why does 240w not always feel like 240w?
Quoted: 1274 Post(s)
Liked 1,392 Times
a subject for another discussion, but cyling is the only strenuous exercise i can do without feeling like ****. the ability to vary effort independently of the road is really great. i do need/use a very wide range of gearing, because i can't or shouldn't go absolutely all out for long. but over the past year my 2-3 hour power has gone up around 20%.
Liked 1,392 Times
I've always attributed my "extra" endurance while doing 240w on the flats (relative to 240w climbs, both measured with a PowerTap G3 power meter) being due to the adrenaline that going faster on the flats produces (that's not produced on the climbs), as well as the advantage gained by the cooling effect of going faster on the flats.
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
beta blocker + ace inhibitor + angiotensin blocker + antiarrythmic (flecainide). pretty much the kitchen sink.
Results matter
Results matter
Le Crocodile
Quoted: 370 Post(s)
Liked 787 Times
The watts being discussed here are a measure of a HUMAN output. It is not the wattage provided by a motor. We have these things called "Power Meters" nowadays that measure our body's output (work) using watts as the unit of measure. We can now see exactly what level of force we are applying to the pedals at any given moment.
Quoted: 590 Post(s)
Liked 445 Times
I'm not saying that going 20 mph on the flats would satisfy an adrenaline junky, but going 20 mph is certainly more exciting (aka adrenaline/endorphin producing) than going 7 mph uphill. And is almost certainly a significant factor is this discussion. Faster = More Adrenaline/Endorphins = More Bloodflow and Pain Suppression = Better Feeling Performance.
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 452 Post(s)
Liked 162 Times
I ride on rolling terrain so pretty much have no idea what it is like to ride for a mile or two without a couple of very noticeable inclines thrown in there several times. But I honestly believe that the perfect terrain for me to do my best 20 min ftp test would be a steady 3-5% incline. But just like there are no longish/flat places where I ride, there are no long inclines either.
I did spend a week on Sanibel Island a few years ago and had my bike. I remember clearly thinking "wow - this is different".
dave
dave
Liked 1,392 Times
dave
dave
Quoted: 4399 Post(s)
Liked 4,844 Times
here's a real world example. one week apart - no meaningful change in fitness or weather. the grade is a little less (and slightly variable) than my hypothetical, but the average power and heart rate for these two 12 minute efforts is virtually dead on. both were during a 1.5-2 hr ride after a day of rest. slightly higher rate for the laps is because of slightly longer interval since i took morning meds, which slow HR down from what you'd "naturally" expect it to be. if someone told me i had to continue the effort on the left for 7 more intervals, for a total climb of 4,000 feet, i'd go home. the effort on the right i know i could continue for at least 8 hours with steady intake of food and fluid.
Version 7.0
Bikes: Too Many
Quoted: 1340 Post(s)
Liked 2,482 Times
Here is an article about why some cyclists are better at climbing verus time trialing and vice versa. https://cyclingtips.com/2013/09/clim...-are-affected/
When I lived in NorCal, I would do my FTP test on Kings Mountain versus the Canada Road time trial course. I generated more power climbing.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
This below means he doesn't understand in the article how hip angle affects power output between the two riding positions and also probably hasn't trained for the TT bike that much for there to be THAT big a difference. That's pretty rudimentary stuff. Even road for road bike, climbing you're likely more upright on the bar tops with more open hip angle than chewing bar tape on the flats on a road bike going 25+ mph.
"For example, when I climb I can hold a consistent 400 watts for 15 minutes. I can’t do this when I’m on a TT bike though — I can only manage about 330 watts for 15 minutes. It’s not just me – my mates and I have always debated about why this might be the case and to be honest, none of us really knows."
Likes For burnthesheep:
Liked 4,844 Times
I tried to read that, and despite a few good tidbits some was word salad.
In reality my preferred cadence when climbing is significantly lower than when riding hard on the flat. I will tend to aim for around 85-90 rpm on the flat at threshold power vs 75-80 rpm on a climb. I presume that must be due to differences in muscle recruitment as the article was alluding to. I basically find it harder to spin on a climb even when I'm not gear limited. Of course when it gets super-steep, cadence simply becomes a function of my power limitations!
Likes For PeteHski:
Liked 1,938 Times
For sure I lose power when riding in a more aero position. It's definitely a compromise for me. The article was interesting, but got unnecessarily bogged down with the concept of kinetic energy. Could have simply said that the rider on the flat has more momentum.
Results matter
Results matter
Newbie racer
Liked 1,569 Times
Cadence change is about crank inertial load, the affect of which is to change muscle recruitment, which changes because while climbing, pedal force becomes more spread out and thus cadence will be lower for the same power. We have to bring the pedal over the top. On the flat, inertia can help us do that, but not so much on a steep climb.
Quoted: 6193 Post(s)
Liked 4,808 Times
I was thinking about this statement when I rode the other day. I think it might depend on how you get more aero. And partly I think that must be a fit issue.
When I'm on the hoods in my normal position, then get more aero while still staying on the hoods, then I can't put out as much power either as I could in my normal position when on the hoods. But when I go to the drops and get more aero, then my arms are in a better position to resist the upward force of putting more power into the pedals and therefore more power goes into the pedals and moving the bike.
I haven't had my PM long enough to really say, but I have for a long time noticed that almost all of my personal KOM's for climbing hill segments are while I'm in the drops and very aero. I'd think I'm putting more power out for them and it's not just the aero benefit alone getting me the good time to climb.
Likes For Iride01:
Liked 1,938 Times
To try to add something to this, I personally feel your airspeed and current power output matter with the inertia part on the flats. It's a lot easier if you've got a false flat downhill putting out 150w at 20mph than it is on the pan flats with an airspeed of 28 or 30mph in a time trial. If you're not "on top of the gear" at those air speeds, no amount of inertia from riding the flats will help as the wind turns into your mountain instead of it being an actual mountain. Just thinking out loud.
Gotta be as you say, on top of the gear.
Results matter
Results matter
Liked 4,844 Times
Liked 4,808 Times
I was referring more to my ability to put out sustainable aerobic power rather than a maximal effort. If I'm riding along in the drops or with bent elbows on the hoods I simply can't breathe as well as I can sat more upright in a climbing position. Also the more closed hip angle changes my pedalling dynamics. The simple fact that I spend far more time climbing than riding on the flats probably influences my personal strengths and weaknesses the most. If I am riding hard on the flat I usually favour the hoods over drops.
My biggest thing for staying aero seems to be the little bit of beer gut I get in the winter that takes quite a long time to get rid of. And perhaps just range of motion in my neck keeping me from being able to see as far down the road as I'd like.
While on being on the hoods in a relaxed position is a comfortable position for long drawn out climbs, I still think I put out more power into the pedals when in the drops. And when I do get out of the seat to climb, I also do that better staying in the drops.
I suppose the differences in our bikes might make a world of difference too. I have short reach shallow drop bars on my bike. But still there is a big difference in effort needed to push 20 mph on the hoods and 20 mph in the drops. At least perception wise there is. I haven't gotten around to actually comparing PM data for that. I'm mostly just enjoying the warm weather now when riding.
Liked 4,844 Times
I've never felt that it harder to breathe or my lung function is reduced when in the drops. I even went to narrower bars recently and didn't notice any breathing restriction. But you aren't the only one I've heard that has said being in the drops or that narrow bars make it more difficult for breathing. So I don't know what's up there. Maybe like some people have to be taught how to properly breathe to sing well, there are people that need to be able to change up how they breathe for the bike.
Quoted: 3949 Post(s)
Liked 7,295 Times
You'd have to have a God awful CdA and CRR combo to only go 22mph on 240w on a flat road. Like, you'd need to be up on a mountain bike or Dutch with Gatorskins or knobbies.
So, the physics is off on your estimate. You're putting out less than you think at 22mph, and can thus go longer.
In either case without a good meter, it's still guess work. The hill is closer to reality, the steeper it is. But you'd still need to lookup the CRR of your tires. Flat? Nah. It won't work out without one.
Liked 1,392 Times
that said, i do think the power meter in that bike reads a little high, maybe 5-10%. but it reads consistently high, so the original question still holds. i do believe it's a combination of factors mentioned, crank inertia, heat/wind, adrenaline, boredom/psychology, riding position...
Newbie racer
Liked 1,569 Times
Their loop had zero elevation, it was an outdoor run/bike fitness track. The Strava elevation profile is about 4 posts above. Your loop there got nearly 1000ft in 30mi. A bit different. And, you were at 1/2 mph faster at that also. So almost supporting my claim instead of refuting it.
Liked 7,295 Times
Here's a run at exactly 22.0 mph average:
So, no, it doesn't support your claim.
Newbie racer
Liked 1,569 Times
It was also a loop, so there is no net elevation gain. Basically the first 15 miles are at about 1% and the last 15 miles are at about -1%. (Those small slopes would cause a drop in average speed of about 2% compared to a perfectly flat course.)
Folks are different, and different in this case means a pretty high combo of CRR and CdA for the power given. Others are a lot less. We've a college kid roadie here that did a 20mi loop locally at around 25mph on 260w. No TT bars. With a few small rollers in there. No aero frameset. Maybe 38mm deep wheels. Again, different.
Liked 7,295 Times
