I'm thinking of going through the custom steel process
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
Elephant Bikes will be the maker. Here's the deal.
I'm not absurdly proportioned, off the shelf bikes fit me fine. I'll be racing m1 next year, team bike provided, so I won't need any of my current bikes.
My want is to replace my old Concorde squadra tsx with modern steel, bb30 and isp. I like the welded/filet brazed aesthetic, powder coated.
SRAM Force/red,group, I'll build some wide rim wheels on h + son archetype rims. Good plan?
Quoted: 6556 Post(s)
Liked 58 Times
Excellent. I would go with the most advanced steel tubing you can afford. The stainless, ultra-high strength Reynolds if you can find any. Otherwise one of the non-stainless types but in the air hardened, heat treated, high strength variety. I don't know much about Elephant, but hopefully they know how to put together a really light frame, <3.5 lb. I would go with a carbon fork. There is some room for argument about this, but I think it only makes sense. As far as the components are concerned, the Force-Red mix is a great idea. Force derailleurs and brakes where the performance is great and the weight penalty is small. Red cassette where you can get a really nice weight savings. I'm not sure which levers to go with. You should really like the result.
Quoted: 25 Post(s)
Bikes: are better than yours.
Why steel? Why custom?
rpenmanparker is right that if you go this route, you should go high end. The modern oversized heat-treated steels ride far better than traditional 4130 or 531 and the like.
Telemachus has, indeed, sneezed.
Quoted: 25 Post(s)
I have a carbon bike. My team bike will be carbon. What I want is the bit of flex that comes with an ISP like my carbon bike in steel.
Bikes: Mikkelsen custom steel, Santa Cruz Chameleon SS, old trek trainer bike
Quoted: 70 Post(s)
Liked 6 Times
I'd say go 853 or OX platinum from what I have read. Otherwise that sounds great. I am partial to Enve fork's myself though.
BTW, definitely go fillet brazed over TIG welded. It looks much nicer. After all, if you just want a nice TIG welded steel frame you may as well get a Jamis Eclipse.
Quoted: 25 Post(s)
Glen Copus is the builder, he uses a combination of welding and filet brazing. I won't interfere in his methodology. But I have been a fan of the isp in terms of comfort, and I think it will translate in steel. If I don't like it, i can always cut it off
You should really ask the builder, not the internet, and have faith in the result. Each builder specializes in certain styles and materials. Tell him what you want, and he'll tell you have you need.
Should Be More Popular
Quoted: 22596 Post(s)
Liked 8,925 Times
This. Go for it. I believe you will be pleased with the results.
He loves it.
Ancient Clydesdale
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,173 Times
I don't think he has to worry about how much weight disc brakes adds
Liked 58 Times
Umm, not exactly. There are two kinds of people... Yep, there are those who think like you and there are others who appreciate and utilize the advice of the knowledgeable builder but who want to keep control of the process themselves. I see no inherent advantage to either approach. It is all about personality. The latter are usually (hopefully) quite knowledgeable themselves. Falling into that latter category myself I appreciate how OP may not wish to just give it up to the whim of a builder, but rather express his own preferences in the process. Naturally I hope anyone going about it this way will be sensitive to such advice from the builder like for instance, "You just can't do it that way," or "At your weight, riding style, power output, etc. that gauge tubing is just not a good idea." But that is very different from just saying to someone, "Look at me and listen to me, then build me a bike!" Many folks just want to be more involved in the nitty-gritty.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
if you want a non-carbon bike, wht's the advantage of steel over ti?
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
Liked 58 Times
OP says he wants both steel and custom. First there is the ride quality. I am not saying one is better than the other, but their reputations are certainly different. One might simply like what one has heard about steel better than about Ti. There could be history with steel that is guiding the choice. There is a significant price differential between custom steel and custom Ti. There are also many more custom steel builders than custom Ti builders. It is easier to decorate steel than Ti. I can't say these are the reasons for OP's choice, but they are some of the factors to consider.
Bikes: Firefly custom Road, Ira Ryan custom road bike, Ira Ryan custom fixed gear
Quoted: 9 Post(s)
Go for it. Steel has an incredible, lively ride if built properly. It's one I haven't found in carbon bikes yet (I've ridden many, but not all, by any stretch).
And, the process and the idea that you have one of a kind is rewarding in itself.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
i'm not in the know.
Quoted: 25 Post(s)
Thread Killer
Quoted: 3136 Post(s)
Liked 1,704 Times
That Peacock-thingy fat bike is sweet; the color matched calipers too outrageous! Dunno why one would want single speed, but hey, I'm sure it's not the only bike they've got!
BTW, what is this ISP you guys are talking about?
