Pre 1900 "direct drive" bike - is this a unicorn?
Strong Walker
Likes For martl:
Quoted: 2337 Post(s)
Liked 2,821 Times
That is a first for me.... interesting, but no help for your question
bis spater
bis spater
Check on The Classic and Antique Bike Exchange. Someone there can probably ID it pretty quickly. www.thecabe.com
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
Pretty sure there's a couple of similar examples in the Pyror Dodge book, The Bicycle
Quoted: 1829 Post(s)
Liked 3,373 Times
The Museum of Science and Industry in Chicago used to have a good display of bike technology. I suspect some of it belonged to the Schwinn family collection. Back in 1994, the display included a bike of this type, where a few gears were used to transfer the power from the cranks to the rear wheel.
This collection might be part of the bicycle museum in Ohio (New Bremen?) now.
Steve in Peoria
Steve in Peoria
Quoted: 3015 Post(s)
Liked 3,793 Times
This is certainly not definitive, but I think it is a bit later, early teens, but pre WW1. The frame geometry, at least to me, is more along post 1900. I am happy to be corrected.
Bikes: '85 Le tour Luxe, Puch Mixtie, Raleigh Gran Sport, Mystery Machine
Quoted: 34 Post(s)
Liked 12 Times
Pretty wild looking, curious what are the downsides...? Pant legs, fingers? Flex between the gears? Better or worse than a shaft drive? How come turn of the century shaft drives weren't more popular on bicycles?
Quoted: 4722 Post(s)
Liked 3,036 Times
The subject bicycle is what is generically referred to as spur gear drive. In mid-1890s the bicycle industry experienced a boom. resulting in a plethora of new manufacturers. The increased competition led to increasingly lower prices and profits and by the very late 1890s market saturation resulted in an industry recession. At the time, the chain was viewed as the primary area for bicycle improvement and many manufacturers focused on developing chainless models, as a means to increase their market share.
The most common solution was shaft drive but spur gear drive was one alternative selected by some manufacturers. The example in the Museum of Science and Technology is a Caroll (see attached), who patented the bicycle spur gear drive in the USA in 1895 but were out of business before the turn of the century. Personally, I've seen about a handlful of surviving Carroll and there are other known manufacturers of spur gear drive bicycles including Humber and Hildick, so it's not a unicorn, though they are still very rare. The issues with spur gear gear drive were the extra weight and cost, which prevented it from becoming popular. It was primarily a novelty and had largely disappeared by the turn of the century, though there have been periodic attempts at resurrection.
To heck with that elegantly executed but dumb direct drive contraption,... I want to ride the bike!
Look at those frame angles! Look at that beautiful seat and bars! That thing looks great!
Liked 3,036 Times
Many bicycles from this era were capable of reverse. Freewheels were rare and the early coaster brakes weren't very effective, so fixed gears were the most popular configuration. There was also the cost factor. Upgrading to something like a New Departure coaster brake could cost the equivalent of a week's wages for a typical labourer.
Likes For T-Mar:
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 530 Post(s)
Liked 1,004 Times
Steve in Peoria
Steve in Peoria
THE BICYCLE MUSEUM OF AMERICA
Likes For Pompiere:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 981 Post(s)
Liked 631 Times
Presumably modifying a bike that old is a no-no, but in post #1's photos those two big gears are calling out for drillium.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For tiger1964:
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,980 Times
It does look like a little frame flex would result in a cog disengagement... not a good bike for sprinters.
Quoted: 3464 Post(s)
Liked 2,828 Times
Quoted: 4802 Post(s)
Liked 3,923 Times
Interesting! I bet the drive train efficiency is a lot better than a chain. (Well chains have a 130 year head start, but done right, that rig would have zero sliding frictional loss, just steel pushing steel.)
@repechage, they got it right. Looking from the drive side, ie that photo; pedals go clockwise so the pedal sprocket spins the middle sprocket counter-clockwise which spins the hub cog clockwise. No re-learning required.
Likes For Bad Lag:
Quoted: 18372 Post(s)
Liked 4,507 Times
I'm not sure there would be flex that would disengage the cogs without some critical damage.
Liked 3,036 Times
It looks like it has aluminum discs with steel ring gears. Rather high tech for the era. You'd be cutting and drilling for minimum benefit.
I'm pretty sure it has a solid right chainstay that jogs around the middle sprocket. Although there would have to be provisions for maintenance.
On the Caroll, the intermediate sprocket is held within a secondary rear fork that attachs to the rear seat stay. The drive side chainstay only extends horizontally as far back as the axle of the intemediate gear. At that point, it jogs upward to form the inner blade of the secondary rear fork. The intermediate rear gear uses an eccentric axle adjuster to provide proper mesh with the crankset sprocket ( I guess I can't call it a chainwheel). Proper meshing with the teeth on the rear wheel sprocket is then achieved by standard horizontal slots in the rear fork ends. See attached detail photo.
IIRC, the sprockets were quite wide, around 1/4" to 3/8. So, you'd need considerable flex to cause an issue. Besides, these weren't the types of bicycles to be owned by big, strong, flex inducing cyclists. The previously mentioned Hildick provided a solution, as the ring style sprocket allowed a straight, continuous, more rigid, chain stay to pass through the centre.
Likes For T-Mar:
Quoted: 981 Post(s)
Liked 1,844 Times
Forward-backward-forward...
-Gregory
Strong Walker
thanks for all the comments! As opposed to the Caroll design, this one has an "open" chainstay - the only connection between the front stump and the rear half is the axle of the big gear.
The owner has done research in german language collector forums and this seems to be one of 4 currently known, no one knows a thing about the manufacturer even though the large cog is stamped. Owner also believes the bike may have been "refitted" to race spec later (as in around 1910-1920) but is pretty sure about it being pre-1900. He has already restored several bikes of that vintage so i trust his verdict.
Quoted: 1856 Post(s)
Liked 664 Times
Steve in Peoria
Steve in Peoria
Liked 3,373 Times
There was some weird/interesting stuff in the museum in Chicago, and I suspect not all of were Schwinn products. Heaven only knows how big the collection actually was. Sometime after(?) my photo, there was a bike museum in downtown Chicago, not far from Navy Pier. Lots of bikes, which I assume all/mostly went to New Bremmen.
They seem to have been happy to show the collection off, at least based on the fact that they put part of the collection on display at the 19th RAGBRAI in 1991. I managed to take a few photos, back in the pre-digital days of photography.....
You never know what you'll see on RAGBRAI!
Steve in Peoria
Quoted: 1119 Post(s)
Liked 2,255 Times
