DIY Pannier Design Thoughts
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
Looking for some thoughts on sizing and design of panniers to be used for up to a few days of credit card touring, which would augment the trunk bag I'll be using for day rides.
Went to the shop to try a used road bike (my first ever), came home with a new gravel bike. Hey, it was what I could get now in my size, and I'm more likely to do the occasional canal towpath or dirt road than ever ride in a paceline. Definitely turning in better times than my around town hybrid, getting used to the drop bars and hoping they're easier on my hands than last week's 78 mile ride with a single hand position was. But spent more than I wanted to, so have to stay budget on accessories for now.
Have an upcoming single overnight trip planned - 85 mile paved rail trail (I did it last summer the other direction on a unicycle, but homewards so didn't need to carry much), hop on a train, spend the night with relatives, then do a casual group ride the next day before catching a ride with family driving back my way, so the idea is to sew up some trial panniers that I can use to put the overnight and weather-unpredictability oriented stuff in, then take them off and do the group ride with just the trunk bag that I made by sewing webbing loops for velcro straps to the bottom of a little Walmart tote.
One of the key challenges with a pannier seems to be heel clearance. Borrowed an open top grocery carrier one for contemplation and find that my heel strikes it, though if I moved the attachments forward to move the pannier back, that might work. So one thing I figure I need to do is go tape an empty cardboard box on the rack and try riding around to identify what the forward limit of a pannier is.
Another is stiffeners. I found a pair of inserts from an old dead duffel bag that are 13 x 11 inches, tempting to use those the tall way though worried they'd project off the back of the rack a bit - and I'm illogically hesitant to cut them. Also have some 8.5 x 11 inch 1/8 HDPE cutting boards that seem like they'd make very sturdy bases for a compact bag - though maybe "too small". Part of me is tempted to play it safe structurally by making the little ones, figuring even if I later make bigger they little ones could still be useful now and then for kids jackets on local family rides, or maybe I could figure out a way to put them on the 3 bottle cage style brazeons on each front fork with some sort of bar looping over the tire skipping the need for a true front rack. There is a chance though that if I go with the little ones, the jacket I set off riding in may end up bungeed to the top of the trunk bag in a stuff sack.
If I go with the larger size and the more flexy duffel bag liner pieces, I've considered sewing a diagonal channel into the back to be able to insert an aluminum or even wooden "batten" to keep the lower rear corner in position - though my guess is that the more I stuff in them, the more they'll bulge away from, rather than into, the wheel. If I use the larger pieces, I also wonder about putting a stiffener along the top inside edge to cover how they'd project off the back of the rack.
What about how wide to make them? I'm leaning towards 5 inches, in a boxy shape to keep things simple, if I go with the smaller size maybe I'll go 6 inches wide.
What's going to happen if there's no floor stiffener piece? Weather is predicted to be dry for this first ride, so I've considered cutting some cardboard to stuff in there, maybe putting it in a ziplock bag first just in case.
Attachment is planned to be small loops of webbing at the upper inside edge, through which I can feed parachute cord running over/around the rack as that gives me flexibility to join them or use them singly and position the pannier attachments either side of or interlocking with the trunk bag ones. I'm not going to go with hooks over the rack rail as I figure that doesn't really get me much compared to tying them on, and mine aren't going to project above the top of the rack since the trunk bag overlaps the rack an inch on each side.
Closure wise, what I'm tempted to do is put a horizontal zipper about 1/4 of the way down the side, then back this up with one or two adjustable webbing straps that loop all the way around the bag and rack vertically with the idea that these can be cinched tight for whatever level of fullness there is, and will take the load off the zipper. There will be a flap on the top side that overlaps the zipper - though the goal is water resistance, in a driving rain I'd be counting on the contents being internally bagged.
Fabric is some bright green nylon packcloth I've used backpacks and triangle bags in the past; I'll get a tiny bit of water leakage at the seams so plan on putting clothes in inner bags, but a backpack I previously made out of this was functionally a bucket where water is concerned. Alas it picks up grime that doesn't easily wash out and has faded over several years of sunny rides, but those are problems for the future.
Bikes: Custom built LHT & Troll
Quoted: 843 Post(s)
Liked 149 Times
Interesting project.
1. I'd avoid a zipper at all cost. Velcro, maybe. Fastex buckles preferably.
2. No need for a bottom insert. Your luggage will do the trick. (Essential on the back, though, to reduce the risk of something getting caught in your spokes)
3. This being said, Ortlieb rollers are the reference. There are occasional bargains on EBay and such. It may not look like it, but robust, waterproof, safe and convenient panniers are a critical component.
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 521 Times
Why not consider a bike packing system. Strap a dry bag under the seatpost https://bikepacking.com/plan/bikepac...iy-seat-packs/ and another small one on the handlebars. I bought some "Rockbros" bags because they were inexpensive-ish, but decent quality. I just mocked up some pvc fork brackets after seeing Tihabeneros example.
Here's what I came up with:
Pvc skeleton before cleaning up. The canals are to isolate the zip ties.
A section of innertube streched over the pvc with straps added
The innertube keeps the bracket from sliding.
On the bike. Have tested on pavement, but not offroad yet.
Likes For mtnbud:
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
Before going through that effort, look at the Arkel Dry Lites. They're pretty minimalist and affordable. The back stiffener is a pair of removable dowels, for instance.
My first tours were with various duffel bags and loose gear tied to the handlebars and rear rack, many decades before the term "bikepacking" was invented.
Quoted: 1182 Post(s)
Liked 833 Times
I made both sets of panniers for our road bikes. I modeled then after normal size panniers, but made them smaller and with more taper on the front side. They were made out of coated packcloth, with sealed seams they were water resistant. For light road trips they worked well. Our daughters used them for several years, until mom and dad got them each a set of Ortlieb panniers for Christmas.
The backing for the panniers is .032 sheet aluminum. The fabric used on the backs is Cordura. It sounds like you have experience sewing so you should do OK. I learned to sew as a parachute rigger, and still think knowing how to sew is a curse
The mounting system and taper are visible in this picture.
Likes For Doug64:
Quoted: 930 Post(s)
Liked 393 Times
Fortunately, I was just able to borrow a single Ortleib zip-lock style closure pannier, so if the DIY project falls through, that will be an option for the possible near-term ride if a bit awkward in how its mounting clips will push up one side of the trunk bag. But I can make it work and it has the capacity for the alternate clothes I want to haul if my DIY efforts fail.
While I was picking that up I also looked at my brother in law's set of other-brand roll closure panniers which have been a notorious pain to get into. Part of the problem is that they're both a roll closure and then another flap on top of that, so there are just too many steps. Looks like the Ortleib branded ones are just the roller, that might be a bit simpler to fabricate and use.
Still, the temptation of a zipper...
At least the borrowed oddball Ortleib let me figure out the heel interference limit, so I think I'm going with my smaller cutting board backers for now - using the larger ones I'd really need an aluminum reinforcement at the top the handle the amount of extension behind the rack, and I didn't buy that Harbor Freight ruler when I was there getting webbing straps this afternoon - maybe next time.
I made both sets of panniers for our road bikes. I modeled then after normal size panniers, but made them smaller and with more taper on the front side. They were made out of coated packcloth, with sealed seams they were water resistant. For light road trips they worked well. Our daughters used them for a several years, until mom and day got them each a set of Ortlieb panniers for Christmas.
Still, the simplicity of your stuff sacks on the forks... and then I think about something like cutting up some 3-liter soda bottles to give them just a tiny bit more definition.
Quoted: 3459 Post(s)
Liked 1,465 Times
If you have clipless pedals, you can attach your shoes with the cleats to the pedals, that gives you a pretty good way to see where heel worst case scenario for heel strike is. Add an inch of space to make sure.
Not sure why your are doing this, there are low budget options for panniers. But if you really want to make some, go for it. Some on this forum in past years have made panniers from kitty litter buckets. Do you have any friends or family that buy kitty liter?
https://www.adventurecycling.org/blo...-own-panniers/
Stiffener, have you considered Coroplast? In some communities it is often used for political lawn signs. I bought a big sheet at Home Depot a few years ago, when I have another project I still have left over.
None of my panniers has a floor or bottom stiffener, only on the side that is against the rack. I pack them tight enough that they hold shape.
I hope you realize that many if not most people buy a different saddle for touring instead of the stock one on the new bike. It is not clear to me if your first day is 85 miles on a brand new saddle on a brand new bike that you have not tried for much distance yet.
Good luck.
Good luck.
Quoted: 930 Post(s)
Liked 393 Times
I do figure I need to do a few miles test ride with an equivalent amount of stuff in whatever I'm packing it in the night before setting out.
Likes For robow:
Quoted: 418 Post(s)
Liked 521 Times
I'm thinking UniChris would probably have heel strike issues with kitty litter buckets, but I love mine. They're waterproof and easy to pack. They also make a great chair and an ice bucket...
Likes For mtnbud:
Quoted: 930 Post(s)
Liked 393 Times
Oh well, hard to argue with simplicity.
A rolling we shall go...
Actually a little hard to roll because it's practically airtight. My buckles for the strap ends may be arriving relatively late in the afternoon, may have to just sew some loops in the webbing and cinch in down with some rope to do a loaded test ride up the local trail
Uncertain yet if I'm going to need some internal straps to hold the cutting board in the back, but can sew those to the exposed inside seam allowances (lazy) if I need to. What I do need to do is go put some painters tape on the rack and carefully mark where the trunk bag attachments fall and where these will so that I can deconflict them.
Overall I think the sizing is definitely small, but two of these and the trunk bag should be enough for the pending trip, and I can do something larger later and relegate these for odds and ends on local family rides, or try to convert them to front mounting on the fork braze-ons.
Right now I still have enough fabric on hand to make two more in a zip style, but probably not a second roller and two zip style, so I need to test this a bit and decide it's going to work before I cut out a second of this style.
Likes For UniChris:
Bikes: 2021 Trek Verve 2 Disk
Quoted: 130 Post(s)
Liked 119 Times
Liked 1,465 Times
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
A long time ago, I wasted about 4-5 days, trying to make my own panniers. I gave up and went to the local LBS and found some in their close out bin for $20. Best thing I ever did. Looking on E bay, I see panniers starting at $20. I don't see any advantage to making your own.
Quoted: 930 Post(s)
Liked 393 Times
As for choice of what to ride, if I were doing this only for my own purposes I might take the unicycle, but part of the point is to join a road-bike oriented group ride the next day, and pace wise I'm going to need the bike (minus the overnight stuff) for that - apart from reluctantly admitting it's more effective for grocery shopping, compatibility for riding with others (beyond the kid-paced family rides where I can take the uni) is a main motivator of why I finally got back into bikes.
Liked 1,465 Times
If you need ideas for your unicycle, I cropped this out of my original photo before I photo reduced the one I previously posted. This way you can better see what that owner did on his.
Quoted: 930 Post(s)
Liked 393 Times
Better touring rigs use a larger diameter pole fore and aft that supports the bags and has the narrow handlebar mounted to its top, though carrying camping gear on a unicycle is beyond my plans.
Quoted: 930 Post(s)
Liked 393 Times
Made some mistakes with how I sewed the webbing that I'll need to fix after doing the other one right from the start, but the good news is that stuffed with clothes and a spare saddle I didn't notice it at all riding around the neighbourhood, in terms of any of movement, weight, or just having it on one side.
I think I do want to leave a spot for a little Velcro strap around the rear diagonal rack support to make it a little more immobile but it's workable without. And the postman just delivered my set of webbing buckles, which look sturdy enough for this use. Plus even though not quite flat they'll engage either way with is potential useful for the roll ends.
Going to sew the webbing to the other one before I sew the bag itself.
Quoted: 930 Post(s)
Liked 393 Times
Bike's ready, but not sure I am.
Well, almost ready. Had to finish the webbing ends and still need to prep some lengths of cord and heatshrink their ends, plus make a couple backup straps for the trunk bag, but went and rode around a bit and the panniers seem fine.
More iffy on if I'm ready for a serious ride even after riding very little this week. If I cancel the trip I may go do an out and back in a different direction with the luggage mounted, or may go through with it but opt for meeting the train at 50 miles.
Likes For UniChris:
Quoted: 930 Post(s)
Liked 393 Times
87 mile day went well, actually, though we'll see how my knee feels about the group ride tomorrow.
Panniers worked very well.
My one concern is that although the webbing that attaches them runs down the back and a bit up the front, the cutting board stiffener is just stuck in there, so the fabric carries the way the weight wants to pull them a little away from the rack.
I think I'm tempted to rivet (or more likely screw and nylock) the stiffener through the main fabric to the webbing at the top. That also gives the opportunity to consider using fabricated rail hooks, though webbing loops and parachute cord tying the two together at a spacing that just spans the rack worked well.
And in the future I want to work out a way to distribute more weight on the front than just the bottle cages I had there. Not sure if that's moving these to the front and making larger but perhaps thinner ones for the back, or making mini ones for the front for tools type items or what... depends a little on what real plans I make, vs the present shakedown scope family visit and way to get to a destination ride.
Mile 54 of 87.
Mile 54 of 87.
Likes For UniChris:
Liked 1,465 Times
Sounds like (1) you have not quit touring, (2) everything that was packed on the bike stayed packed on the bike, and (3) nothing broke. So in that regard this was a success. Great. When you have plans for improvement, that means this was the first of many trips.
Likes For Tourist in MSN:
Quoted: 930 Post(s)
Liked 393 Times
Nine of them ;-) And for silly reasons want to hold off doing my first on the bike one until making that ten with this summers first.
Main challenge apart from needing a longer day is the greater toll a unicycle saddle makes. Though yesterday's bike ride makes me confident a bike century is there whenever I choose to claim it - or may pick a different hiller route to make it interesting.
(What's also proven true I hadn't expected is that I needed the past several months to gain range on the bike - different muscles used on the longer cranks, different techniques)
