Tubes and bending
Tubes and bending
Hi all. New on this forum. Hope to get som tip regarding choice of tubes and/or bending.
I am currently exploring a design which require a slightly upward bend on the top tube and the down tube must have a «s» curve below the head tube and down to the horisontal line going back to the BB.
My Columbus tube supplier does not recomend bending top/down tube for their type og tubes. So, what tubes are used to achive bends and still preserving quality and frame integrety? I do have a proffesional/industry bending machine available but i do not have the equipment or experience to go through annealing and cool down procedures.
Any tip appreciated. Thanks.
Randomhead
Liked 3,696 Times
Welcome to the forum. What's an OG tube?
I think going with a non heat treated tube might work. I have only ever bent 4130 straight gauge though.
Randomhead
Liked 3,696 Times
Okay. I think that heat treated tubes and butted tubes can cause a problem. Although I'm sure some people have bent butted tubes. The problem is it might get expensive if they buckle
Columbus sells some tubes that aren't heat treated
Quoted: 18373 Post(s)
Liked 4,509 Times
I'm not sure what the OP has access to, but my tubing bender doesn't do particularly well with the ends of the tubes. I think it also distorts the tubing slightly.
Anyway, one could get a better bend with straight tubing and discarding a few inches at each end.
The plan is to set up a frame for EL crank and incorprate the battery into a Shwinn lookalike «tank» in the frame. I have alot of experience in fabricating gastanks and fenders for custom Harley’s so not conserned about that either. TIG and/or brazing should also be ok.
Quoted: 714 Post(s)
Liked 800 Times
Your best bet is to go with straight gauge .035" 4130 tubes. It's not worth saving the few grams that a butted tube will save and you will get reliable bends with the proper equipment.
Thanks! I just got a reply from Renoylds tubes also. They siggested their 631 tube. I guess the cost for a 631 is higher for similat 4130 thickness..
Randomhead
Liked 3,696 Times
The cost might not be higher until you start buckling tubes. Although if you are bending in the non-butted part, it might not be too bad. However, it's harder to successfully bend thin tubing.
Yes, but the 631 is plain straight gauge. I see that the cost for 1 3/8 with 1mm thickness is EUR22.52 pr meter or 19.44 annealed.
Randomhead
Liked 3,696 Times
I didn't know 631 came in straight gauge.
1 3/8 at 1mm is very thick, can you get .9mm? How much was the 631? Or are you quoting the price for 631?
Quoted: 103 Post(s)
Liked 144 Times
You don't say what the bike is used for so, that may change the following. As mentioned, 1-3/8 1mm 4130 tubing is VERY stout and heavy! You will have much better success trying to bend smaller tubes like 1" for the top tube and 1.125 for the downtube. If you're using straight gauge 1mm walled tubes for these the risk of buckling is much lower, they will be certainly stiff enough and the frame will be somewhat less of a boat anchor. The Schwinn Stingray/paperboy bikes used quite heavy gauge, mild steel tubing in small diameters which would make your job much easier.
https://www.flickr.com/photos/54319503@N05/
https://www.draper-cycles.com
Likes For duanedr:
Quoted: 103 Post(s)
Liked 144 Times
@DUANdr. Thanks. Good tip. The bike is for road use with EL crank.
The prices i mentioned are from the catalogue per meter in euros, and 631 is straight gauge per info from Reynolds but i’m sure they also du butted versions.
Yeah, I'm just saying that 631 is going to be pretty difficult to bend (it's very strong) and it doesn't likely come in thick walls like the old Schwinns. You'll likely go through a fair bit before you get satisfactory bends - be prepared. Bending tubing is one of the more difficult processes in framebuilding. Please post up progress and the tools you use.
Likes For lejo:
Quoted: 321 Post(s)
Liked 263 Times
I think that's a head-tube. Some of these are supplied very long and they're the only non-butted tubes in the Reynolds catalogue. Also those dimensions work out to a 34mm ID (which is HT sized).
Likes For guy153:
Randomhead
Liked 3,696 Times
Good catch. I think it would take hydraulics to bend a head tube. Or an incredibly long lever arm.
Liked 6 Times
Bending 4130 is pretty straight forward. You don't need to anneal it after bending. It CAN be done but is not necessary for many applications. I used to build roll cages for cars and annealing is not necessary. Even tube chassis cars and bikes are often not annealed. They are built jigs for accuracy and welded.
I might be a bit late in this discussion, but thought I would share some recent experience bending seat stays for the first time. They are straight gauge, but tapered 4130. Roughly 1/2" diameter at the bend area and approx. 1 mm wall thickness. I filled them with sand and bent them in my vise over the post (tried to post a pic, but am too new...). They came out reasonably well for such a low tech approach. There is a small flat spot on the inside of the bend. I will be trying a different approach on the next ones...
Likes For Devin Rickey:
Randomhead
Liked 3,696 Times
Quoted: 321 Post(s)
Liked 263 Times
Quoted: 103 Post(s)
Liked 144 Times
I'm not associated with the listing but something like this. Also, I grease the follower shoe and mandrel with a very thin coating of thick grease. You'll avoid that flat spot on the inside of the tube.
Ridgid No.398 1/2” Tubing Bender | eBay
Likes For duanedr:
