"Ideal" cycling temp
Old 04-13-22, 01:56 PM
noimagination
Quoted: 364 Post(s)
Liked 418 Times in 247 Posts
https://pezcyclingnews.com/toolbox/i...-for-exercise/
Really? Neither 10°C (50°F) nor -4°C (25°F) sound right to me.
My experience is that I am "faster" when it is quite warm. I've not done any controlled tests, but I feel fastest somewhere in the range 78°F (25.5°C) to 84°F (29°C).
Although the article is in Pez, I don't think the study really applies to cycling. I think the following factors (in order of effect from low to high) make the "ideal" temperature for cycling quite different (higher).
1. Cold air is denser, at cycling speeds there is a perceptible difference between air resistance of cold and warm air, though the difference is small.
2. Increased air resistance due to extra clothing being worn, means that cycling at 25°F, or even 50°F, is less "ideal". Also there is a small amount of effort that goes into deforming tights or knee/leg warmers when those are worn. This is not noticeable for light tights/knee/leg warmers, but for thicker wind-front tights you can feel the resistance to your pedaling motion.
3. Better muscle contraction at warmer temperatures means you can apply more force to the pedals in warmer conditions (up to a point, of course).
4. Increased efficiency of evaporative cooling due to the increased airflow over one's body at cycling speeds means that cycling in colder temps cools your muscles too much. It is more "ideal" to cycle at warmer temps when evaporative cooling balances the heat generated by cycling so that muscles are warm-but-not-too-warm.
Eventually the deleterious effects of higher temperatures negate the positive effects of cycling at warmer temperatures, of course, but IMO the "ideal" cycling temperature is a lot higher than is suggested in the article.
noimagination is offline
Old 04-13-22, 02:08 PM
CrimsonEclipse
Quoted: 540 Post(s)
Liked 618 Times in 362 Posts
Any weather you can tolerate is ideal.
For me, day or night between -10c to +20c (+30c if raining) with winds less than 40kph
Not hard limits, but good guidelines.
CrimsonEclipse is offline
Old 04-13-22, 02:09 PM
Troul
Troul's Avatar
Liked 2,935 Times in 1,899 Posts
less than 4 mph wind, dry, above 50F below 90F
-Oh Hey!
Troul is offline
Likes For Troul:
Old 04-13-22, 03:46 PM
rodymanners
Quoted: 9 Post(s)
Liked 13 Times in 11 Posts
I think it depends on how every individual can handle heat or cold
rodymanners is offline
Likes For rodymanners:
Old 04-13-22, 03:55 PM
Wildwood
Veteran, Pacifist
Wildwood's Avatar
Quoted: 3895 Post(s)
Liked 4,821 Times in 2,226 Posts
My preference is between 62* and 64* depending of course on humidity.
Wildwood is offline
Likes For Wildwood:
Old 04-13-22, 04:03 PM
zandoval
zandoval's Avatar
Quoted: 949 Post(s)
Liked 1,617 Times in 1,038 Posts
"Used Ta Could Ah" but not any more.
Now days its gotta be above 45°F, day time, with dry roads and minimal traffic...
I have become such a weakling... Ha
zandoval is offline
Likes For zandoval:
Old 04-13-22, 04:37 PM
wolfchild
Quoted: 4227 Post(s)
Liked 2,488 Times in 1,286 Posts
I don't focus on speed, so temperature is irrelevant to me.
wolfchild is offline
Old 04-13-22, 04:41 PM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
25C, no wind.
caloso is offline
Likes For caloso:
Old 04-13-22, 07:31 PM
qwaalodge
Quoted: 211 Post(s)
Liked 79 Times in 61 Posts
I ride mostly in >85 F temperatures >60% humidity, year round . However, I found myself fastest in the 60's at humidity below 50%. Temperatures here very rarely drop below 60F so I have no idea if I will perform better at even lower temperatures.
I grew up and live in the tropics but my ancestors lived high up in the mountains. Never acclimated to the heat as well as several other relatives. Relatives from that tree tend to have strong aerobic base but weak tolerance to the heat.
qwaalodge is offline
Old 04-13-22, 08:12 PM
Random11
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times in 197 Posts
Seems like there was a similar thread here in the past year. For me, 60 degrees F (16 degrees C) is ideal. Cool but not cold.
Random11 is offline
Likes For Random11:
Old 04-14-22, 05:09 AM
noimagination
Quoted: 364 Post(s)
What is interesting to me is that this is a purported data-based study, presented on a cycling site, which reaches a conclusion that seems, on the face of it, to be irrelevant as applied to cycling.
Likes For noimagination:
Old 04-14-22, 05:23 AM
GhostRider62
Quoted: 2332 Post(s)
Liked 2,097 Times in 1,314 Posts
Warmer and more humid reduces aerodynamic drag and tire rolling resistance but destroys power output. If I am going to do a 10 mile time trial, I want it 85-90 F as, humid as possible, and low atmospheric pressure like right after a T-storm. By the end of the race, my power is still good but starting to fade. On long rides, I prefer colder temperatures, certainly below 70F. 60-70F is a nice range.
GhostRider62 is offline
Old 04-14-22, 06:55 AM
qwaalodge
Quoted: 211 Post(s)
If you look closely at the study, the test subjects were athletes. Most likely at the competitive levels and some are probably professional athletes. Higher watts / kg of athletes would certainly result to higher core temperature and if the heat is not dissipated quickly enough, may cause heat stroke. The lower ambient temperatures, the faster you can dissipate body heat and higher power output you can possibly generate without giving yourself a heat stroke.
In my own experience, I was a bit faster at higher temperatures (90F) when I just got into cycling and never had any issues. It felt easier to pedal the bike at higher temperatures. Perhaps due to less drag, less friction/rolling resistance, etc.
But now, at significantly higher power output, I can only achieve my peak performance at the lowest temperatures and that's 60F, 30% humidity for me so far in this tropical region. During 90F, 60% humidity, if I do harder efforts than a recovery ride, I get varying degrees of heat stroke symptoms.
Old 04-14-22, 10:00 AM
KerryIrons
Quoted: 503 Post(s)
Liked 630 Times in 352 Posts
Pretty good summary, though for me it would be 5-10 degrees cooler. I did time trials once a week for a three decades and my ideal conditions were 80 F, high humidity, and no wind. For long-distance rides, 75 F and low humidity are much preferred.
KerryIrons is offline
Likes For KerryIrons:
Old 04-14-22, 10:29 AM
timdow
Miles to Go
timdow's Avatar
Bikes: 2022 Juiced Crosscurrent X, 2022 Fuji Touring, 1998 Schwinn Moab (drop bar conversion), 2010 LHT (Stolen)
Quoted: 151 Post(s)
Liked 145 Times in 95 Posts
Depends if the sun is out or not, but 60-70F.... Preferably with a tail-wind!
timdow is offline
Old 04-14-22, 01:53 PM
Rdmonster69
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times in 216 Posts
Today its 55 with 20 mph wind gusts. Gonna see how cold it feels and maybe go ride .... maybe wave off. I rode several times in March down to about 40 degrees. I have decent gear and can handle it but man ....it is hard on my neck and not much better on my leg.
Rdmonster69 is offline
Old 04-14-22, 02:09 PM
noimagination
Quoted: 364 Post(s)
That is a good point, and one I did think of after I posted. You see pro cyclists racing with bare legs and arms in temps that would have me covering up, most likely because, as you say, they're able to put out so much more wattage than I that they can maintain their body temp. On a recovery ride, on the other hand, a pro would likely wear more than I, due to their much lower % body fat.
It's analogous to when my wife and I ride our tandem: I've got knee warmers, a wool t-shirt and a wind-front jersey; she's got full booties, thermal wind-front tights, wool t-shirt, wool ls base layer, ls cycling jersey, cycling jacket and cycling shell.
Old 04-14-22, 02:53 PM
livedarklions
Tragically Ignorant
livedarklions's Avatar
Quoted: 8186 Post(s)
Liked 9,095 Times in 5,053 Posts
These aren't just runners, they're endurance runners, a really specialized kind of athlete. I have to wonder if this would generalize even to other types of runners, who likely have different body builds and shorter times to endure.
livedarklions is offline
Old 04-14-22, 07:08 PM
qwaalodge
Quoted: 211 Post(s)
Perhaps true, on recovery rides. I wouldn't mind wearing regular wool articles either if the need comes to that. I ride all-weather. It just happens we have no winter here and never got to cycle in winter temps.
However, I have experience hiking up mountains at <0 C <32F. On one occasion, the temperature is just below 50F at the beginning of the climb. I wore two layers of wool. Not soon after, I began sweating and went down to just one thin layer of wool even with winds gusting to 20 mph. I imagine sweating even more if I was cycling. However, on a bike. I'd probably be wearing long sleeved jersey, long pants (no exposed skin) if the wind chill factor is down to 0C
Old 04-14-22, 07:39 PM
SpeedyBlueBiker
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Quoted: 170 Post(s)
Liked 391 Times in 226 Posts
For me, I like it warmer. 81F/27C is ideal with about 40% humidity. Sunny and no wind is even better. I'm fine with temps ranging between 70F/21C and 95F/35C.
SpeedyBlueBiker is offline
Old 04-14-22, 07:51 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3870 Post(s)
Liked 2,563 Times in 1,577 Posts
60-65°F and dry-ish is about perfect for me. Warm enough that I can wear a minimum of clothing, but not so warm that I need to manage a lot of sweat and drink more water.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 04-15-22, 01:52 AM
50PlusCycling
50PlusCycling's Avatar
Quoted: 544 Post(s)
Liked 783 Times in 399 Posts
If I have to wear covers over my shoes, it's too cold to ride. For me there is no upper temperature limit, cycling is one of the few sports which keeps me cool as I can move fast enough for the wind to cool my skin. The only bad thing is that when having to stop for a drink or at a traffic light, when the wind ceases the body temperature spikes, and can cause dizziness and fainting.
50PlusCycling is offline
Old 04-15-22, 06:13 AM
noimagination
Quoted: 364 Post(s)
For me, it's true that I've not experienced an upper temp. limit (for just a ride, not talking about performance here), and I agree that when it's warmer you just sweat more and experience more cooling thereby, even when it's humid. However, though my body is not unbearably uncomfortable, I have had trouble with (a) my feet, closer to the even hotter pavement, can get painful; and (b) my head, with the sun beating down, the part of my head under the helmet, can feel like it's being hammered by the sun.
Old 04-15-22, 06:46 AM
Bearhawker
Bikes: '23 Devinci Hatchet Carbon Apex1 '19 Norco Bigfoot 6.1 ,'12 Motobecane Turino (killed by dog crash), '12 Trek 3700 Disc
Quoted: 149 Post(s)
Liked 128 Times in 74 Posts
I prefer cooler temps for sure. Yesterday was ~10*C and it was awesome. I've ridden from below -20*C to above 30*C and I would take the the -20 over 30, but maybe not over +20. I hated every second on the 30*C+ ride. Every lungful of air felt like the air had been baked. do not want.
I also prefer no wind but living on the east coast, that's a vanishlingly rare event. Anything under 20 kmh is considered low. Worst I've commuted in was gusting to over 70 km/h (in the summer) and the worst I've ridden in was gusting over 100kmh (winter storm - took more than an hour to ride 5km... probably could have walked faster lmao)
"perfect" for me is when I'm almost uncomfortably cool for the first 5-10 minutes of riding - those are the days I over-heat the least for the rest of the ride.
Bearhawker is offline
Old 04-15-22, 07:11 AM
qwaalodge
Quoted: 211 Post(s)
True, it's a lot easier to deal with the cold, just wear more layers.
Hot can be ok but ONLY if it's DRY. But Hot and Humid is just punishment. I think NASA or maybe the US Army tried to invent active cooling systems for conditions like these for soldiers and astronauts. Bottom line is, it's a lot more complicated and difficult to keep cool in the very hot environments than trying to keep warm in very cold environments.
And the fact a lot more people die in heat waves than cold spells or blizzards reflects the vast difference in difficulties dealing with either situation.
Likes For qwaalodge:
