Shimano DI2 with Campy Super Record Crankset issues
Hi All,
I recently acquired a 2017 Cervelo R5 with Shimano Ultegra Di2 (11-speed) and Campy Super Record Carbon Crankset and put on for few 40+ miles rides. Overall, the ride was excellent but one thing I noticed during the ride is while shifting from the small to big ring on the front, the chain gets dropped frequently. I completed the ride with just riding on the big ring. Then, I took it to my favorite bike shop here and the tech looked at it and said the gap between the crank and front derailleur is very small and the crank is almost touching derailleur. The crank is actually slightly touching the derailleur cage on rotation. The tech said these two components (Crank and Derailleur) may not be compatible and he is going to check for compatibility and come back. In such case, the crank may need to replaced with Shimano ultegra non-carbon Crankset and bottom bracket as well.
While I trust this shop, I am not sure if they have handled the electronic groupset before. So, my questions to you all,
a) Do you know if the Campy crank and Shimano derailleur combination is compatible?
b) Would you go with replacing the crank and BB with mechanic suggested components?
Any advice on how to handle this repair is highly appreciated.
Thank you.
-maadfw
Thank you.
-maadfw
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
There is nothing anywhere from either Shimano or Campy that is going to say your crank and front derailleur are compatible. You will nor the mechanic will NEVER find this. He's nuts for even saying he's going to look for it.That said,it should work fine and I'm thinking this guy has no experience w/ adjusting Di2.
Quoted: 6193 Post(s)
Liked 4,809 Times
Quoted: 4234 Post(s)
Liked 2,949 Times
+1 get a 2nd opinion. I had a lot of issues with my bikes (things I couldn't fix myself) that I wasn't able to get much improvement on after taking them to a local shop. Finally, moved onto a new shop when the mechanics at the first place told me something I knew was blatantly wrong and suddenly a lot of those niggling annoyances that I could never get quite right (even with the first shop's help) went away.
Quoted: 3238 Post(s)
Liked 2,085 Times
You might have spacing issues between what Di2 thinks is supposed to be the distance between rings on Campy vs. that distance on Shimano. You can likely look that up. If the Campy ring spacing is not the same as Shimano, I could see why the derailer drops the chain. No way around that except use a Shimano crank,
Bikes: State Bicycle Co. Undefeated Track SS/FG, Lynskey Helix-Bronze
Quoted: 115 Post(s)
Liked 204 Times
My brother has a '18 R5; swapped out EPS for DA Di2 but kept the Record 11 crankset since it had the Stages power meter; that was almost 3 yrs ago and he never had any issues.
Thanks guys for all your suggestions. The LBS went out of their way to fix this issue. They first updated the firmware to the latest version and also found that the chainring wasn't fully tight and that was the one causing the chain drops. After they tightened it to the specs, the DI-2 is now shifting between the smaller to big ring without any issues.
Just thought of sharing. Very happy with the LBS.
-maadfw
-maadfw
-maadfw
-maadfw
Good deal
Id still swap that crankset to Shimano though -- im OCD and mixing Japanese and Italian is unsettling.
Like a pizza flavored sushi roll
Likes For J_Chickles:
