where to pin the number?
You know you want to.
Bikes: Pinarello Prince, 1980's 531 steel fixie commuter, FrankenMTB
My first crit is tomorrow morning - I'm hardly prepared for it, but I think it will be a small field, and it's less than a half mile from my house. Not doing it would be crazy.
When I was registering, I heard someone ask "where do we pin the number", and the guy said "on the right". It seemed to be a satisfactory answer to the question, but I just realized I don't actually know what it means. Last time I had a number, it twist-tied onto my frame. This has safety pins, so I assume it goes on the jersey. On my right side, under the armpit?
Weather today: Hot. Humid. Potholes.
Quoted: 31 Post(s)
Originally Posted by timmhaan
yeah, like this (except on the right side...this is on the left).
OP - look around at others to give you some guidance when you're getting ready to race, then find a pretty girl and ask her to pin the # on your jersey.
Little Pony
Edificating
Bikes: Spooky + Sachs
or look at everyone elses (they could be wrong too.. but oh well)
Cat 3 // Dylan M Howell
thanks everyone.
As a sidenote - is an old MS150 jersey kosher (no sponsors anywhere, just says MS150)? I know you're not supposed to wear anything for a team you don't actually race for, does this fit the bill?
Sorry for silly questions, since it's my first I think it only makes sense to be most concerned about my clothing, right? Actually riding will take care of itself
more ape than man
Originally Posted by MDcatV
The # on that jersey looks too high on the back. Depends on where the camera is I guess.
semifreddo amartuerer
Bikes: several
Originally Posted by damocles1
Ask the official when you register. It's always different.
Many times race organizers will have a sample jersey showing how the number should be pinned on. You may even have multiple numbers to deal with. Don't trust other racers, who may be just as clueless as you are.
Blast from the Past
Im sure the Jersey will be fine. I would agree TimmH's looks a little high, but hey it's NYC.
Over the hill
Quoted: 996 Post(s)
Liked 1,204 Times
you think? could be a tad high i guess. i just like to have access to my jersey pockets during the race, so i usually don't pin the number over the openings.
fwiw, it's best to have someone pin your number on while you're bending over similar to the position you will be in on the bike. Pinning it on while the jersey is off often ends up with a big ripple catching wind when it's on. To the OP, if you're still unsure, you can just look at other riders when you arrive and copy them. Just be sure to check 3 or 4 riders (from different teams), because I have seen plenty of people with them on the wrong side or rotated sideways. You're not the only noob out there, most likely.
It's like riding a bicycle
Quoted: 31 Post(s)
Over the hill
Quoted: 996 Post(s)
Liked 1,204 Times
by too high I was trying to say it looks like the # is too far toward your spine and think it should probably be more under the arm so that the finish line cameras can capture it, not meaning "high" to be in relation to your jersey pockets vs. shoulders. Definitely want to keep your pockets accessible.
WHen pinning the number, it's best to have an assistant do it when you're weariing it and bent over into the cycling position. Usually testing your head on the back of a car and sticking your ass out will work pretty good. Then rest your hands on the top of the bumper.
To prevent the number from turning into a sail and catching all sorts of wind, use 5 safety-pins with one in the exact middle. Each pin should actually make two holes. One hole going down into the number, then the jersey. Then a second hole coming back out through the jersey, then the number. This forces the number to sit right next to the jersey at all times.
部門ニ/自転車オタク
Bikes: 2008 Blue T16, 2009 Blue RC8, 2012 Blue Norcross CX, 2016 Blue Axino SL, 2016 Scott Scale, Fixie, Fetish Cycles Road Bike (on the trainer)
I prefer this, strategically placed works wonders and easy to get on/off the jersey. (still stick a couple pins in to protect loss of the number, but I've never had the number come loose yet where it relied on the pins.
Envision, Energize, Enable
