Clear up a cassette question, please?
Old 11-24-16, 07:55 PM
67tony
67tony's Avatar
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times in 92 Posts
My buddy has a Titanium Litespeed mountain bike, with a Shimano Deore XT drivetrain. He wore out the chain, big ring, and cassette, so I offered to help him freshen it up. I had a Hyperglide 8-speed cassette, and even though the bike came with a 9-speed cassette I told him the 8-speed would work fine as a replacement.
Since I don't have the cartridge bottom bracket tool, we took it to a bike shop for the BB replacement. There the bike shop guy says, "these are 9-speed shifters, and you have to use a 9-speed cassette".
So...who is correct?
67tony is offline
Old 11-24-16, 08:08 PM
alcjphil
alcjphil's Avatar
Quoted: 1813 Post(s)
Liked 1,691 Times in 972 Posts
The bike shop mechanic is correct, if he has 9 speed shifters he will need a 9 speed cassette. Give this some thought: An 8 speed cassette occupies the same amount of space on the rear hub as a 9 speed cassette, so the distance a 9 speed shifter has to move the derailleur between the lowest and highest gears is the same as for an 8 speed shifter. So it follows that the 9 speed shifter is going to move the derailleur a smaller distance between gears than an 8 speed shifter would. Therefore, starting from one end of the cassette, if you installed an 8 speed cassette, the 9 speed shifter would not move the derailleur far enough to center the chain over the next cog. With each shift, the chain would be farther and farther off center. By the time you reached the middle of the cassette the chain would be directly between 2 cogs looking for that 9th cog in the middle of the cassette.
alcjphil is offline
Old 11-24-16, 08:13 PM
10 Wheels
Galveston County Texas
10 Wheels's Avatar
Bikes: 02 GTO, 2011 Magnum
Quoted: 1349 Post(s)
Liked 1,243 Times in 621 Posts
I use a 9 Speed Shifters with an 8 Speed cassette. No problems
Fred "The Real Fred"
10 Wheels is offline
Old 11-24-16, 09:18 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,834 Times in 2,293 Posts
Consider yourself lucky. In your system it seems there's enough slop to absorb the dimensional differences between 8 and 9 speed der movements. Andy.
Andrew R Stewart is offline
Old 11-24-16, 09:24 PM
10 Wheels
10 Wheels's Avatar
It is on a 7 Speed Hub, that came with a 9 speed cassette that didn't work on the small cog.
It had an extra long lock nut.
Old 11-24-16, 09:44 PM
SkyDog75
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times in 9 Posts
The cogs on a 9-speed Shimano cassette are 4.34 mm apart and so 9-speed shifters are designed to move the rear derailleur that far for each shift. 8-speed cassettes are spaced at 4.8 mm, though. Thus, a 9-speed shifter won't move the derailleur far enough for each shift. It'll undershift about half a millimeter per cog. If the derailleur was adjusted properly for one end of the cassette, it would be 3.5 mm off at the other end, which is more than enough to cause shifting problems.
Can it be made to work? Probably. But it's far from ideal. It could take some ingenuity and/or lots of fiddling to make it work acceptably.
SkyDog75 is offline
Old 11-24-16, 09:54 PM
Andrew R Stewart
So how many actual cogs were in play? The freehub body width has no influence to the movement amount per shifter click. I guess i'm confused by your system and since it's not on my bike have only academic interest. Andy.
Old 11-24-16, 10:02 PM
10 Wheels
10 Wheels's Avatar
I am not a mechanic, but my friend is.
The cassette did not work good so I had him look at it.
The small 11T cog was there on the end but it had no connection to the other cogs , so it didn't work.
It seemed to be there just for looks.
I now have a new 8 spd 11/34 and it works perfect.
Old 11-24-16, 10:06 PM
Andrew R Stewart
So your post #3 was not right?? I think I should leave this mess of a thread. Andy.
Old 11-24-16, 10:08 PM
10 Wheels
10 Wheels's Avatar
Haha
It came with a 2003 New Green Speed GTO
Old 11-24-16, 10:11 PM
10 Wheels
10 Wheels's Avatar
Says 9 Spd but it came with a 7 Spd Hub.
Greenspeed Recumbent Tricycles (Trikes) GTO Recumbent Trike from the Bicycle Man
Old 11-24-16, 10:15 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1785 Post(s)
Liked 1,259 Times in 868 Posts
You're talking about 8 of 9 on 7.
That way you can use 8 cogs on a 7 speed FH.
9 speed spacing is still correct, so you only use 8 of the positions.
This is a TOTALLY DIFFERENT situation then this thread topic.
https://sheldonbrown.com/k7.html#up7
Bill Kapaun is offline
Old 11-24-16, 11:57 PM
Dave Mayer
Dave Mayer's Avatar
Quoted: 1368 Post(s)
Liked 475 Times in 277 Posts
Running a 8-speed cassette with 9-speed shifters will work. But it depends on your definition of 'work'. If you do this, your drivetrain will constantly clatter randomly between gears. No amount of adjustment will fix this.
But this is the M.O. of most recreational cyclists, who are oblivious to the mechanical workings of their bikes; they expect that their drivetrains to be always erratic and noisy.
Yesterday I spent 2 hours working on a bike ridden by a lady who despite having a wide-range triple drivetrain, and having to deal with big hills, exclusively used the granny cog up front and the smallest cog in the back. Because this was the only gear combination that worked.
I suspect most department store bikes are ridden this way as well, in the their 75 mile lifespan - from the time they land off the boat to the time they end up in the landfill.
Dave Mayer is offline
Old 11-25-16, 12:05 PM
AlexCyclistRoch
The Infractionator
AlexCyclistRoch's Avatar
Bikes: Classic road bikes: 1986 Cannondale, 1978 Trek
Quoted: 875 Post(s)
Liked 3 Times in 3 Posts
It's amazing how much floating derailleur pulleys can make up for bad drivetrain builds.....
Bet you have a long-cage derailler; they sit further away from the cogs. A short-cage derailleur doesn't. While your setup can absorb the inherent mis-match (I bet it still doesn't shift well into the outer cogs, BTW), I would doubt that on his bike it would work at all well.
AlexCyclistRoch is offline
Old 11-25-16, 12:08 PM
davidad
Quoted: 582 Post(s)
Liked 171 Times in 138 Posts
You use 9 speed shifters with a 9 speed cassette with one cog removed. I know, I did it.
davidad is offline
Old 11-25-16, 12:12 PM
alcjphil
alcjphil's Avatar
Actually, the point of maximum misadjustment would be in the middle of the cassette where the derailluer would be looking for a cog midway between 2 cogs. By the time it got to the far end of the cassette it would be back in perfect alignment with the 8th cog
alcjphil is offline
Old 11-25-16, 06:46 PM
67tony
67tony's Avatar
Quoted: 209 Post(s)
This response nails my original question...thank you for posting it!
67tony is offline
Old 11-28-16, 02:16 AM
dabac
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
Shimano Cassettes & Freehubs
+1
Functionally, it's an 8-speed drivetrain, but it's (mostly) built out of 9-speed parts.
That way, the three-way fit between cassette spacing, shifter pull and derailer movement still line up. The fact that there's one unused position at the shifter isn't a problem.
dabac is offline
sandeept
Bicycle Mechanics
16
04-16-18 07:54 AM
steinrr
Bicycle Mechanics
11
08-31-13 01:22 PM
Zenmaster2009
Hybrid Bicycles
5
06-06-12 11:42 PM
j3ns
Bicycle Mechanics
12
03-31-11 05:17 PM
Cachequatch
Bicycle Mechanics
7
01-03-10 05:06 PM
