Flat tire frequency
Bikes: 1994 Raleigh MT200,,2022 Marin Four Corners ,1994 Cannondale T700,2019 Trek Domane SL7
Quoted: 35 Post(s)
Liked 269 Times
Flat tire frequency
I started riding this year after retirement and at 1800 miles I’m up to seven or eight flats. I ride a little gravel but mostly paved shoulder. I started out on a used mtb and ended up buying two more bikes new. They all had new tires and tubes and all three have had flats. I know flats happen but come on,is this normal?Mostly back tires.I am surprised at the recommended tire pressures of 50 lbs plus on these things. Finally,are the “slime”filled tubes any good?Thanks.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
I started riding this year after retirement and at 1800 miles I’m up to seven or eight flats. I ride a little gravel but mostly paved shoulder. I started out on a used mtb and ended up buying two more bikes new. They all had new tires and tubes and all three have had flats. I know flats happen but come on,is this normal?Mostly back tires.I am surprised at the recommended tire pressures of 50 lbs plus on these things. Finally,are the “slime”filled tires any good?Thanks.
Quoted: 35 Post(s)
Liked 269 Times
The only thing i’ve found still in the tire was a sliver of bone(deer)about the size of a toothpick that went through both sides. I agree that the shoulders suck for debris and maybe I should start “sharing” more road. Thanks for your reply.
Quoted: 506 Post(s)
Liked 638 Times
Yup. If you don't know what is causing your flats then obviously you can't take steps to address the problem. If the flats are always on the rim side of the tube then it could be a bad or shifted rim tape. All kinds of causes and without knowing why, you know nothing.
Not all tires are equal. Having the correct pressure for your weight and the terrain also matters.
I’ve been using Continental Grand Prix 4 season on my Roubaix for years and they’ve been very good for me.
Other tires I’m using are Specialized Pathfinder sport for gravel/road and they’ve been good as well.
Likes For Chicken_fat:
Quoted: 980 Post(s)
Liked 582 Times
If riding more in the "swept" traffic lane doesn't improve your situation, you could get more flat-resistant tires. I've not had any puncture flats on my road bike with Schwalbe "Marathon Supreme" tires, though I don't put as many miles on that as my commuter bike. The commuter has Schwalbe "Marathon Plus" tires, which over about 15,000 miles on Chicago city streets have only suffered one flat due to puncture by an unknown but apparently supernatural object.
Another option is to place "tire liners" (eg: "Mr. Tuffy") between the tires and the tubes. Using these in my "winter" bike has literally eliminated puncture flats.
EDIT: Since all three of your bikes have the same problem, it's less likely that it's anything other than road debris. Unless you don't keep your tires inflated properly, in which case you could have "pinch flats".
Likes For sweeks:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
"I am surprised at the recommended tire pressures of 50 lbs plus on these things."
Maximum pressures are not always the best pressure.
Personally, i've found the best ride is always less than max pressure... this applies to all types of vehicle tires.
another "discovery" along the way has been that Max pressure can INCREASE punctures because the offending object has no choice but to puncture when met with a rock hard tire......a Softer tire might just conform but not puncture.
and riding the shoulder is not the best route to avoid garbage that hurts tires....
Finally.. Slime tubes suck... the first time that Slime gets in the valve, the valve is RUINED.... the Slime will eventually harden and may cause a nasty hop at speed too... and then, there's the added WEIGHT, AKA: Rotating Mass, in this case.. a bike rider's worst enemy.
in the future, i'd suggest... buy Quality tubes, Find a pressure for your tires about 10 to 20% Below Max Pressure, and watch where you're riding.... oh, and learn to let the bike ride SOFT under your weight... Plopping your butt on the seat is NOT riding soft... letting the bike rock back and forth under your feet IS Riding Soft.:-D
Likes For maddog34:
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
What others said: after each flat check where in the tube the puncture is (submerge in water if needed) and check the tire. In order to do this install the tires so that the label matches the nipple. Then you can superimpose the tire and the tube and find the thorn embedded in the tire.
I rarely have flats unless the tire is worn significantly.
Likes For csport:
Quoted: 6193 Post(s)
Liked 4,809 Times
50 PSI. Might be too much or it might be way too little. Depends greatly on what size tire and total weight of you, bicycle and stuff you carry along.
You mention a Roubaix. If that's a bike, then a Specialized Roubaix? Normally they'd only have a 25mm or perhaps a 28mm tire on them. Not certain how wide they can handle. I'd think 50 PSI in them too little unless you are very very light.
I don't ride shoulders as they are usually where all the debris is. But you do have to consider the way motorist handle cyclist in your area. Here, most act pretty decent around cyclist.
Likes For Iride01:
Quoted: 1561 Post(s)
Liked 1,734 Times
The OP says he rides MTB. 50psi is way high for any kind of MTB.
Flats are a fact of life. I suggest the OP look into tubeless wheels and tires though. Most MTB & gravel riders swear by tubeless nowadays.
Likes For icemilkcoffee:
Quoted: 5781 Post(s)
Liked 2,578 Times
All the above suggestions are good, but not necessarily on point for you.
The key to a solution is considering the specific causes of your flats, ie. punctures through the tread, pinch punctures on the sides, or punctures on the rim side of the tube.
Once you know how and why you're getting flats, you'll be able to take corrective action.
BTW you didn't mention where you live, which may matter. If you live in the southwest, you may be the victim of goathead thorns. If so, Slime may be your best friend.
Likes For FBinNY:
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Liked 2,578 Times
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
True,
SE Wis
Quoted: 2747 Post(s)
Liked 3,394 Times
" I started out on a used mtb and ended up buying two more bikes new."
Quoted: 241 Post(s)
Liked 454 Times
Slime sucks
Don't ride in the debris fields
Maybe look into tubeless if you can't do the above.
Likes For Kai Winters:
Imaginos, glad you are sticking with it. If I recall, you are in Craig on Prince of Wales Island, the 3rd largest island in the US. POW has the best road system in The Tongass Forest because of logging. It is a paradise for fishing and hunting, mainly because you can access so much. But those logging roads are tough and there really isn’t much pavement. There should be no problem riding on the road itself and I don’t recall there being a real bike shoulder on the few paved roads from Hollis to Klawock. So take the road.
I am north of you in Haines. We have more paved roads and a little more traffic, but drivers are good. I switched to tubeless on my road bikes and it has worked well for me. I am in America at the moment, but will be bring back a vintage Italian steel bike to ride on nice days. That will have tubes and will be fine. Unless the wheels on your road/touring bikes are tubeless ready, just keep riding tubes and take the road. If you are fully committed, then you can and probably will get tubeless wheels and tires.
I get to Ketchikan occasionally, but not with bikes. If you get to Haines, I will let try tubeless tires. And Ketchikan has a bike group that my be a good resource. I know being a bicyclist on POW is tough, but good on you.
Mike
Mike
Likes For Yan:
Quoted: 877 Post(s)
Liked 726 Times
Flats don't happen that often. Once for me in the last three years, and it sealed on its own.
- A tubeless rider who flatted at least half a dozen times a year pre-tubeless, often riding on unswept shoulders and occasional gravel segments.
Likes For surak:
Liked 4,809 Times
I suppose I could assume they are all mtn bikes, but I'd rather not.
Quoted: 2495 Post(s)
Liked 738 Times
Have we helped the o.p. yet? I started to skim after post #10 and we're still talking past one another. Let's find out what the o.p. is riding on! And where he is riding. I'm reluctant to add any more confusion or push him into the traffic lane unless absolutely necessary. 50psi is for 2.0" tires. About the only thing I'll add is that after flat number #1 it is often the case that whatever caused it is not properly removed. It can really be frustrating! You need to get a very bright light AND run your fingers over the entire inside and outside of the tire and make sure no wires or small (really tiny) pieces of glass are not still embedded.
Liked 2,578 Times
FWIW the OP implied that the flats were spread over multiple bikes. If so, that would argue against anything specific to rims and tires. So, if they're punctures, it MIGHT be about his lane position, or some other factor. If snakebites, it MIGHT be low tire pressure.
So, we might point out water sources, but he has to do his own drinking.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 35 Post(s)
Liked 269 Times
OP here. Thanks to all who replied,a lot of good info and insight.Of all the factors mentioned,i think that getting more onto the roadway and off the debris laden shoulders would help the most. I ride a 50mph two lane highway and it can be unnerving sometimes.The shoulder just feels safer. You guys are great,thanks again.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
I can't tell you how many club rides I've been on where someone got a flat, they did nothing more than a quick finger sweep while not even removing the tire and when they found nothing assumed a pinch flat. So they installed a new tube and a couple miles down the road, another flat. You really need to remove the tire, turn it inside out and both look and feel carefully for any objects. I rarely get flats - usually about once a year or less. When I do, I usually find a small strand of wire.
Likes For Lombard:
