Goofy Glasses: Look like a **** but get down long and low with no Neck Pain
Bikes: Trek Madone 5.2 SL 2007, Look KG386, R022 Re-framed Azzurri Primo, Felt Z5, Trek F7.3 FX
Quoted: 398 Post(s)
Liked 85 Times
Hah hah! You ride with those glasses?
I use it on my trike, when there is a strong headwind. It's more aero than keeping your head tipped up to see through the tops of your glasses. It works perfectly in light traffic, Not well in traffic. There was a company that produced a mirror just for this effect. I'm not saying that the glasses don't work. This is more aero but there is not much fine detail to see in traffic. The glasses seem like they would be better in traffic. The mirror may work better in a triathlon. I had it on a bike with aero bars, it was really great.
Someone here
Imagine a heads up display for a bike... kinda: Triathlon Forum: Slowtwitch Forums
says that the mirrors made a brief appearance in the late 80s early 90s.
I have found the product
https://forum.slowtwitch.com/Slowtwit...ars._P2935266/
https://forum.slowtwitch.com/forum/Sl...met_P1296879-2
It was called a WINDCHEETAH forward viewing system but it does not seem to be available right now.
Bikes: 2019 Supersix Evo, 2002 Trek 2000
Quoted: 273 Post(s)
Liked 45 Times
I get what you're saying -- it's not the prescription thing, it's when you're in the drops and looking forward, you see the tops of the glasses -- I have the same problem.
I, too, commend your effort, but while I'm no slave to fashion, I really don't think I could wear the snooker-glasses.
Something like THIS however, might be closer:
They appear tall enough to be out of one's line of vision, even while in the drops and offer enough wind protection so as to not allow one's contact lenses to utterly dry out and fly off one's eyeballs during extended descents.
Quoted: 398 Post(s)
Liked 85 Times
Those sunglasses will all work with contact lenses. The Goofy Glasses are only for those that want to wear prescription spectacles.
There are prescription sunglasses, but I find it difficult to believe that the top part of the frame does not obscure vision.
https://www.adseyewear.com/prescripti...ng-sunglasses/
I may go back to contacts and use them with sunglasses, but for the past many years I have not liked putting things in my eyes. On the other hand I would like some tinted goofy snooker glasses, perhaps in orange.
I got another bike since then and no longer have the problem though.
Quoted: 398 Post(s)
Liked 85 Times
In order to make them less goofy, all that is needed is for Oakley or someone to make a typical 'cool' wrap around style with the frame below rather than above the lens, and to provide prescription lenses.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
i don't like contacts because they get dry. i might look into the snooker glasses idea.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
"look into" glasses...get it? get it?
Quoted: 398 Post(s)
Liked 85 Times
Clearly.
I have found that most opticians will be happy to put lenses into cheap frames cutting them to any size you stipulate. I used to put lenses in to 100 yen store (dollar store) rimless reading glasses, for about 51USD (50 for the lens) per pair.
These half frames be found cheaply second hand or from dollar stores. Rimless supported at the bottom of the lens might also be an option. So you could probably get his done in Taiwan a lot cheaper than any of the stores above.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
Clearly.
Thanks for the amusing thread! I sympathize, though, I have terrible eyesight and astigmatism. I used to wear contacts, but none are comfortable now and I am stuck with glasses. Not a candidate for surgery either.
I find that having a raised stem, combined with the Croakies retainer strap on regular glasses, helps me see ahead, even in the drops. Of course, I am not racing nor am I very aero - I have some back issues, so I've got spacers and a raised stem... The Croakies strap does allow more sweat to get on your glasses and for fogging to occur. Still, I would be too self-conscious to wear the glasses in your picture. Do your glasses fog up a lot?
Quoted: 398 Post(s)
Liked 85 Times
I am finding that I can get down lower lately, and am looking for a longer lower stem for improved aero position rather than a higher one. I did not need the glasses at first.
I do find that there is a bit of a problem with sweat running into my eyes. Eyebrows evolved, I believe, at least in part, to catch the sweat rolling down our foreheads and then evaporate the same from those curly hairs before it runs into our eyes. Since my eyebrows are behind the screen of my goofy glasses, less wind hits them so I get more sweat-in-eyes problems than with normal glasses, especially if I use them and do not get down low. If I use the glasses properly, i.e. with the lens facing somewhat down, then enough air comes over the top to prevent problems. It is not a big issue though, and occurs I guess with sports sunglasses too. Also, this is more of an issue for me since I am bald, my sweat does not evaporate from my head much either. I don't have issues when I am wearing a hat thing like that deceased Italian "pirate," RIP.
Quoted: 398 Post(s)
Liked 85 Times
And in normal bike position (no way are the glasses actually facing directly at the ground, but even in a fairly aero position like this, I can almost see the tops of the lenses)
The 100 yen ear muffs, which reduce wind noise, are pictured here
https://tinyurl.com/100yenshopearmuffs
Quoted: 1063 Post(s)
Liked 771 Times
The cans really didn't work. Cheap ear muffs do. Here we go....
100~Vbv bt - Google
100~Vbv bt - Google
Administrator
Quoted: 11891 Post(s)
Liked 6,486 Times
A bunch of spandex-wearing, leg-shaving, non-waving guys are worried about looking goofy on the bike? Seriously?
It's a great alternative solution. And it's not like they're going to be your all day, everyday glasses.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
best thread for a long time.
Likes For coasting:
Likes For RPK79:
Bikes: 2006 Raleigh Cadent 2.0, 2016 Trek Emonda ALR 6, 2015 Propel Advanced SL 2, 2000 K2 Zed SE
Quoted: 115 Post(s)
Has the problem been solved? I have some sports glasses but when I tilt my head down I can see the top part of the frame. I have yet to encounter cycling/sports glasses with lenses which come up as high on the forehead. Many of them seem to take prescription lenses as inserts.
With the Racing Jacket's thick frame you'd think it would be a problem, but cycling glasses are not quite the same as more generic sports glasses. It also depends a bit on the shape of your face.
They aren't a cheap solution, but Oakley isn't the only cycling glasses frame maker. I just need to go to the more indestructible side of things; I'm not as careful as I should be. Oakleys are pretty tough.
Quoted: 398 Post(s)
Liked 85 Times
In my earlier version I put them closer to my face but sweat would run off my forehead onto the lens. The second pair are so far above my brow to allow for a few millimetres gap between my brow and the lens for ventilation and to keep sweat from running onto the lens.
And as you point out, they are not cheap.
Oakley Racing Jacket Prescription Sunglasses | Get Free Shipping
It seems that the Oakleys are 160USD plus lenses, which are, wow, 70USD each for a total of 400USD per pair. Cool is 4 to 8 times the price of dork. (mine were $51 clear, and perhaps $101 tinted.)
The frames are flimsy but can be replaced for $1 (Japanese Opticians do repairs for free, the frames are from the dollar store).
Also I can't understand how you are not seeing the frames. When I am on the drops I am looking under my brow (I can see bushy eyebrows at the top of my field of vision like this (from https://www.flickr.com/photos/nihonbunka/10094442395/)
) but these guy must be seeing some frame because you can see some eyebrow above the frame.
From
https://boncycle.exblog.jp/18081748/
From
https://www.shadestation.co.uk/style-...our-de-france/
When you say you can't see frame is that even when you go down low?
Last edited by timtak; 05-21-14 at 06:47 PM. Reason: added photos of oakleys and my eyebrows
Quoted: 398 Post(s)
Liked 85 Times
New Version
The half-frame reading glasses were too flimsy and broke so I cut the tops off some flexible dollar store sunglasses and the result is shown below
These are a bit taller still since they start lower on my face. The height above my brow is about the same, and results in my being able to see only the outside corners of the lenses.
I have added some cable ties to create an L behind the ear for added security of fit.
They are a bit stronger but not as strong as I would like.
Sp I stilll wish Oakley would produce some and keep me in pairs for the idea. They need a name. Goofy Glasses. Space Specs. Lanced Lenses, to go with my Lanced bike, the use of which necessitates the use of these spectacles.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
now this is too far. you look like such a goof ball.
You can get frameless untinted wraparound safety glasses at some hardware stores for around $20. They work great & aren't quite so... umm... unique looking.
Plus, too, and also, you can get polarized frameless sunglasses in the WalMart fishing department for $5 to $15. If you scratch 'em, who cares? $15.
