Any science nerd here work out the work equivalence formula for incline vs. flat ?
For example, 1 minute up a 6% grade is equal to X minutes on a flat grade.
If not specifics, has anyone ever come up with a "Rule of 72" style rule of thumb approximation?
Quoted: 506 Post(s)
Liked 638 Times
calories/hr = [Vg*W(.0053 + %G/100) + .0083(Va^3)]*7.2
watts = [Vg*W(.0053 + %G/100) + .0083(Va^3)]*2
where Vg is ground speed, Va is speed through the air (includes head/tail winds), W is bike + rider weight in lbs., and %G is grade in per cent. The factors listed here (0.0053 for friction + rolling resistance and 0.0083 for aerodynamic drag) are obviously not absolute. They will vary with efficiency of the tires and drive train, and with the aerodynamics of the bike + rider combination. Both of these assume a racing position on a racing bike. A clunker bike or a more efficient riding position will change these numbers, which are averages anyway. Power to overcome friction and gravity is proportional only to rider weight and ground speed. Power to overcome wind drag is proportional to the cube of the air speed. For reference, 1 hp = 2700 calories (because of human metabolic efficiency of 24%); 1 calorie = 0.276 watts; 1 hp = 746 watts. Here, all calories are kg-calories, or "food calories."
Analyticcycling.com allows you to put your numbers into a calculator and get numbers out. There are other calculators out there but some of them are pretty inaccurate. They often estimate significantly high calories burned.
Likes For KerryIrons:
Quoted: 4246 Post(s)
Liked 1,351 Times
Bicycle Speed (Velocity) And Power Calculator
Quoted: 20810 Post(s)
Liked 9,456 Times
1 minute of hard work up a 6% grade = 1 minute of hard work on a flat grade.
1 minute of easy effort up a 6% grade = 1 minute of easy effort on a flat grade.
Likes For WhyFi:
Quoted: 2333 Post(s)
Liked 2,097 Times
Depends if bare chested or if the dumpster dove smirnoff was consumed. This would require nonlinear approximations.
Likes For GhostRider62:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Ask this sort of question in the Nutrition and Training forum.
Likes For livedarklions:
Tragically Ignorant
Liked 9,098 Times
Because the OP asked the question so badly, that actually is the correct answer.
The question could make sense if it was asked in terms of distance instead of time.
Quoted: 2952 Post(s)
Liked 3,106 Times
You could get a powermeter and assign real numbers to this exercise if you wanted. Pedal your bike at 250 w (for example). You'd find out that 250 watts for 1 minute = 15 kj, whether you're going up a hill, or on the flat, or with a tailwind, or if you were on a heavy bike or a super-light time trial bike.
Tragically Ignorant
Liked 9,098 Times
Liked 1,351 Times
Likes For njkayaker:
Liked 2,097 Times
1 mile flat = 180-200 vertical feet
YMMV depending on your parameters
Cheerfully low end
Quoted: 645 Post(s)
Liked 1,044 Times
FYI, the last (aero) terms of each formula should be proportional to Vg * Va^2, rather than Va^3.
See, for example, https://www.sportsci.org/encyc/cyclin...wn.html#uphill
Otherwise, you would be needing power and doing work to stand still in a headwind.
Otto
Otto
Quoted: 506 Post(s)
Liked 638 Times
See, for example, Cycling: Uphill and Downhill
Otto
Otto
Cheerfully low end
Quoted: 645 Post(s)
Liked 1,044 Times
That said, the actual wind speed that the rider experiences are hard to determine. My experience based on a large number of time trials is that the wind the rider sees is about 1/3 of what the weather is reporting. "Weather wind" is measured in the wide open and about 30 feet above the ground. Bushes, trees, buildings and simple ground effects all reduce the real speed at bike level.
In the winter, nearly all the leaves are gone and there is a pretty consistent 10-15 mph wind most every day and more in the early spring time before the leaves grow back.
Dont have the link handy but Jobst Brandt did a neat discussion on the effect of wind at all angles and basically its a drag. A side wind increases the workload some, so averaged over all angles, the wind definitely slows you down or requires more power at speed.
Otto
Tragically Ignorant
Liked 9,098 Times
Liked 2,097 Times
550 foot pounds per second = the power of one good horse
An average cyclist is about as good as one third of a horse or about 245 watts.
A pretty fit 183 pound average recreational cyclist developing 1/3 of a horse could travel about 18-20 miles in an hour.....i do about 20 miles at that power on a normal road bike, nothing fancy. OTOH, if this same cyclist were to travel vertically, they would travel 3,606 feet for the same power (246 watts) required to travel 20 mph. So, we can say 20 miles is about 3600 feet or one mile is 180 vertical feet. Some riders are more aero. Some are heavier. But these are sort of my numbers at a tempo or high zone 2 pace when I am not fat. Hope this makes sense, I tried to use a lot of words. Lawyers like words.
Zircon Encrusted Tweezers
Quoted: 260 Post(s)
Liked 128 Times
Can be determined empirically or do the math.
This is kind of interesting. I have pondered before how to do climbing / distance equivalencies and I struggle with it.
Looking at the last two rides I did... Saturday morning and last night. Both rides took me close to 90 minutes. I rode very similar effort and average heart rate on both. Although Ride 1 was done in pretty hot weather, and ride 2 was nice conditions.
Ride 1: 1890 feet of climbing, 101 feet of climbing per mile, 18.8 miles, 91 minutes, 12.4 mph average. Climbing via one mountain climb and one more decent sized hill. Route is 90% up or down. Very little flat, and no rollers either.
Ride 2: 1225 feet of climbing, 47 feet of climbing per mile, 26.3 miles, 86 minutes, 18.3 mph average. Climbing via many small hills, no big ones. Not much flat.
Looking at climbing to equivalent distance, the extra 665 feet I had to climb on Ride 1 reduced my distance by 7.5 miles. And if I had ridden for 5 more minutes on Ride 2 to equal Ride 1's time of 91 minutes, I would have gone another 1.5 miles. So, here the extra 665 feet penalized me by 9 miles. That's 74 feet of climbing = 1 mile.
While I can't fault your analysis, I am wondering what major factors might influence the equivalency. So that sometimes it's 180 ft = 1 mile on the flat, and sometimes its 74 ft climbing = 1 mile on the flat, and sometimes something else. Obviously aerodynamics and body/bike weight count, but perhaps it's also the nature of the climbing too that plays a role.
Tragically Ignorant
Liked 9,098 Times
Also a lawyer, so yeah.
Not a physicist here, but I'd have to think that would vary with grade. It's a lot easier to climb a foot at 1% grade than it is to climb the same foot at 25% grade. If the grade gets steep enough, it becomes actually impossible.
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 910 Times
'workouts' can be about more than 'work'
For example, 10 repetitions with 200 lbs. is vastly different from 100 repetitions at 20 lbs., even if they both equal the same amount of work. Why do so many insist otherwise?
Liked 3,106 Times
True.
False. Why do people believe that total energy expended is the only parameter relevant to describing a 'workout'?
Likes For caloso:
Liked 2,097 Times
So, we're both randonneurs. Let's say I have a 200K with 7,500 feet of climbing. The distance takes me around 6:15. The elevation takes me about 2:15. So, it is going to be a little under 9 hours with controls. If it is a flatter course like in southern NJ or Florida. It is going to be under 7 hours.
On a 300K recently, there was about 11,500 feet of climbing. I rode hard and did under 13 hours. About 20 mph for the distance or about 9 hours and a little under 4 hours for the climbing.
Where it gets tricky is on a long ride like a 1200k because of fatigue and 100 feet might be more like a mile after the first day or so. I predicted my PBP time within 30 minutes with this approach with slight modification, I ignore short shallow hills and because they will be steam rolled.
Note: This back of the envelope is for my upright. The bent is more like 25 mph on the flats and less elevation per hour. I wear the same kit on my upright, so, the aerodynamics are about the same on any brevet. The bent aerodynamics are in another world so to speak. Again, just a rough way for an approximate equivalency, It can be important if there is a control at the top of a mountain......I just barely made the second control out West due to a big climb and several riders just missed it. I knew based on elevation that it would be tight and rode hard, just barely making it.
Another factor is whether you ride at the same output from ride to ride. I tend to ride at a certain HR and it corresponds to a certain power (zone 2). If I am fit and healthy, this power starts at a certain level and declines as time goes by and unless it is very hot, this decline is also fairly predictable.
Tragically Ignorant
Liked 9,098 Times
True.
You aren't the first person to misapply weightlifting logic here, Start with the fact that the differences in weight between bikes are likely small in comparison to the gross weight of the rider and the bike, and that the bike is actually a machine designed to minimize the vertical lifting of the weight and to maximize the advantages of forward momentum and you'll soon realize that the analogies are more confusing than they are helpful.
Also, for that matter, riding in a higher gear, or riding faster add resistance (both mechanical and wind).. Increased weight also just adds resistance. And as pointed out repeatedly, if you really want your resistance in the form of weight, just carry something heavy on your light bike.
Tragically Ignorant
Liked 9,098 Times
Wrong. There's no reason you can't get as much training stress from a lighter bike, one simply adjusts gears, routes, payload, and speed. And if you really want to do it with weight, carry something on your bike.
Want to do the math? How much faster do you have to ride a bike that's 5 pounds lighter in order to equalize the resistance that's being overcome? Please be sure to include drag in your calculations.
