Can ATAC cleat position be adjusted?
Old 01-29-22, 12:31 AM
ese002
My left knee wants to fall outward causing me pain on the inside. If I focus and force that knee in, I can ride without pain but it doesn't take much ill attention for the aching to begin. Is there a way to fix this? If I understand correctly, moving the cleat to the outside should help but neither the shoes nor the cleat have slots.
ese002 is offline
Old 01-29-22, 03:47 AM
Canker
Quoted: 261 Post(s)
Liked 115 Times in 69 Posts
No. Time is forward and backwards adjustable only(unless there is some funky time atac cleat I don't know about). Shimano and Crankborthers have some side to side adjustment built into the cleats, and it looks like some CB cleats have it and some don't. I've only ever ran time atacs.
Canker is offline
Old 01-29-22, 10:31 AM
ese002
How would even forward/backward be adjusted? Do you mean flipping the cleat over?
ese002 is offline
Old 01-29-22, 11:03 AM
mprince
Dont fix whats not broken
Bikes: Steelman Stage Race, Dura-Ace 9s
Quoted: 94 Post(s)
Liked 164 Times in 93 Posts
Most 2 bolt (SPD) shoes are slotted, allowing for fore/aft movement of the clear. If you are looking for your feet to be further apart, you can install thin washers between the pedal and crank arm for small adjustments, or install pedal extenders for larger adjustments. The BikeFit website has all of this stuff available for sale.
mprince is offline
Old 01-29-22, 11:09 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
Bikes: Soma Fog Cutter, Surly Wednesday, Turner 5-Spot, Canfielld Tilt
Quoted: 2401 Post(s)
Liked 2,029 Times in 1,133 Posts
Every clipless cycling shoe for mtb (2 bolt) cleats I have ever seen has two slots that the two cleat bolts go through that allow fore/aft as well as some rotational adjustment.
Like this:
Kapusta is online now
Old 01-30-22, 04:45 PM
jaxgtr
jaxgtr's Avatar
Bikes: Trek Domane SLR 7, Trek Emonda ALR 6, Trek FX 5 Sport
Quoted: 414 Post(s)
Liked 825 Times in 503 Posts
you can slightly position the cleat to kinda of point to the left or right, but it's very little. My right foot tend to point in, so when I put my ATAC cleats on, the right foot nose of the cleat is positioned a little right to straighten the foot a little.
Brian | 2021 Trek Domane SLR 7 | 2016 Trek Emonda ALR 6 | 2022 Trek FX Sport 5 (On Order)
Originally Posted by AEO View Post
you should learn to embrace change, and mock it's failings every step of the way.
jaxgtr is offline
Old 01-30-22, 07:52 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1505 Post(s)
Liked 2,153 Times in 1,124 Posts
You've never noticed the slots in the sole of your shoes? And the 4 hole mounting plates?
cxwrench is online now
Old 01-31-22, 12:42 AM
ese002
My shoes have only a single pair of holes that match the spacing of the ATAC cleat. Nor is it obvious that the platform can be shifted. After Kapusta's post I went back to shoes and discovered that if I push a hex wrench into one of the holes when no cleat was installed, I could shift the plate up and down. Good to know, even if it isn't obviously a solution for the problem at hand.
ese002 is offline
Old 02-12-22, 01:22 PM
ese002
Unfortunately, BikeFit is out of stock for an indefinite period. Does anyone know of an equivalent product that is actually available? I tried Kneesavers but when I got it home I realized that the extender has only wrench flats, no hex socket. Since the ATAC has only a hex socket, the combination leaves no reliable way to tighten or remove the pedal.
ese002 is offline
Old 02-16-22, 03:34 PM
63rickert
Quoted: 1011 Post(s)
Liked 294 Times in 221 Posts
Very long time since I used my ATAC pedals. The cleats, or at least my aged cleats, are not symmetrical. If memory serves it was 5 degrees rotation to unclick in one direction and 15 in the other. Move the cleats from left shoe to right shoe and the long swing is on the other side. Do you have any available rotation in mounting the cleats? I had my cleats on two different pairs of shoes and they were not same. What I am suggesting is you try rotating the cleat so that it becomes firm as soon as your knee begins to drift. Not sure if any of this will apply for you but if it does worth a try.
63rickert is offline
