Disque Break Pads: Ware them down to the boan?
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
I go through a lot of Shimano disc brake pads. I usually take them out when they are thinner than 0.9 mm, which is what Shimano officially recommends. Because of the pandemic-induced shortages, I have tried to push it a bit further, and am now replacing them when they start to make noise or feel substandard in braking power, and I've noticed they have this delightful dog-bone wear pattern that is revealed when they are approaching the point where the rotors will be damaged.
Is the 0.9mm Shimano recommendation excessively conservative, or reasonable? I understand why, if someone brings a bike into a shop, you shouldn't send them home with pads that are 85% worn down, but if you monitor them closely, that last 0.4mm might be worth preserving when these are unobtainium.
Quoted: 6193 Post(s)
Liked 4,808 Times
It's not so much the pads and their braking ability, but the fact that the pistons will be further out of their cylinder and that makes for the possibility of them getting skewed in the cylinder and scoring or damaging their walls. Along with the increased problems for seals and such trying to keep dirt and grit out of places it shouldn't be.
I'll happily replace them at the recommended times when I'm able to. I won't worry if let them go longer because I can't find any compatible pads. Though I'll understand that I might be risking having to buy an entire brake assembly because of the potential negative impact on the brake pistons and cylinder.
I might could let Disque pass, but is ware and boan really the correct translation of wear and bone in your native language? And I don't even want to get into break vs brake. <grin>
Likes For Iride01:
Liked 3,434 Times
At least I didn't write ShimaNO.
My native language is FORTRAN.
Liked 4,808 Times
Well if your native language is FORTRAN, then you should know that you have to declare all user defined types. I didn't see a declaration for those words and their implicit definition didn't match the use so I threw a compiler error.
Liked 3,434 Times
Use the --vomit-frame-pointer compiler directive.
Quoted: 645 Post(s)
Liked 797 Times
Likes For Litespud:
Quoted: 2338 Post(s)
Liked 2,822 Times
Heathen, COBOL is the way
Likes For squirtdad:
Location: '16 StumpJ, Salsa Mukluk, Soulcycles SS, Dean Colonel HT, BMC FourstrokeTrail, Dean Torres CX, Santana Visa Tandem, Trek T2000 Tandem, Cupertino MTB Tandem, FreeAgent26"Xtracycle, Dirt Drop Dingle, Jamis Dragon Dingle, Airborne Skyhag SS, SSDean Cols
Quoted: 70 Post(s)
Liked 116 Times
GO1 pads obtain inexpensive obtainableNecessary cooling fins not /maybe 🤔Downhills Clydesdales if not 5+ miles
and drag vertical > 2k /∆ V
Obsolete Package markings
Regardless
Rotors cheap only resin /expensive ice tech
Deform Brake track
Wear premature
springs retaining screeching
Pistons clean
Lube oil mineral with
Worries: none
Much noisy - not
Down pads wearToo late replace beforeOccurs damage rotorLeft none bone
Regardless
Deform Brake track
Wear premature
Pistons clean
Worries: none
Much noisy - not
Likes For Sorcerer:
Quoted: 537 Post(s)
Liked 415 Times
A new cheapie pad will be better than end of life premium pads that are grinding a disc metal on metal.
Unlike automotive brakes, they have a wear indicator made of soft metal so you can hear it when it's time.
But on bikes, they need to be visually inspected. When you hear it, it's too late.
Likes For soyabean:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
IMHO with you being willing and able to monitor them why not get the maximum life out of them? I do much the same with my vehicle service as it nags me for an oil change at 15% oil life and I will hold off until 5%. That being said, I get that reminder every time I start my engine, something a bike can't do. Also my intention for my disc brake bike was to overhaul it this winter but here it is nearly spring and I haven't taken it off the wall.
Long story short, I need to check my pads this week.
Likes For Chuck M:
Quoted: 873 Post(s)
Liked 726 Times
I see 0.5mm in the Shimano dealer's manual for R8050. Also, you can't wear them to the bone because the pad presser springs will start scraping against the rotors. Rotors aren't any easier to source than pads. Don't be penny wise and pound foolish.
Likes For surak:
Quoted: 537 Post(s)
Liked 415 Times
As long as you keep proper engine oil levels, it's very safe to keep using un-burned oil well beyond maintenance recommendations.
This reminds me of the movie '1984' where Winston kept re-using an end of life shaving blade...
Quoted: 2026 Post(s)
Liked 1,096 Times
Not a good analogy since engine oil is already half billion years old.
Likes For HillRider:
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
Likes For dedhed:
Quoted: 6963 Post(s)
Liked 10,962 Times
Current synthetic oils are a lot newer than that. Also, using oil beyond it's recommended service life is foolish, not because the oil itself is worn out but the additives have been used up, and their protection is not what it should be. Save $40 on an oil change and discard a $40,000 vehicle prematurely?
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
...or alternatively, skip the oil change & simply replace the filter & top up the oil to the proper level.
It's not like the oil is bad, it's just the impurities have accumulated. Swapping out the impurity collector before it clogs & the safety valve diverts the flow to bypass mode is savvy equipment operation.
It'd be a hard sell for consumer facing enterprises like car dealerships & Jiffy Lube. But the practice is sound for all manner of industrial applications.
Car dependency is a tax.
Likes For base2:
Clark W. Griswold
Quoted: 4352 Post(s)
Liked 3,990 Times
Replace pads and rotors as needed no need to wear them out to death. Not going to save you anything and could cost you a lot more.
I am seeing 4 different pads (granted non-finned) that will work for those brakes at 50+ in stock at my distributor (and a few others with lower stock) meaning pretty much any shop can get them and probably some shop already got 'em. They even have some E-bike specific pads from Jagwire which would do the trick and sure maybe you are wearing them down quick and the finned pads are nice but possibly a change in braking and also just a little more replacement would do you just fine. So long as you have good quality pads the fins aren't a deal breaker and when you can get them get them otherwise just stick with one of the G-series or style pads for a bit. Brakes are one of those places on a bike I would try and get the most life out of they are relatively cheap to replace and provide an extremely important service in allowing you to stop and slow down which could save your life.
Likes For veganbikes:
Quoted: 537 Post(s)
Liked 415 Times
But a grocery getter that's always doing the speed limit, all they need is proper oil level and good SAE oil that isn't pitch black, which takes a lot to get to, and even more so to the point where there are chunks in it. When these vehicles display 0% life on oil yet it's still golden yellow, it's just wasting money and causing more carbon footprint.
Maintenance schedules really helps folks that never look under the hood, so if they are leaking or burning any, it will be caught on the next visit.
SE Wis
Liked 3,391 Times
But a grocery getter that's always doing the speed limit, all they need is proper oil level and good SAE oil that isn't pitch black, which takes a lot to get to, and even more so to the point where there are chunks in it. When these vehicles display 0% life on oil yet it's still golden yellow, it's just wasting money and causing more carbon footprint..
Quoted: 537 Post(s)
Liked 415 Times
Hey, my friends that own garages and dealerships, trust me are very happy to play that to the clients
Liked 3,434 Times
XT and Ultegra rotors are a bit easier to get ahold of at the moment, vs. L03A pads FWIW.
Last edited by Polaris OBark; 03-16-22 at 11:51 AM. Reason: I wrote J03A. L03A are the ones that are unobtainium currently
Quoted: 537 Post(s)
Liked 415 Times
Which can be further accelerated on an unexpected surprise on avoiding an accident, ie. bikers in front of you that just decide to stop for no reason, just like on interstates.
That's why you really want to stock up on more pads whenever possible.
Liked 3,434 Times
I did have a pad trash a new rotor a couple of years ago on another bike while my kid was riding it, so I understand the problem.
Likes For Polaris OBark:
