Dropout Angle Question
Quoted: 455 Post(s)
Liked 112 Times
As a newbie here I have a question. I think I know the answer but bare with me!
Rear dropouts are available in different angles am I correct in assuming
the angle is determined based on a line drawn between front and rear dropouts that is parallel to the ground?
Thanks!
Thanks!
Randomhead
Liked 3,696 Times
No, it's the angle between the rear stays.
Randomhead
Liked 3,696 Times
ummm, I found this
This video shows the dropout design changing right at the beginning https://www.bikecad.ca/dropouts_from_static_drawings
Quoted: 321 Post(s)
Liked 263 Times
ummm, I found this
Randomhead
Liked 3,696 Times
one of the commonly available track dropouts has a weird angle between the stays. I have seen a lot of bikes that look pretty awkward because of that. I suppose you want the axle slot to be horizontal, but I think I might fudge a little to get the interface with the stay to look better. It's interesting bikecad lets you play with that. You could also bend the stay.
I'm not sure how changing the angle with linear dimensions really works. It would be nice to know the angle though, since that's what dropout manufacturers tell you.
Quoted: 103 Post(s)
Liked 144 Times
That's interesting actually (although not the angle people are talking about). Shimano have a spec for the angle of the derailleur hanger-- it's meant to rake back a bit by a certain amount and there's a range they give for it. But I don't think it really matters. So long as it's basically pointing downwards.
I have used socketed track dropouts that didn't have an angle between the slot and the chainstay socket. This results in either having to bend the chainstay to achieve the horizontal slot while aligning to the socket OR ending up with non-horizontal slot. If the BB is high enough the slope of the slot is minimal but it's a compromise nonetheless. Bending the chainstays is the right approach - I just didn't think of it at the time. Angling the cut on the chainstay doesn't allow the plug to insert into the tube well so that's not a great option either.
https://www.flickr.com/photos/54319503@N05/
https://www.draper-cycles.com
Likes For duanedr:
Quoted: 4806 Post(s)
Liked 3,928 Times
The fix gear of my logo has custom dropouts at 11 degrees; a carefully chosen angle t\hat allows me to slide the hub anywhere inside the 2" slot, keep the brake pads on the relatively deep Velocity Areo rim and minimize frame height change. I use cogs from 12 to 24 teeth, sometimes both on the same ride. The 12 tooth slides the hub all the way back to the highest point in the slot and hence drops the bottom bracket the most. That cog is also used when I pedal around high speed mountain descent corners. I want all the clearance I can get!
And on the ease of wheel removal - the slot runs so far forward that a 25c tire nearly hits the seat tube using the biggest cog (to keep the chainstays from getting too long with the 12 tooth). Slot opens down at the front, not forward so removing the wheel is always easy. I dreamed this up, then learned after the bike was built that it was done in the 1930s (I don't know by who) and I've seen a modern day Shaw with them. A real joy for removing fix gear wheels, something I celebrate every time I climb and descend really big hills. (And I routinely leave the house in a bigger cog, warm up, then flip the wheel to do the bulk of the ride.)
Likes For 79pmooney:
Quoted: 1856 Post(s)
Liked 664 Times
Thanks!
Thanks!
Given the angle of the dropout slot to the horizontal (or vertical) is important, why would a builder use a vertical-style dropout and not install it in vertical orientation, or at least in consideration of wheel extraction? My 650b has them sloping with the opening toward the BB. The problem is that as the wheel with inflated tire is slid down for removal (the attachment is QR), the wheel has to move forward tending to close the gap between the tire and the chainstay bridge, and interference between the inflated tire and the bottom of the fender at the chainstay prevents the wheel from releasing from the frame. Some space is lost to the fender hang-down and the chainstay-fender attachment bolt. That space could have been conserved by making the D/O truly vertical at its front edge (and possibly lengthening the chainstays a few more millimeters), since the error is just a few millimeters. It's improved by minimizing the fender hang-down, but not enough that I can R/R the wheel without reducing air pressure. It's slightly better with 38 mm tires v. 42, but the stays and bridges could accommodate tires possibly up to 48 mm, though I'm not sure what the brake limitations are.
I can usually see where such a choice has a positive trade-off, but I just don't see it here. To be fair to the builder, this bike was designed in the 2011 time frame, before "gravelism" was pushing ever wider tires on an otherwise standard road/rando configuration. And the original owner (the custom customer) was an urban rider back then, not looking for a current gravel bike.
Randomhead
Liked 3,696 Times
Vertical dropouts almost always have the slot angled with the bottom closer to the bb than the top. The shimano dropout standard are drawn that way, but the angle isn't called out. I'm too lazy to trig it out, but the hole for the derailleur vs. the place where the axle sits is close enough that it probably requires the axle slot to be angled this way.
Quoted: 103 Post(s)
Liked 144 Times
Tandem Tom ,(and possibly lengthening the chainstays a few more millimeters),
I think a lot of times, we try to design and build right up against the edge to achieve a particular ride or other design goal and then we risk going over that line by a couple mm. The consequences are something the rider has to deal with for a lifetime. It's a good lesson. Those extra few mm in chainstay length wouldn't matter but not having them causes you frustration for the life of the bike.
Likes For duanedr:
Quoted: 4201 Post(s)
Liked 3,857 Times
It's this. The interface with the wheel, derailleur, and frame has to be in a certain place and orientation. The builder decides how long to cut the tubes. The builder of your bike cut them a bit too short or you're using a bigger tire than anticipated or you've added fenders that weren't planned. Bridges are very fiddly to get just right and perhaps as they were adjusting it into place they made a choice that the fit was perfect even if it was a few mm further from the BB than they designed. They decided to braze it in rather than risk adjusting it more and then having it be too short. There are a million little decisions like that. Could be a combination of all of the above - each contributing 1mm to a 4mm problem.
+1 here. A very good explanation of the decision flow chart we go through when making a frame. Beginning builders should read this a few times, as should any custom build customer too. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Randomhead
Liked 3,696 Times
Likes For unterhausen:
