I would recommend you look for third party options such as K-Edge for a mount that fits 26mm diameter bars. Let us know if you have any other questions."
Haven't heard from K-edge and there are some knock off on Amazon and e-bay. Those worry me a little as I have heard stories of them breaking.
Quoted: 871 Post(s)
Liked 726 Times
Are there any Garmin mounts for that diameter? You can always just get a Wahoo to Garmin adapter puck and then use any Garmin-compatible mount.
Liked 10,959 Times
From Wahoo:
