Blackburn Rack Bending
Quoted: 60 Post(s)
Liked 195 Times
Looking for a little help a whether these racks can be bent without damage. I purchased this Blackburn rack and it's from a 22.5" frame. I'm putting it on a 21" frame and the seat stay section of the rack is too wide for my frame. I need to reduce the width about 5-7mm. Anyone ever bend one of these with luck? Is there anything special I should do before attempting to vice them in a bit? Would heating over a flame and bending while the rack is warm lessen the chance of breakage?
Thanks to all in advance.
the difference between annealing and melting aluminum is small .
and just warm is meaningless , annealing metals happens at about the temperature, they glow
hard to see when that is reached but in near dark,
there are other racks with adjustable stainless steel struts ,
copies of the older blackburn racks that may fit better for your needs.
Quoted: 60 Post(s)
Liked 195 Times
Bikes: Many
Forgive me if I'm being really stupid here but is it possible to use slightly longer bolts and just space out the 5-7mm with a few washers?
Likes For bradtx:
Quoted: 60 Post(s)
Liked 195 Times
Right now the rack seat stay attachments line up with the center of the seat stay tubes. I need them on the inside of the stays to attach them to the braze-on's. I need to move them together to get them to bolt on.
How much money do you have in the rack? If my eyes aren't fooling me, those struts appears to be solid aluminum. That alone will make them much easier to bend than if they were tubular. Basically, if you don't have a ton of money in it, I'd go ahead and try to bend it. You don't have much to lose. Worst case it breaks and you buy a new, better designed, rack that will fit without issue.
I wouldn't bother heating the aluminum. If it's heat treated aluminum, you'll ruin the heat treatment if you get it hot enough to make a difference. If it's not heat treated, it'll bend readily without heat. Most people caution about bending aluminum because frames are all heat treated to a T6 temper or higher. At that temper, aluminum won't bend far before it cracks. At T0, 6061 bends very easily.
Likes For joejack951:
Mechanic/Tourist
I have bent Blackburn racks to fit, but bending is going to be problematic, as you will need a double bend to make the ends parallel to the braze-ons and you don't have a lot of length to deal with. You could also ignore the braze-on mounts and use a P clip or get a rack that will fit properly and resell that one.
just wonder what happens with out any shop classes in schools ? non shade tree mechanical savvy generations..
Bruce .. just use soft jaws , wood in the vise, etc. you dont want sharp nicks in aluminum .
Quoted: 836 Post(s)
Liked 1,059 Times
Bending 3.5mm per side is nothing for these racks. Most bikes will have to have these Blackburn racks bent a little to fit. Contact Blackburn if you want the most cautious answer and I'm sure they will say it's OK.
Quoted: 19 Post(s)
Liked 7 Times
Why not fit them to the outside of your eyelets? Just spread the legs out 3mm and they will spring back, no ned to permanently bend them . I think I did this with one of my racks, many years ago and it is still working.
SE Wis
Quoted: 2742 Post(s)
Liked 3,389 Times
I've used spacers mostly to clear the brake on this install.
Quoted: 60 Post(s)
Liked 195 Times
Soft jaws was something I would have overlooked. Great input and thanks. The rails are solid aluminum so it's good to hear positive comments about bending. I plan on attempting this over the next month and will post pictures upon completion.
Not quite there yet
Bikes: A bunch of old steel bikes + an ICE trike
I have 2 old Blackburn racks and have used them on a number of different bikes. Each time I would make some bends to customize to the new frame, both to spread/compress or level the rack. I have never had any issues at all. The rack I am currently using on my commuting bike has ~ 30 years use. 5-7 mm is nothing - go for it. Remember - slow and steady pressure is what you are after.
Good luck
Good luck
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
You may not get an answer as this is a zombie thread from 2013
Likes For JoeTBM:
Must be symmetrical
Use a long bolt and spacers. Blackburn racks used to come with aluminum spacers for such purposes.
Doing so will put some leverage on the braze on, and the bolt, if not completely tight, will wiggle in the braze on, loosening more and doing damage. Whenever i need to space out a rack, I install a long bolt from the inside out, so it is screwed tightly against the braze on. For extra piece of mind, fasten a nut from the other side. Then you have a length of bolt really securely attached. Use spacers or washers, then the rack, then a washer and a nut.
Must be symmetrical
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
If you had to bend 6061, you would need to heat it with a torch.
Ahhhh. A zombie thread! I was sucked in!
