Elevation gain variance
Bikes: Trek Domane SL5
Quoted: 25 Post(s)
Liked 41 Times
We rode the same trail today with a large variance between results.
Wahoo ELEMNT Bolt. 220 ft
Apple Watch 7. 385 ft
i expect a difference between devices but this seems rather large. At a quick glance the elevation map profiles appear similar. Anyone know if they use different algorithms?
Quoted: 1277 Post(s)
Liked 1,392 Times
1) the barometric altimeter
2) GPS altitude - essentially useless
3) elevation from maps by correlating GPS location
different software will absolutely use different methods to reconcile the variation between these three sources.
Quoted: 25 Post(s)
Liked 41 Times
both devices have a barometric altimeter and GPS. what apps/software are you using to view the results? many map based systems (e.g. strava) will correct the device altitude readings based on map data. said map data varies in quality greatly, so you have three different potential altitude sources:
Likes For Camilo:
Bikes: 2021 Salsa Warbird, (Specially Love my) 2021 Salsa Cutthroat, 2012 Surly LHT, 2015 Surly Cross-Check, 2008 Giant OCR A1, 2005 Leader 735R, 2005 Gary Fisher Montare, 1991 Nishiki Pueblo,
Quoted: 84 Post(s)
Liked 57 Times
Likes For Eds0123:
Quoted: 1944 Post(s)
Liked 2,164 Times
My personal rule of thumb has always been to mix-n-match using the best numbers. One gives more elevation, the other more miles, use them both and toss out the lower numbers.
I would guess that for the vast majority the numbers really don’t matter. If it helps to make you feel better about yourself, who cares.
I remember when our boss wanted everyone in our dept to participate in recording daily steps. We all got clip on pedometers. I’d clip it on and drive to work. I was breezing through each day until I noticed my drive registered around 4000 steps each way. Oh well, I guess I deserve some credit for fighting traffic for almost an hour to work and an hour back. There were no prizes, but 10,000 steps were never so easy.
John
John
Likes For 70sSanO:
Quoted: 822 Post(s)
Liked 1,960 Times
I gave up on recording with my Garmin Vivoactive. Always gave me wildly inflated #'s compared to mapping software like ridewithgps.
I want accuracy not a pat on the back.
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
Lots of folks buying lots of electronics that are essentially random number generators and then spending their time trying to figure out why they make little sense. Unless you figure out how to calibrate/verify what these "instruments" (being generous in many cases) are indicating, there's no reason to assume they're offering useful data. They may be consistent within themselves (i.e. they have precision) and may be useful under that umbrella(only), but without verified accuracy they have little connection to reality..or other devices. Toss in the software that lays on top of all theses devices..yikes. (imho..as a retired chemist that is familiar with real instrumentation as well as gage R&R instrument capability analysis)
Likes For fishboat:
Quoted: 6193 Post(s)
Liked 4,809 Times
Who cares which is correct? If they are consistent in their reporting, then you'll know which route has more climbing and descending in it.
I wouldn't expect two different devices to report elevation gain loss the same way. If we really got to talking about it I doubt that even we would agree what constitutes elevation gain or loss.
If I'm on a fairly level road that goes up and down a foot 20 times over the course of a mile do I count that as 20 feet of gain/loss? What if it's 5 feet 20 times in one mile?
Likes For Iride01:
Sure, as it's valid elevation gain/loss, but you'd never measure it accurately and, as you noted, it's not worth even considering.
Then it's 100 feet, you'd still never measure it accurately.
Likes For Flipper_:
Quoted: 18413 Post(s)
Liked 15,536 Times
Where I see a big difference between map sources is between Google Maps and RWGPS. I’ll get, say a 49 mile route from the former and then plot in on tha latter. The former will show something like 2,500’. The latter has shown nearly 1,000’ more.
Liked 1,392 Times
if you really dig into it, it just gets worse. the underlying data that strava uses for elevation correction is not that great. i've compared it to known-good data (surveys and other directly-measured elevation datums) and it's pretty far off in places. 15 to 20 percent error in these stats is pretty regular, whatever the source.
Liked 1,392 Times
yep. different underlying terrain models, different degrees of precision in those models and the way they interpolate the "2D" points onto the underlying model... and then just the inherent problems of that methodology. it took RwGPS about 10 years to not register riding across the golden gate bridge as dropping 200' to sea level, and then abruptly climbing 200' back up. an extreme example, but 400 additional feet of climbing per round trip.
Liked 15,536 Times
Quoted: 759 Post(s)
Liked 810 Times
https://ridewithgps.com/help/advance...tten-elevation
Likes For fishboat:
Quoted: 759 Post(s)
Liked 810 Times
Precision is "repeatability"(in the science and engineering worlds). An instrument can be highly precise and yet be completely inaccurate at the same time. Accuracy is an instrument's ability to measure a correct or theoretically correct value. All measurements are estimates of some true value. A good estimate of a true value is an average of multiple measurements.
Maps or reported elevation estimates need to be accurate. With any luck, they were developed with accurate and precise instruments.
Likes For fishboat:
Quoted: 1109 Post(s)
Liked 1,200 Times
John
John
Liked 1,392 Times
Not to be too anal(or pedantic if the last word was aced), but when talking about accuracy and precision it's best to use specific/correct terms.
in addition to the lack of spatial resolution, when the data is generated by remote sensing (as it usually is) things like trees, buildings, etc can make the sampled point just completely inaccurate. combine that with the low resolution, possible inaccuracy of the placement of the road on the map, the user's GPS position on the map, which may or may not be snapped to the road... and it's actually surprising to me that they aren't off by even MORE!
here's an example of a couple block spin around my neighborhood. RwGPS terrain model thinks it's a 1.3 mile segment with 170 feet of climbing. it's actually 1.25 miles (no way to know if RwGPS knows that but is just rounding...) and 239 feet of climbing. the actual vertical gain is almost 41 percent more! i've seen errors like this all over the place, with both strava and RwGPS, but there aren't all that many places in the world that "good" data is easy to come by.
Liked 2,164 Times
I have also found that the degree to which I round up is in direct proportion to my age.
So far I have not yet resorted to metric distances. However, I anticipate doing so sometime in the future.
I also think many non-cyclists will be more impressed with kilometers, it just sounds further.
John
Edit added: Or a metric half century.
Likes For 70sSanO:
Quoted: 759 Post(s)
Liked 810 Times
...imprecise..while I get your meaning..imprecise, precise and precision are very different words. The latter, in science, is basically a reserved term/professional jargon that only involves measurement repeatability. Detail and "precision" have no relationship. What the non-science/engineering world does with these words, in their own environment, including Webster's Dictionary, is up to them.
As for for my initial comments.. the random number generation applies to watts..calories burned, watches counting steps...... The devices may be useful in terms of individual unit precision, comparing output to other's results or reality will have limited success.
Likes For fishboat:
climber has-been
Quoted: 3428 Post(s)
Liked 3,566 Times
yes. you're correct. the issue with the terrain models is actually not so simple - they are precise in the sense of repeatability - if you project the same 2d coordinate onto the model you will of course always get exactly the same result. but the frequency of sampling of the underlying data is very poor, which makes it inaccurate in a way that could also be described as imprecise. not in the sense of repeatability but in the sense of "lacking exactness and accuracy of expression or detail." (per the definition of imprecise.)
When calculating vertical gain, the length of your ruler has a significant impact on the answer. Even if your elevation data are perfect.
Liked 1,392 Times
i’ve done it before by projecting the line onto the surface created by the contour data and the using a script to sum any positive differences between subsequent points on the line. the projection algorithm introduces vertices wherever there needs to be a kink last a certain degree of variance.
it’s worth noting that the contour data is itself created by interpolation from a (very, very large) number of points, so it’s not perfect either. but it’s within inches in most of the dozens of locations that i’ve spot checked it against surveys of actual pieces of property. data like this is very hard to come by at the scale needed for something like cycling.
Liked 15,536 Times
RWGPS introduced a "Flatten Elevation" tool a couple-few years back to eliminate the up and down spikes from tunneled hills and gorges. It's a premium feature. I haven't used it(not a premium acct), but the functionality is pretty straight forward. They have a demo of it on their site somewhere.
Liked 1,392 Times
https://ridewithgps.com/news/5657-br...a-improve?otu=
worth noting that the auto version doesn’t work for rides, just routes:
Quoted: 759 Post(s)
Liked 810 Times
My ignore list is up to 88..and continues it's slow growth.
Likes For fishboat:
