Chain falling off cassette (not what you are thinking)
Bikes: Fairlight Strael 2.0
Shimano Ultegra drivetrain. This isn't the "normal" chain falling off of the cassette issue. I can't shift the chain off of the cassette, the shifting is all spot on. But...
I'm in my biggest gear (chain is on the smallest cog in the cassette). I'm going down a hill, eventually get to 35mph or so and pedaling isn't really helping. So I'm pedaling hard and then I suddenly stop pedaling. The rear cassette has momentum, so it continues to rotate a tiny bit more, which causes the chain to move forward and down to the chain stay. The chain almost touches (or maybe slightly touches) the top of the chain stay. Then the cassette rotates back a few degrees and the chain snaps back (or really, up) into its normal position. And at this point the chain falls off the cassette, to the outside (away from the hub). The chain is off the cassette, and the cassette is now free spinning. I can shift the chain back on to the cassette but as you can guess, this is a huge pain. It doesn't happen every time, but often. More than once I've started to pedal and "Oh Crap my chain is off."
I've never had a bike do this. What is going on? Again, I can't shift the chain off of the cassette, and the shifting is spot on. I sized the chain using the normal "wrap the chain around the biggest rear/biggest front and add one link" measurement. But is my chain one link too big?
I live in Colorado, so this is really annoying, I never have a flat ride.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Highly, extremely, almost definitely not this. If the chain was too long you'd only see it in the small ring/small cog or 2. Wouldn't matter a bit anywhere else. Same with b screw adjustment. What kind of wheels do you have? Sounds like a Mavic freehub that needs cleaning/lubing.
Likes For cxwrench:
Mr. Dopolina
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times
Sounds like drag in the freehub. Should be videos to help you clean/repair this.
Quoted: 2693 Post(s)
Liked 485 Times
It sounds like you have to be careful when really hammering it. My chain/cassette is messed up too but I just got used to it and adjusted my pedal stroke accordingly
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
That was my first thought. Inboard bearing a plastic bushing, what were they thinking.
You can verify this is the issue by the fact the cranks turn when you wheel the bike in a tall gear.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Quoted: 4384 Post(s)
Liked 4,824 Times
Almost certainly going to be a draggy freehub. I get a similar thing happening on my direct drive turbo trainer if I sprint hard and then suddenly stop pedalling. Fortunately it doesn't happen on the road as the freehub on my wheel has much less drag.
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
