turning peogoat to singlespeed using the freewheel it currently has
Got an old Peugeot
Bikes: I had a Trek 1200
Turning Peugeot to singlespeed using the freewheel (cassette)
Hi all,
I have an old Peugeot:
I have cleaned and de rusted everything. Now I started to put everything together.
I thought maybe before I put the derailleurs and shifters, to try and put the chain as is on the freewheel and the crank.
I didn't thought about it completely, but will I have a chain-line problem? I want to use the small ring in front and one of the big gears at the back.
Thanks,
kfir
Thanks,
kfir
Fixin' To Die
Bikes: 2010 Mercier Kilo TT, 2020 Specialized Rockhopper
I did an old conversion simliar to this one, and older frame and what not. Generally, the freewheel is kinda large and 'chunky' so i didnt need any spacers. If your planning on using the pre-existing wheelset, that is where you might need to use spacers. They look like they are in good condition, but with ollder bikes like this, the wheels are generally heavy as hell. I would get some newer wheel set, mabey an aluminum set, something that will be lighter, and lighter on your bankaccount.
Got an old Peugeot
Hey, thanks. I will post some photos.
I asked a question. I think you didn't read my post completely. I want to know if I can just pick gear in the back and ring in the front, without a problem? Something related to chain-line.
Thanks,
Kfir
Thanks,
Kfir
Fixin' To Die
i just edited my origonal post. You right, i didnt answer it at all, but i went back and answerd it.
Got an old Peugeot
I will keep for now the wheels and will not change anything. I don't have the money for it now.
So again, can I just pick the gears and cut the chain?
Thanks,
Kfir
Fixin' To Die
What you can do, if your not looking to spend really any money, is just get rid of the derailer, and the shiffters, etc and just place the chain on like 3-5 gear in the back. this willl give you a freewheel SS essentially, and if you ever want to get a diffrent gear ration, you willl just have to take your tire off to move it up or down a cog.
Got an old Peugeot
What I'm asking is: Will the chain be enough for gear change? I can move the rear axel 2 cm.
You'll need a straight chain-line for it to work, otherwise the chain will slip down a cog (and go loose and fall off) or try to walk up a cog (and get tight and lock up). This will limit the gear combos you can use. You'll have to determine this yourself, as chain-line is a function of the BB spindle length, crank dimensions, # of gears front and rear, etc. so there's no way for us to determine it for you. If you re-space your rear hub you can use a different cog, but I wouldn't put that kind of effort into it without replacing the freewheel with a single speed one.
You will need to shorten your chain, no getting around that.
You don't have a cassette, you have a freewheel. They come in many types, some are singlespeed, some are multi speed (generally 5-7). Cassettes go on cassette hubs (freehubs).
Useful info here: https://sheldonbrown.com/home.html
Got an old Peugeot
I went ahead and just shortened the chain. It seems ok. I'm now setting up the front brake. When finish, I'll take it for a ride. and then figure out if the chain line is correct.
Sometimes you just need to try ;-)
Thanks,
Kfir
Thanks,
Kfir
Got an old Peugeot
Ok,
Seems that all fine.
I have installed the chain on a big gear and small front ring. Seems to work fine.
The winemann brakes are hard to setup.
I'm now thinking of cutting the bar to bull horns, so I will feel more comfortable, like using modern STI.
Also getting rid of the suicide levers seems hard. I saw it off, but it is not clean.
Any help will be appreciated.
Regards,
Kfir
Regards,
Kfir
Hey Kfir,
I hate to go off topic, but I think I'm going to be in Israel for the summer, May-August in Yemin Orde, a bit south of Tirat Carmel.
I've been told it is pretty secluded there, and I was wondering how easy/safe it is to travel somewhat long distances?
Any advice?
Sorry to go off topic.
On topic though, since you are keeping the wheel the way it is and shortened the chain, it will work fine most of the time.
Be careful with your right leg when you pedal though, if your pants or leg bump the chain, it may fall off or move up a gear.
Any advice?
