Replacing isozone handlebar
Bikes: 1990 Giant Rincon, 2022 Trek FX 3
I have a 2022 Trek FX 3 disc with the isozone grips and after a summer with it, I think either my hands/nerves have gotten significantly worse even with the isozone, or I need more variation. My hands are going numb at least twice as fast as they used to, riding the same routes/roads.
So, I'm going to try variation as I'm not sure that my hands/nerves have gotten significantly worse in one year.
On my prior flatbar hybrid, I added Ergon 2s and I really liked them. I added them 7-10 years ago and I believe they helped significantly at that time. I want to try with Ergon 2 or 3s.
The Trek FX 3 disc comes with 660mm wide bars and I am comfortable with that width. What I don't seem to find is options of 660mm wide bars. Most are 800mm. MoBi has 10 of 660mm width and the ones not in cruiser style are carbon. I don't want to spend at the level of carbon. MoBi has 374 at 800mm. Is the idea to just cut them (if metal) to the desired width, or do I just have to have to go to 800mm wide bars?
If it is to just cut, do I use a pipe cutter or a hacksaw?
Thanks.
Thanks.
Bikes: 2022 LiteSpeed CHEROHALA CITY, 2019 Canyon Roadlite 9.0 CF LTD, 2015 Giant FastRoad CoMax 1, 2001 Mongoose Pro Triomphe,
Quoted: 129 Post(s)
Liked 84 Times
Pipe cutter. Be sure to measure twice and cut once. You might want to take it down in stages. Personally I like the Ergon GP3s and have them on all my flat bar bikes.
Likes For DowneasTTer:
Deraill this!
Bikes: 18 Cdale Quick 1, 94 S-Works M2, 98 730 Multitrak, and a few others
Quoted: 139 Post(s)
Liked 416 Times
I'm another fan of Ergon GP series and used the GP4 on my Quick1.
My biking friends would ask this question: Are you holding tight on the grips? Have you considered turning the grips so the heal of your palm sits differently on the grip itself?
Likes For Trav1s:
Thanks each of you.
I've tried various adjustments of the isozone grips earlier in the season. I can't say that they were the appropriate positions from when it was adjusted at time of purchase from the LBS.
Quoted: 1392 Post(s)
Liked 1,852 Times
new grips and/or new handlebar and/or new stem might reduce or eliminate the problem
'cushier' grips ? ... ergo-shaped ?
riser bar ? (if current bar is flat) ... more swept back ?
shorter or longer stem ? ... 'taller' stem ?
Quoted: 761 Post(s)
Liked 1,720 Times
are you sure you might not be too much pressure on your hands. You might need to get a longer stem. I had a situation where the bars were too close and once I got a longer stem, that eliminated the hand buzzing. Might check that before you have to cut a set of bars up.
Bikes: 2021 Trek FX Sport 4, ~1996 Mongoose Crossway 4.50
Quoted: 94 Post(s)
Liked 1,303 Times
Mark
I have a $20 fx2 spare parts flatbar (same dimensionally as the isozone fx3 the shop says). I hope all works out once I put ergon gp3 grips on
thanks all
