Wahoo Kickr Bike, dual sided power
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
My Wahoo Kickr bike has a built-in (hub) power meter.
I control the Kickr bike from my Wahoo Roam.
I want to use dual-sided power, so I added Garmin Rally RS200 dual-sided pedals.
Problem is, I can find no way to convince the Roam to display pedal power while the Kickr bike is connected.
With both Wahoo and Garmin power meters connected, the Roam defaults to the Wahoo.
Any ideas, or do I now own a low mileage pair of pedals I can't really use?
Barry
Barry
Likes For spelger:
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Nope... no cigar!
Nice idea tho
With Pedals connected, me pedaling and display showing L/R balance (so definitely dual)....
As soon as the bike powers up I lose the L/R balance (so we are back to the Bike hub PM)
Barry
Nice idea tho
Barry
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
bummer. here is another idea...i would assume that the bike is being connected via ant+, so, try to connect to your peddles via blue tooth, assuming they support that protocol.
Liked 1,182 Times
i am hoping that the bluetooth connection will be left alone. i've not tried to connect to my kicker or hrm or cadence sensor via both but mayte tommorw i'll give it a whirl.
Likes For spelger:
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Barry
Liked 1,182 Times
i know, such a total hack, and a miracle if it works.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
I’ve both the Roam and Bolt…. I’ll try that in the morning.
Barry
Barry
Randomhead
Liked 3,696 Times
This seems a little weird. It would mean that if you are riding someone, your roam would connect to your friend's power meter if it likes it better somehow. Similarly if you had two trainer bikes sitting in the same room together. I can't imagine that's really true. Wahoo has some bugs, but I imagine they fixed that one early on.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
The head unit then operates with sensors it’s been Paired with and ignores all others. My issue is the I have to Pair two Power Meters and have no control over which gets used by the Roam.
Now if your at the mid ride stop with friends, unpair and re-pair your Heart Rate monitor, you could get the wrong one.
Then with your friends Heart Rate displayed on your Roam, you get to give him crap for how bad he’s doing for the rest of the ride.
Much fun was had that day.
Barry
Randomhead
Liked 3,696 Times
You can't simply not pair the trainer power? Zwift and trainerroad both allow you to do that.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
The Roam is paired to the trainer in order to control resistance and record Speed & distance.
When pairing you don’t get to choose, you get the whole bike.
Barry
Barry
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Ok fixed!
Solution was the simple application of money.
Purchased a Garmin Edge 860. It’s quite happy to control the bikes resistance, read power from Garmin Rally pedals and ignore the Wahoo Kickr bike built in power meter.
In summery
I’m extremely happy with my Wahoo Kickr bike, but for the bike’s cost, dual sided should have been included.
At very least a path for self upgrade provided for.
I can’t help feel that the Garmin solution is just luck and one (Garmin or Wahoo) firmware update away from failure.
Barry
In summery
Barry
Likes For Barry2:
Quoted: 4234 Post(s)
Liked 2,949 Times
Well, if the firmware update screws that up, you now have 2 bike computers. One to control the kickr bike and the other two get the Garmin pedal data.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
I may yet end up running both Garmin and Wahoo computers, the Garmin will not recognize my Wahoo Headwind fan. I do enjoy being able to control the fan while I’m on the bike.
Barry
Liked 1,182 Times
Tried that already with my Roam & Bolt…. I wind up with two .fit files and data I need in both. Strava and Intervals.icu can’t handle that.
Barry
Barry
Likes For spelger:
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
I'll stick with the Garmin for the time being, it gets me LR balence and a whole host of other
Thanks again
Barry
Randomhead
Liked 3,696 Times
The kickr is really giving you dual sided power, but it's merged together, obviously. I wonder if anyone has ever tried to deconvolve the data.
Wahoo would have to have a fairly complex extra circuit to determine which leg was which. Or a much more expensive crank with built in power meter. I can't imagine it's that important to too many people. The thing that's screwed up is the roam forcing you to use the one power stream instead of the other.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
With a single strain gauge in the Hub you can't determine one leg from the other.
Is the power registered at the Hub from the left leg pushing or the right leg pulling.... no way to tell.
You need two strain gauges, one for each leg. No manor of electronic circuit or decombobulatingism will fix a single strain gauge.
Barry
OH.. and yes it's a shame about the Roam.
It's also a shame it's up on Craigslist as we speak!
Barry
Randomhead
Liked 3,696 Times
Unless you are a rarity, you probably don't put out power from both legs at the same time. I don't know what your left/right balance is, but most people aren't 50/50. If you are, you don't really need two sided power anyway.
I guess I should connect my garmin up to my kickr and see what the data looks like. I'm not sure if zwift carries that much detail
Liked 1,182 Times
Liked 1,182 Times
Likes For spelger:
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Unless you are a rarity, you probably don't put out power from both legs at the same time. I don't know what your left/right balance is, but most people aren't 50/50. If you are, you don't really need two sided power anyway. I guess I should connect my garmin up to my kickr and see what the data looks like. I'm not sure if zwift carries that much detail
YES ..... I do output power from both legs at the same time!
I've worked quite hard in order to do so.
My coach even gives me pedal drills.
And with the help of 21st Century technology documenting my progress, I can get stronger at doing it.
As for my 55/45 split, its not bad, and it does tend to get better at higher outputs, just like my Torque Effectiveness.
By profession I'm a geek and do so enjoy some good data.
Dual-Sided is not just about balance, there is a whole lot more to be had with the right PM.
In simple terms, Imagine this....
You push down with your left leg 50 lbs
But you fail to pick up your 20 lbs right leg
30 lbs pushes you forward
What if you picked up your right leg 25 lbs
55 lbs pushes you forward
What if you used your pedals to push over TDC/BDC.
Lastly to quote my buddy in the UK
"You have to pedal all the way around" - Robert
