New wheels for old bike?
My wife has not ridden in many years until recently. She is now trying to get back into riding (just on local streets and paved trails). She is small and has an old 24" mountain bike that fits her correctly, but over the years the wheel rims have rusted enough that I can't make them smooth enough for really good braking. Two questions:
1. It's an old (probably late 1990s; we bought it used) Roadmaster with 15 speeds (3 chainrings, five rear gears, Shimano derailleur). Can I safely assume the five gears are a cassette that can be removed and mounted on a replacement wheel?
2. I am having a hard time finding a wheelset for as few as 5 speeds on the rear wheel; and it has 24 x 2.00 tires. Most say they are for 7, 8, or 9 speeds and 2 x 1.5 or 1.75. Any suggestions? I would not necessarily object to going to 24 x 1.75; I assume I can adjust the brakes to match.
Yes, we probably will wind up with a new bike, but I want to try the less expensive options first, to get this one in safe condition to ride a bit so we have a basis for deciding what she needs next.
Quoted: 523 Post(s)
Liked 229 Times
First you need to determine if your existing wheels use a cassette or a freewheel. https://pedalchile.com/blog/freewheel-vs-cassette
That is a very entry level bike (cheap) so it might have used a freewheel instead of a cassette. A new 5 speed cassette is pretty cheap but the replacement wheelset is not and even a cheap set is more than the bike is worth. You are probably far better off junking the bike. Spend some time looking for a used bike that fits her instead.
If you are bound and determined to use the old bike you can have new 24" rims put on the existing wheels but buying the rims and having the wheels rebuilt by a bike shop will probably still cost you more than the bike is worth. Figure needing a set of spokes too if you replace the rims.
I certainly do not have sufficient attachment to this one to justify that effort and cost! But I appreciate you mentioning it. Thanks again.
Quoted: 529 Post(s)
Liked 255 Times
Like has been said, look for a complete bike first. Would she be ok on a 26 inch? There are many more of them.
If you do change the wheel on the existing, you don't have to stay with 5 speed. You could get a 6 or 7 speed wheel. You could probably set up the existing derailleur so 5 of those can be used.
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
Try just sanding down the rust on the rims first. Aluminum foil makes an OK rust sanding medium.
Yes you can remove the freewheel and reuse it. You’ll need a special tool.
Yes you can buy a wheel for six or 7 speeds and remount your 5 speed freewheel. There will likely be an axle spacer that makes the difference. Reuse the axle spacer from the 5 speed wheel. You might have to redish the wheel.
I’m doing these steps to a bike right now. Way more of a PITA than it’s worth. I’m only doing it to learn.
I also want to build a wheel- also more of a PITA than it’s worth and only want to do it to learn.
Quoted: 18373 Post(s)
Liked 4,508 Times
You should be able screw a 5-speed freewheel on any wheel that is marked 5/6/7 FREEWHEEL (or upgrade depending on your shifters).
The "Modern Bike" link above lists "135 OLD". That is the measurement between the dropouts on the bike. You should be able to adjust the width, especially with a 5-speed freewheel, but that is another potential complication. Ideally after adjusting spacers, you should also adjust the dish and truing of the wheel.
These are listed as having an aluminum rim, alloy hubs, quick release, freewheel. "135 OLD".
https://www.ebay.com/itm/124753028062
The anodized brake track will eventually wear some, but that is OK.
Bikes: 2017 Surly Cross-Check. 2020 Specialized Turbo Vado 3.0, 2002 GT Dyno Roadster, 2002 Rans Stratus, 2020 Giant Fathom 2, 2011 Trek Pure Sport
Quoted: 171 Post(s)
Liked 85 Times
Honestly, you'll spend too much on new rims. Find another 24" bike with aluminum rims and just swap or get another used, better bike is my $.02
Likes For restlessswind:
Roadmaster is the cheap Walmart brand. And a 20+ year old Walmart bike is not worth much. I would not bother to replace the wheels on that bike unless with some better 24" from a cheap used bike. Otherwise you probably pay more for fixing up than for a decent newer used bike. The classifieds are full of decent used bikes. I would also recommend getting a bike with 26" wheels. The 24" wheels are a bit of an odd size and not that common and tires and tubes can be more difficult to find.
Quoted: 912 Post(s)
Liked 515 Times
Mrs SteveG23 deserves a new bike, or at the very least a very good used one. One she can test ride beforehand or she likely won't like it.
Likes For FBOATSB:
