Machining cold forged aluminum part.
Quoted: 753 Post(s)
Liked 735 Times
I figured some one here might know. I was wondering if it was practical to machine a cold forged component? Or are there additional stresses in a cold forged item that will cause warpage or weakness from cutting the "grain"?
The simplified example is If I have 2 cold forged bars. One is 5/16" and the other is 1/4" I would like to mill the 5/16" bar to 1/4" by removing 1/16" from one side. Will I end up with 2 bars with the same "strength", or will the modified bar be "weaker" or prone to warping?
Randomhead
Liked 3,687 Times
If I had a forged flat bar I would machine it in stages because some stresses are likely to be released during machining.
What exactly do you want to do?
Quoted: 753 Post(s)
Liked 735 Times
I'd like to thin and reshape a crank arm. I've got a Shimano FC-6207 left crank. It looks to me that the Dura Ace FC-7400 is made from the same forging and is machined down a bit and fully polished. I'd like to thin the FC-6207 left arms front face and contour the back to match a Ritchey Logic right side. I'd be using hand files and abrasives.
Randomhead
Liked 3,687 Times
I imagine you would be okay. Like any aluminum under cyclic loading, you should make sure your polishing is good.
I went looking for drillium examples of that crank and failed to find any, which surprised me a little.
