Rounded screw on cleat tension adjustmently - Assioma
Bikes: Bianchi Veloce and a custom-made Commonwealth (Medford, MA)
Quoted: 22 Post(s)
Greetings.
I ride Assioma duo pedals. For reasons not totally clear to me - possibly but not surely because I unclip with it - I found the float on my right pedal at its loosest yesterday. However, the screw must be rounded - not stripped - because I cannot get any resistance with my 3mm wrench. None of the suggestions surrounding using rubberbands, etc, work. My question is whether if I drilled the very top of the head out, I'd be able to extract and subsequently replace the screw without ruining the entire mechanism. Thanks for any suggestions.
John
John
Likes For Barry2:
Quoted: 836 Post(s)
Liked 1,061 Times
I'm not real clear as to what the issue is. Is the 3mm wrench socket stripped out or are the threads that the screw goes into stripped? If just the wrench socket is rounded out a tight fitting torx wrench may work or drilling off the head as long as you can grab onto the remaining stud with pliers, vice grips, etc. If you have room, cut a slot for a screwdriver on the screw head. Contacting Assioma may get you some offers of help as well if there is some type of problem with the tension adjustment assembly.
Quoted: 506 Post(s)
Liked 638 Times
Likes For KerryIrons:
Quoted: 491 Post(s)
Liked 431 Times
Sr Member on Sr bikes
I’d just advise that getting the (replacement) screw back into the nut, and with the tension springs positioned correctly, can be difficult.
Dan
Dan
Likes For _ForceD_:
Quoted: 22 Post(s)
Thanks to everyone. I have an inquiry into Favero and do expect to be told to get a replacement body. I've never spent much time observing the exact mechanics of how the increased twisting of the screw actuates the tightness, but to my friend who said "eh", I can assure you that I have never ridden with that much float and that I did not intentionally have the adjustment in the lowest position, as I found it when I hopped off to see what is going on. I used the term "rounded" because there are no threads in the screw head and the wrench itself is fine, since it works perfectly well in the other pedal. It's all academic, as I see a replacement in my future, as well as the very sleek video (it looks more like a magician at work).
