How tall are you and what frame size do you ride?
5'10 and a 54cm. I am almost always better with one size smaller than manufactor suggested ideal. Worst case I swap stems and wider bars
Quoted: 18 Post(s)
I'm 5 10 and ride 54cm 54cm ctc. Long legs and short upper body. But I always like riding a little smaller bike, to me it handles quicker and I can have a little longer stem. Makes for a solid handling quick bike.
Quoted: 1062 Post(s)
Liked 665 Times
I'm 5'10" and my bikes range from 53 to 56 cm with horizontal top tubes. Of course the shorter frame has more standover clearance. The 53 is generous and the 56 is snug. I also have a 60 cm frame that's uncomfortable for me to stand over. The 53 cm frame was 10 bucks, and it's my favorite ride right now. If it matters, I tend to wear regular street clothes, not spandex, so maybe I need a little more clearance if you catch my drift.
With that said, I see no other relationship between frame "size" and the fit and ride of my bikes, because they vary in other dimensions such as reach, and they have a variety of stems and handlebars based on what I've picked up over the years.
If I were looking for a new frame, I think that 54 would be the tallest that I'd choose, unless a 56 was some sort of insane bargain in pristine condition.
Too many variable dimensions in modern frame geometry to give a number. I usually fluctuate between Large and XL frame sizes. 6'0" with 33" inseam.
Quoted: 4559 Post(s)
Liked 2,802 Times
5'11", 33" inseam. I usually prefer 56-58 cm. But I'm more comfortable with a little shorter reach due to an old neck injury. I might try test riding a 54, just to see if the seat post and stem length can be adjusted to suit me.
velo-dilettante
Quoted: 1628 Post(s)
Liked 3,114 Times
6'0." '33 inseam and in between a 40 regular and 40 long suit coat/jacket. currently riding both a 58 and a 59 but had and sold a 60 that also worked.
between stem/seatpost length and saddle positioning, able to make all three sizes work. all 3 bikes i've ridden in the three different sizes were all
a more relaxed geometry and i usually only ride in the drops on descents. have had lower back problems the last 15 years (currently on hiatus thank goodness)
but none of the particular sizes of 58, 59 or 60 seemed to alleviate or exacerbate symptoms better or worse than the others. the 59 feels the most
comfortable/natural.
6-0 with a 33 inseam. 56cm frame is a pretty solid number across the board for me. 90mm stem seems to work well, 175 crank arm. 55/57 can work as well, depends on the bike and setup.
5'9" and I ride a 52 with a 100mm stem. (Came with a 90mm) Sounds small, but my inseam is 34, so I usually have to ride bikes one size smaller due to short torso. Took me a while to figure that out. Lol.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Most of my bikes were purchased years ago when I was taller. I was 6'1" and my bikes were 64cm/25" for road. I have since shrunk and can still straddle a tall frame but will probably buy 62cm/24" if I get another.
The jeans I bought recently were 34" inseam and the Bridgestone RB-T I bought for my retirement present three years ago was a 62cm, and my height last doctor visit was shockingly (to me) less than 6 feet.
Quoted: 623 Post(s)
Liked 397 Times
I'm 5'10" on a good day. I have a frog body...long arms and legs, but short torso. My Jamis Quest is a 56 cm , but my Jamis Expert is a 58 cm with a shorter stem. I've had hybrids that were 19"/Large.
Fredly Fredster
5'10"... 56cm on road bikes, 55cm on gravel bike. Long arms and legs... short torso.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
5'10", with a paltry 29" inseam. I prefer larger bikes, even if I can't always stand over them, because the top tube suits my torso better and leg adjustments are easy.
-Mazama is medium, was on the line between the two and would have preferred the large but that is what was on sale. Had to bump up the length of the stem significantly
-Trek 520 is a 58, fits fine
-Schwinn Le Tour is a 23", fits like a glove. Best fitting bike I own.
-IIRC, the Univega is a 53. Fit is "meh", no complaints or discomfort, but doesn't feel all that inspiring.
-Scott touring-conversion bike is a 16". I'd never buy one small, but it was my first "real" bike that I have no desire to get rid of, and the trekking bars and longer stem make it fit fine.
-Scott fat bike is a medium, that is the only one I purposefully went smaller on, tires make it sit much higher, more worried about coming off and banging the crotch on that than any other bike Also had to use a longer stem.
Calamari Marionette Ph.D
Six foot tall with average proportions. My favorite bike fit is 66cm. But that's with townie bars, not drops.
Do people also find different manufacturers bikes seem to size differently ... I've been looking at buying a Giant Gravel Bike and was quite surprised that for my 5"7 they were suggesting small / 52cm when most other manufacturers would be a medium / 54cm.
Ride what fits best? For you, and your reach and leg length. Road bike, touring bike, racing road bike, fat bike, or mt bike?
I used to be 5' 8-1/2", but have shrunk a bit with age... Pants inseam 29.5, sleeve length 34.5. Back 40+ years ago when I was a teenager, there wasn't the selection of sizes we have today. Fuji came in 19", 21", 23" and 25" , and you must remember this is also with 27x1-1/4" tires, too! The LBS tried to steer me to a 21" frame bike, but I felt too cramped front-to-back.. The 23" frame (~58cm) fit me much better. The standover height issue is a bit over-rated. Yes, 'the boys' would be feel the squeeze if I were to stand with both feet flat-footed, but who does that??? Never happened to me in over 40 years, either! I guess ideally I should be on a 56cm, but those didn't exist in my price range back then.
So, that said, here are my bike sizes...
23" frame '75 Fuji S-10s w/27x1-1/8 tires
23" frame '84 Univega Viva Sport 27x1-1/8 tires
23" frame '84 Univega Gran Tourismo 27x1-1/4 tires
57cm frame '86 Miyata 710 700cx28 tires.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Hey everyone, I am trying to gather some insight on pairing frame size with height.
I always been riding a 54 cm but I am thinking about moving to a 53 cm. I am 5 feet 8 inches. I know there are a lot of factors like leg length, arm reach, etc, but still I want to know!
The difference between a 53 and 54 can be significant.
I would try the 53.
Bikes: Specialized Diverge E5 Comp, Specialized AWOL Comp, Scott Solace 10
Quoted: 137 Post(s)
Liked 27 Times
I'm definitely an oddity - 5'7", and I'm most comfortable on a 56 cm frame. I know that sounds ridiculously big for my height, but I genuinely feel cramped on a 54 and feel properly relaxed and appropriately stretched out on a 56.
I've got a 56 cm Scott road bike, a 56 cm Specialized Diverge, and a medium AWOL (which has about the same reach as the Scott). And I've comfortably ridden the Scott and AWOL for hours at a time. I haven't owned the Diverge long enough to see how I fare over a long ride, but it feels like it fits perfectly and certainly fit better than the 54 I tried out.
