sci guy's & SmellyAir's CAAD4 Bike Build Bromance
Old 11-22-22, 04:47 PM
  #76
SoSmellyAir
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,461 Times in 1,012 Posts
Originally Posted by the sci guy
I wanna see that final build
It will be similar to yours, but not color coordinated, and with an old geezer stem angle as the steerer is only long enough for a single 15 mm spacer under the stem.
My lackadaisical build progress is mostly due to the daunting task of installing the Hollowtech II BB and crankset. Once I get past that the rest should be relatively easy.
SoSmellyAir is offline
Old 11-22-22, 04:57 PM
  #77
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10947 Post(s)
Liked 7,473 Times in 4,181 Posts
Thats one of my favorite parts of a build- greasing the shell threads, the satisfying feel of the cups twisting in, the solid stop of the wrench when the cups are tight, testing the preload, and cranking down the two bolts. Its one thing I would sit and do for money over and over each day.
mstateglfr is offline
Old 11-22-22, 06:43 PM
  #78
SoSmellyAir
I did not know that I have to test the preload! If you were closer I would invite you over to do it for me in exchange for a fat lunch and beer.
Old 11-22-22, 09:52 PM
  #79
mstateglfr
Sunshine
mstateglfr's Avatar
Yeah, that little cap on the non-drive side arm needs to be tightened before the two bolts on that arm are tightened. It's like a headset- set the preload and then tighten the stem.
Likes For mstateglfr:
Old 11-23-22, 05:41 PM
  #80
SoSmellyAir
Thanks, I had bought the special plastic tool for the NDS crankarm cap; I just did not know that doing the above is called testing the preload.
Likes For SoSmellyAir:
Old 01-03-23, 05:17 PM
  #81
SoSmellyAir
After an almost half year hiatus, I have accomplished what mstateglfr said is one of his favorite parts of a build:
But not so for me; my travails here: Shimano 11s Bottom Bracket & Crankset Installation - Noob Questions - Bike Forums
The process was quite a bit harder than doing the JIS square taper BB and crank arm installation for the 1x conversion of my hybrid.
Old 01-18-23, 08:55 PM
  #82
the sci guy
bill nyecycles
the sci guy's Avatar
Quoted: 789 Post(s)
Liked 350 Times in 190 Posts
Glad to see some progress!! What’s next?
Twitter@theSurlyBiker
Instagram @yankee.velo.foxtrot
the sci guy is offline
Likes For the sci guy:
Old 01-19-23, 12:58 PM
  #83
SoSmellyAir
Next segment is the easy part, i.e., installation of brake calipers and derailleurs. After that, I am debating whether to replace the handlebar with another that has internal routing.
Old 01-22-23, 04:47 PM
  #84
the sci guy
bill nyecycles
Quoted: 789 Post(s)
nah man, I’d keep it traditional. The look of the cables is part of the aesthetic.
Old 01-22-23, 05:37 PM
  #85
SoSmellyAir
The cable housings are only partially routed through the tops and exit the handlebar to the outside of the stem clamp area, so either way would be covered by bar tape.
3T Ernova Team Stealth Handlebar - Components (competitivecyclist.com)
This is the best opportunity to install these bars.
Old 10-18-23, 01:39 PM
  #86
georges1
Steel is real
georges1's Avatar
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 666 Post(s)
Liked 963 Times in 637 Posts
As I said here it is a back up Cannondale frame in my size but if it ever turns into a project I will however buy step by step the components: a cane creek headset, 3T Mutant stem and 3T Mutant handlebar, dura ace 7800 tranmission and brakes , fsa carbon crank , zipp 808/404 wheels with conti 4 season tires and when I feel it need to get built, it will be built. But for the moment as I have far too many projects running on my plate, it will stay as back up
georges1 is offline
