2022 Escape 3 Disc vs 2018 Cannondale Quick 4
I'm new to bikes and looking to commute 14mi daily on relatively flat terrain. I'm looking at two used options, first is a like-new 2022 Giant Escape Disc 3 with microshift shifters instead of Shimano for $450. Second is a lightly used Cannondale Quick 4 2018 for $400. Additionally, I thought about buying a Priority Ace of Clubs for $570 and building it at home for the easy to maintain belt drive, though something tells me it's not a good idea... I'm lost so any insight at all would be very much appreciated, thanks!
Clark W. Griswold
Quoted: 4347 Post(s)
Liked 3,983 Times
If someone held a gun to my head I would pick the Crackandfail because it has slightly better parts.
The Priority would be a good choice for a easy to maintain single speed and if you order through Beeline a local shop could potentially build it for you or if nothing else just have them ship it to you and then go to your local shop for building. I would probably go for the Brilliant L Train 8 speed with disc brakes if I was looking for cheap and reliable long term geared bike with a belt. Probably a Continuum Onyx if I was going to be using it often for commuting and if I really could swing it the 600 with the Pinion is really neat.
Make sure whatever bike you get fits well and has decent parts. Tourney is never something I would want on a commuter bike or any bike I am riding more than once and blue moon. For commuting I want the most reliable parts I can get. Saving a tiny bit of money at the front to get a less reliable bike doesn't make sense. The belt drives do make sense and with an Alfine or better yet an Enviolo hub for low to no maintenance is a good option. Plus with things like dynamo hubs for power when you pedal for lights can be a bit costly but in the end I don't need to charge lights or replace lights and I have lights during the day for extra safety.
It sounds like you are interested in a flat bar hybrid bike. I've got a Jamis coda that I'd have no qualms commuting on 14 miles 5 days a week although on flat terrain you'll make better speed with a road bike with drop bars and that's what I use now to commute. A Jamis aurora touring bike. Carries groceries well, too.
I don't mind single speed, down for a workout and my budget is pretty tight so can't do other priorities. Would the priority be worth the extra cost over the cannondale for low maintenance? Don't know a lot about priority or how their parts compare to mainstream brands like cannondale. thanks for the reply
Bikes: Way too many
Quoted: 897 Post(s)
Liked 606 Times
I'd go for whichever fits best.
The Giant is 4 years newer and you get disc brakes instead of rim, and the 7 speed will be easier to maintain than the 9 speed.
The Cannondale does have a carbon fork vs the Giants steel though.
So if it's for all weather use and/or hilly, I'd go for the Giant. If you want smoothness over everything then the Cannondale.
Personally, I'd take the Giant.
Quoted: 1397 Post(s)
Liked 1,874 Times
agree with above recommendation - go with the bike you feel fits better
but without getting a good look at them - I rate the Cannondale above the Giant due to the carbon fork ... the Giant has a steel fork ('high tensile' - not CrMo ?) ... Cannondale 9 spd vs Giant 7 spd ... and Cannondale has the more current/contemporary cockpit etc - 31.8 stem/bar vs the Giant 25.4 (according to specs ?)
( the Cannondale might weigh 2 or 3 lbs less ? )
the Giant has disc brakes and that can be a plus - especially in inclement weather - but low end disc brakes are often not a plus compared to caliper or V brakes (or even cantis ?)
Thanks for all the replies guys. I’m going to go try out the cannondale tonight, see how it feels, and if I think I can do better I’ll try the giant out another day. Much appreciated!
Likes For freddyfazbear:
Clark W. Griswold
Liked 3,983 Times
If you are on a tight budget then spending more on the bike makes the most sense. Having to spend a lot of money post sale sucks and is not worth it and if I can spend more at the front end to spend a whole lot less on the back end I would rather do that.
