1994 Hoo Koo E Koo paint formula
Bikes: 1994 2001 Trek Madone 5.9, 2011 Trek 2.3, 1986 Fuji Absolute, Jamis Explorer 2.0, Diamondback Sorento, Gary Fisher Hoo Koo E Koo
Quoted: 8 Post(s)
Liked 8 Times
Could anyone help me with the paint formula for a 1994 Gary Fisher Hoo Koo E Koo? It is called ballistic blue.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Sherwin Williams Automotive lists the chip number for Ballistic Blue as PCRS32.
See if these guys can get you the formula: https://www.sw-rodandrestocustomcolo...nd-your-color/
Wal-Mart sells the base coat aerosol: https://www.walmart.com/ip/Rod-Resto...osol/278742861
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Guest
Liked 3,270 Times
Quoted: 4192 Post(s)
Liked 3,837 Times
After a number of years of UV exposure a color and any cleat coat can (and often) will shift it's color from the OEM tint. So for touch up work a different "color" will better match the aged OEM one. For a full repaint this isn't an issue but a primer or base coat's color still is a point to also match up with the factory job. There are others (more often in the frame building subs) that might give more detailed advice. Andy
AndrewRStewart
AndrewRStewart
Quoted: 836 Post(s)
Liked 1,058 Times
What size area are you trying to paint? Is this just for a few minor chips or larger areas? Little chips can be matched by mixing paints from a hobby store (fuel resistant types will last longer), nail polish, auto touch up paints, etc.
Quoted: 8 Post(s)
Liked 8 Times
Thanks for all the good advice I will check the paint at Walmart. The bike needs a lot of touch ups and the complete bottom of the bottom bracket needs repainting.
