Cannondale 2.8 Variant
Bikes: Specialized Allez Pro(2003); 1994 Cannondale R 800
Quoted: 5 Post(s)
Liked 12 Times
I used to own a 92 Cannondale – 2.8 R800. Loved that bike but it was stolen. Looked around for a long time for another. Bought some other bikes in the interim (a Lemond, a Specialized Allez Pro which was a great bike) and then ran into a 94 2.8 R800. I was so happy to find one I bought it without looking very close; turns out it was a lightweight variant Cannondale made with 650c sun wheels, Look pedals and some really tall gearing. Crank was 42/53 with an 11/21, 8 speed cassette. While the bike is absolutely original, light and fairly quick, it is a monster riding up a grade into the wind. I live on the SW Florida Coast, wind is a constant and my 79 year old legs have a hard time.
The folks at the local bike shop tell me I probably should change the cassette, but I am not so sure. Would that help; would it be better to change the crank; The other day I looked at a really tough looking 3.0 cannondale with a very nice 9 speed ultegra set up and thought about buying it for the parts (it was really cheap). By the time I made up my mind to do that, it was gone.
So does anyone have a suggestion? Making my legs work better is probably not going to happen. I ride 100 miles or so a week and I think my legs have got as good as they are going to get.
Bill McKay in Sarasota
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
I believe those were early triathlon specific variants. IIRC, in the late 80’s-early 90’s the 650B wheel sets were supposed to be the hot set-up.
You could change the rings on the crankset for lower teeth counts, just have to match the BCD for that specific model. If you change out the spider/crank arms watch the length. I’d definitely look into a lower/wider range cassette set, that shouldn’t be too difficult to find.
There are a few Cannondale gurus here, they can better address specifics about your bike, it’s geometry and tire clearance will have a big effect as to exactly what can be done.
I had a ‘92 R300 that was the best crit ride I could have asked for. Just very snappy and quick handling. I understand what you are saying about Pro range hearing, all three of my bikes are getting a bit tougher to get cranking along🥴
Nice looking ‘Dale you have there! Not one that you see every day, but this is the second one that I have read about in the past 4 days. Must be the moon phase or planetary alignment this week😏
Bill
Bill
Quoted: 5 Post(s)
Liked 12 Times
Thanks for the information. I really like riding it most of the time. It is really nimble. I really want to keep it as my primary ride. Not looking forward to winter. Where I live the wind really blows from the Northeast during the winter months.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Isn't changing the cassette the cheapest, least risky solution to try?
I think you can get a 28t on there, would that be low enough for the headwind?
Quoted: 1607 Post(s)
Liked 2,214 Times
@billmckay - I'm not too far behind you in age but don't do 100 miles a week! That is a target for me.
I have a few hills that are a bit of a challenge, requiring a level of fitness I need to get back too. Even then it was a bit of a challenge.
I have two bike I like to ride, a De Rosa and a Pinarello. The Pin is an 8v and the DR a 10v. The DR has a 25t rear vs the 23t on the Pin. The hills really show the benefit of the 25.
My solution was to convert the double on the Pin to a triple. Huge difference with the 30 vs 39 on the 23t. Much easier.
The conversion from DA740x to Campagnolo Chorus is not complete as I am still using the DA hub and cassette. The new wheels for the bike are tubular with the rear having a 9v Campagnolo cassette with a 26t. That should do the trick for longer steeper hills. What I am giving up is the 12 for the 13 along with the front ring from 53 to 52. I like to coast once in a while, no problem.
Likes For SJX426:
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
I second the cassette swap. It's relatively inexpensive, and pretty non-invasive, as far as the rest of the bike goes.
You probably won't be able to find much smaller than 50/39 for those old 130 BCD cranks; could be enough? But a 'compact' crank with 650 wheels, might result in a really short-geared bike.
Quoted: 5 Post(s)
Liked 12 Times
Thanks all for the help. I am off to the LBS this afternoon to see what they could come up with for a cassette. They had originally suggested that when I first brought it in but as usual I had to overthink things. Will let you all know how it worked out.
Bill McKay
Bill McKay
Likes For billmckay:
Quoted: 5 Post(s)
Liked 12 Times
Put an 11/28 cassette on (along with a new chain) and it solved the problem. Into a really still Northeast wind this morning with no problem (or at least no significant problem) for these old legs.
Bill McKay
Bill McKay
Good to hear that you got a cassette with gearing that you desire.
FYI, if you haven't figured it out yet, seems to be a 1995 R800C (Compact). For a few years CDale made a few models with 650 wheels in a modified road geometry, as well as a triathlon 650 model. The compact model in larger sizes weren't available for very long. Catalogs are available on VintageCannondale.com and should have all specs.
