Tire recommandation for a 150-200km challenge
Quoted: 37 Post(s)
Liked 23 Times
A few tips I read:
-> remove the original rim tape, degrease the rim, use tubeless tape (2 layers)
-> prepare the inside of the tire with baby powder
-> the area around the valve is critical -> a multi layer of tubeless tape + circular hole is needed
What comes to my mind is to deburr the edges from the spoke holes aswell. I don't like how sharp it feels and when you put pressure with your fingers it might damage the tape.
I like to learn by trial and error rather than based on what others say so I have to try it anyways . I'm convinced preparation is key here. I'll always keep a butyl tube as a spare though, just in case.
Edit: I might use butyl tubes as a first try with the new tires after I installed the tubeless tape on the rim. It should help to put pressure on it so that the fit of the tape is adequate with the rim. Afterwards I'll remove the butyl tube, inspect everything, make the corrections if needed and just go for the latex tube. Let me know how this sounds for you.
Quoted: 338 Post(s)
Liked 408 Times
For me the pinching would occur somehere in the middle of the tube between rim and tyre, on a tubeless designed wheel without rim tape or spoke holes. Didn't use any powder which might have been a mistake. The flats weren't dangerous on the road, but if it happened on a fast descent, yes, that could be.
I did notice a (positive) difference in ride feel between Vredestein latex and butyl, but the issues with the tubes led me to go tubeless.
Quoted: 37 Post(s)
Liked 23 Times
Quoted: 338 Post(s)
Liked 408 Times
Yes.
My thinking is that the tube just migrated somehow under the bead. I mean, otherwise it would self destruct right away which happened once I wasn't extra careful.
It ia probably due to Vredestein latex tubes being super thin, supple and flexible. I can't see the much thicker Michelin latex tubes doing the same.
Quoted: 37 Post(s)
Liked 23 Times
Yes.
Likes For Pulse_:
Randomhead
Liked 3,686 Times
If the tube is under the bead just right, it can go for quite a while before it pops, at least with butyl tubes. I speak from the sad experience of this happening on the first day of a 1200k, which resulted in me getting way behind. I had changed tires so I would be less likely to get a flat. I am not sure I believe latex are any more prone to this than butyl.
There is no doubt that latex tubes will extrude into some pretty tight spaces. I have never used them in clinchers though. At least there should be some contrast with the tire, a bubble of butyl tube under the bead can be really difficult to see sometimes.
Even though they are very expensive, the urethane tubes looked attractive to me. Then I found out they have a lot of problems, heat for one.
Likes For unterhausen:
Quoted: 37 Post(s)
Liked 23 Times
An other inconvenience of latex is related with the heat generated by rim brakes. On hard descents friction can produce so much heat that it can lead to a flat aswell. The other option is to go for a lighter butyle tube like a supersonic from Conti.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Randomhead
Liked 3,686 Times
I saw it there, but I lost interest a couple of months ago when I found out more about those tubes. Not being able to tolerate heat is a deal killer, but there was a list of things about them that I didn't like. Not being able to patch, having fragile valve attachments and I think there are more I forget.
Not having punctures is great, but having a blowout going down a mountain is probably the worst kind of flat.
Quoted: 37 Post(s)
Liked 23 Times
Ok so the installation went flawless.
What I did:
followed this vid:
- deburr the edges of all the spoke holes
- went for 21mm Schwalbe tubeless tape which is the same size as the original rim tape (which I removed, of course) -> it fits my 17mm width rims perfectly
- used a blowdryer to soften the tape while applying on the rim and avoid bubbles (I hadn't any)
- used a patch of gorilla tape at the valve entry before perforating it with a big needle and install the valve (no cutter for me to keep the hole round)-> I did the test of perforating a piece of Schwalbe tape and it tend to tear a bit so I made it stronger with a tape which has a weft already
- use a headlamp (trust me, it helps).
What I didn't do:
- use a standard butyl tube first with the tubeles tape installed to help making the tape stick without bubbles -> wasn't needed with the Schwalbe tape + hair dryer
- use 2 layers of tape -> I used one layer only- because it's really thick and Schwalbe states 2 layers are not needed
- use baby powder -> there was enough on the latex tube and the inside of the GP5000 tire is very slippery already
- use any tool to mount the tire (to keep the tube safe). I had no problem whatsoever to mount the GP5000 on the rim
To me the main thing is to inflate the tire very slowly and keep an eye at the bead and make sure the tube isn't trapped under it. I honestly thought it would be more complicated based on everything I read so it's worth trying it by yourself. Now I'll see how it holds up and will let you know if I didn't fall of a cliff because my tubes popped.
What I did:
followed this vid:
What I didn't do:
Likes For Pulse_:
Liked 2,563 Times
Good video. I cringe (and plug my ears) when I see someone stuff a flat tube into a tire, pry the rest of the tire on with levers, and start pumping back up to 100psi.
Randomhead
Liked 3,686 Times
I didn't watch all of it. Interesting the tire went on easy for him, I have seen people really struggle with those. But he did pull the slack in the bead around to the valve.
Something no one ever talks about now... But if you are going to use tubes, use Tire Talc. In the tire, on the tube. It reduces so many tube issues, from pinched flats to foreign object flats.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Quoted: 37 Post(s)
Liked 23 Times
I'll try to go in further details about the installation and how to avoid pinching. The video shown above is one of the most explicit on youtube but if you still struggle maybe you could follow the tips which helped me:
Do NOT end the last bit of tire bead installation at the valve itself but just 10cm or so away from it.The reason being this is precisely the location where the risk of pinching is the highest because there is a more rigid piece around the bottom of the valve which makes it more difficult to place the beads of the tire between the rim and the tube. If you finish at this place you will struggle not to pinch the tube. So, just before installing the last bit of tire bead on the rim just remove a bit of air from the tube and push on the valve slightly. This will allow the base of the valve to detach from the rim on the inside and give some room for the tire to sit against the rim. Make sure by a visual check that the tire beads are around the valve and not on the tube (this is the single most important check to make). Then, put slightly more air in the tube (just a tad), and let the bottom of the valve sit correctly by doing so. Finish by installing the last bit of the tire bead under the hook of the rim. If needed remove a bit of air again or place the beads all around in the center of the rim where the diameter is the smallest. This will give you some margin to install the bead. While inflating the tube for this 1st time I would suggest to proceed progressively: inflate the tube just enough so that it takes it shape, push the tube gently in the tire, install the beads, deflate slightly if needed, check around the rim for pinching, re-inflate the tube a bit and do the same again until you can't see the rim tape by pushing on the tire anymore. In no case you should be able to see the tube. A last thing: you can use plastic tire levers as soon as you don't put them under the beads of the tire but just use them to push the bead from the outside. It helps on the last bit rather than using fingers.
I hope I'm clear, english isn't my 1st langage and I'm a beginner so take what I say with a grain of salt. But it worked for me. Concerning talc, I would not advice to use more than needed, it would be a mess when changing the tires in the rain and latex tubes come with talc as standard. This said you can put a small amount at the valve base, just to make sure this spot is well "lubricated' (talc acts basically as a dry lubricant).
Edit: a last thing -> I don't think you would want to install a lightweight latex tube if you have a flat on the road -> I'd advice to keep a normal butyl tube wherever you go...
just another gosling
Quoted: 3881 Post(s)
Liked 1,933 Times
Huh. This is all so odd to me. I'm a group ride leader and besides my own flats, I bet I've probably fixed over 100 flats of other riders over the past 25 years. It's simply not hard, though it does make a big difference to have strong thumbs. Of course one inflates the tube first, but just enough to make it round. I never use tools or talc. Too easy to pinch a tube with a tool and who has talc on the road? I always start the second bead at the valve, never ever end it there. When starting at the valve, one "stakes" the valve, that is pushes it into the tire so that the thick stuff surrounding the valve is definitely above the bead and never under it. When working your way around the wheel, popping in the second bead, push that bead toward the center of the rim. When you begin to apply pressure to that last bit of bead, drag your thumb along the tire bead, from valve to the hard part, slightly stretching the bead and probably doing that several times. Finally, just push the bead over the rim with your thumbs. All that said, some rims are easier than others, being slightly deeper in that center well. Since I've changed a lot of tires on a lot of rims, I know which rims are easier and use those.
I don't notice any difference between mounting a latex or butyl tube. It's all the same. And no, latex don't flat more easily than butyl. Might be the other way around. I noticed this thread still here, and having just mounted a latex tube in a 5000 tire on our tandem, thought I'd comment while the procedure was fresh in my mind. It was a butyl tube which flatted and flatted because the tire was worn thin in the center and got an injury there. Slow leak, didn't notice it, got to change it at home. As usual on the tandem, I mounted a 19-23 tube in a 28mm tire. Works fine and is easier. Used my last tire, have to order another pair of 5000s for the tandem.
Results matter
Results matter
Likes For Carbonfiberboy:
Randomhead
Liked 3,686 Times
Ever since the advent of tubeless tires and tubeless ready rims, I have been putting the last bit of bead in place at the valve. Yes, you have to push the valve in so that the tube isn't stuck, but you often have to do that anyway. If you do it before seating the second bead, it isn't as likely to get stuck. The valve takes up some of the available slack that you need to get the bead over the rim, so if you finish up there you have more slack available to you. The only tires I have trouble mounting with my bare hands are really cheap ones, they have a lot of rubber that gets in the way. Hopefully nobody that reads this forum is forced to use something like that, but the same principles apply.
It seems to me that you answered your own question in your second sentence. If you have changed over 100 flats for other people, wouldn't it be nice if they had known how to change their own? I know I always wish the people that I changed flats for knew how to do it themselves. One time in the middle of the night on a 400k, someone I had been riding with had a flat and blew his first 2 tubes by trapping the tube under the bead. So I made him let me put his third and last tube in. I would have been happier just zoning out while he changed his flat than doing it for him. The other guy I was riding with also had a slow leak that he was fixing, but at least he knew what he was doing. I harbor a theory that people who ride old tires should know how to fix a flat and quickly, but I have seen that not to be the case. I usually intervene at the point I see them getting out the tire irons to put the tire back on.
Liked 1,933 Times
The group ride issue is that I have to get the rider back on the road ASAP. So far, I've never ridden with a woman who could change her tire by hand, thus I apologize for being such a sexist about all that. It's fairly easy to get a tire off with tools, not damaging the tube and not a disaster if you do. Putting the tire back on, the tool to use would be a bead jack, no damage as it's just like doing it manually.
So women: carry both tire irons (plastic though) and a bead jack, though I suppose most of you have figured that out.
Results matter
Results matter
Bikes: 2003 Litespeed Vortex, 2017 All-City Mr. Pink, ~1997 Trek Multitrack 700
Quoted: 139 Post(s)
Liked 94 Times
I'm of the belief that ALL riders should have the equipment and skills to fix a flat.
Likes For GadgetGirlIL:
Quoted: 37 Post(s)
Liked 23 Times
Just to let you know the challenge has been potsponed to an undefined date because the organizer was too busy and didn't find the time to end what needed to be done.. Until the end of the week I thought some guys would be willing to ride anyway, even for a shorter distance but they all found a reason not to ride. Whatever, I'll ride by myself for the times to come, this is just the beginning for me. I'm sorry for this, I wished all your good advices would lead to a challenge at the date I announced. You took the time to answer to a beginner like me and I really appreciate your effort.
A little feedback concerning the GP5000 tires + latex tubes. Sensations are phenomenal. First time I rode felt like I was cheating. My average speed didn't change a lot -about 1km/h advantage on the same course- but it must be due to the relative lack of speed variations. The feel is great, the sound too (very distinctive), I have more grip, less weight (-400g), and more comfort than before. I did have a puncture on the rear though but this is due to a piece of glass. The issue would have been the same with my previous setup I think. It's a course where many people go by foot because there is a park nearby so there are many little debris due to human activities. I'm quite concerned about the problem so either I'll need to choose more puncture resistant tires or better places to ride (which is what I'll do).
Right now, I want to prepare my Triban RC520 for winter and road/gravel riding to maximize my time on the saddle. I want to cover every situations with my 3 bikes: road, gravel; mtb.
Typically what tires do you use for winter season, bad/ wet/ slippery roads etc.. ?
Re. tire width, I'm drinking the kool-aid on the wider tire idea. I've only ridden 3 brevets but 2 of them were on 42s and a few weeks ago I rode 44s. They're super cushy and comfortable. I did just pick up a Soma San Marcos that only has clearance for 35s in the back but I still might try to squeeze in a 38 up front. The San Marcos is currently running 28s and the ride quality isn't harsh but it's not as plush as the the bike with 44s.
I think the consensus view is that there's no significant difference in rolling resistance or speed between 25 and 28 with the same quality tire. The pro teams still run mostly 25's so I assume there's some benefit to the narrower tire. Acceleration maybe? I don't know. All the teams have disk brakes, so there's no reason for them not to run wider tires if there was no downside.
For me it comes down to feel. Most of my training rides are 50-100k on pretty good suburban roads and include some hard efforts, so I prefer the feel of narrower tires for that kind of riding. At 150-200k I might run a wider tire or I might not. A solo 150k would almost certainly be on 25's, but I might go much wider on a casual club 200k. There's no one right answer all the time. I say try the 28's. You can always go back to 25's if you like them better. Tires don't last forever so you can try a few different ones out. FWIW I've never seen any reason to try latex tubes.
Quoted: 2332 Post(s)
Liked 2,097 Times
I use latex tubes but my spare is always butyl. The one step where I am very careful installing latex tubes is verifying that the entire tube is properly mounted inside the tire. After installation, I add 15-20 psi and then go around the tire checking the seating visually. Sometimes albeit rare, I will pinch the latex tube between the rim and tire bead. That is and explosion waiting to happen if not immediately at higher pressure. I don't feel like dealing with that step on the road. Personally, I find latex less susceptible to flat tires. They definitely roll much faster than butyl tubes tires.
