French Thread Stronglight Competition Headset
Bikes: 2017 Sage Skyline, 2015 Co-Motion Periscope Tandem, 2012 Soma Smoothie, 2006 Kona Jake, 1986 Miyata Nine Twelve, 1977 Peugeot UO18c, 1977 Peugeot PRN10, 1974 Allegro Schweitzermeister Model 76, 1972 Hugo Rickert Spezial
Quoted: 114 Post(s)
Liked 591 Times
THIS ITEM IS SOLD
1 inch early 70s era Stronglight Competition headset. French threaded. No bearings. Threads and races in very good shape. Some very small pitting on the chrome but still very presentable. $50 with shipping included in the Continental US. PayPal or Venmo preferred. Will include two Stronglight Competition threaded caps (one is slightly taller than the other) and two crown races (one interior is milled 26.4 and one is stepped from 26.4 to 27 mm) so you can customize fit of stack height and match race better to the shape of your fork. I have also found a corresponding cable hanger that will be included. See picture below.
If I own it, I ride it
Quoted: 591 Post(s)
Liked 662 Times
What size crown race?
Likes For CV-6:
Quoted: 114 Post(s)
Liked 591 Times
Quoted: 591 Post(s)
Liked 662 Times
I was not clear. What is the internal diameter of the crown race? Typical may be 26.4mm, 26.5mm or 27.0mm
Quoted: 114 Post(s)
Liked 591 Times
There are two available
I looked at the two in my stash and measured with calipers. One has a completely smooth interior and measures 26.4. The other has an interior ridge that was milled wider. The bottom is 27 about 2/3 of the way up and the top 1/3 is 26.4. I will also include both races so that the buyer can use the one that fits their fork best.
The whole inner diameter measures 26.4 mm Race #1
Bottom inner diameter is 27 mm Race #2
Top inner diameter is 26.4 Race#2
Edumacator
Quoted: 2436 Post(s)
Liked 3,118 Times
That dual diameter is sort of interesting. If 27.0 crown then it presumably won’t seat all the way, if 26.4, there’s a hollow area at the seat.
Wonder why this was done. Stuff is in nice shape though.
Quoted: 114 Post(s)
Liked 591 Times
The 27 mm part would be the bottom.
Including both of the screw on caps. I suspect the height difference helps depending on whether you are using side pulls (the taller one) or center pulls (shorter one) where you will be including a hanger in your stack height. I’m including both so buyer has option there, too.
Quoted: 114 Post(s)
Liked 591 Times
Still available
Still have this available and added the hanger that goes with the headset for buyers who are running center pull brakes.
Quoted: 114 Post(s)
Liked 591 Times
Sale pending
Sale pending
