bar tape?
bar tape?
Yep: old question new day.
So what makes a bar comfortable on a long tour?
That discount stuff I bought is just that, discount stuff.
Got any ideas?
Got any ideas?
Slow Rider
Some ideas:
1. use tape or grips that absorb shock and vibrations (dampens input from the wheels)
2. double tape bars
3. use gel pads under tape
4. raise bars to take more pressure off hands
5. title saddle back a bit to take more pressure off hands
6. try different handlebars
7. try gloves
8. rotate hand positions during ride
9. stretch fingers and hands against handlebar during ride
10. stop and rest at intervals
Sometimes it is not possible to eliminate all pain, so try to minimize pain.
2. double tape bars
7. try gloves
Since you've mentioned bar tape I'll assume you're talking about drop bars.
I do most of my riding with my hands on the break lever hoods, so padded bar tape isn't all that important to me. I also wear padded gloves. As far as comfort goes, remember that your hands adsorb a lot of road shock and vibrations, so anything to diminish that ( larger tires for example ) will go along way to make your life in the saddle a lot more comfortable.
juneeaa memba!
Bikes: Crap. The box is not big enough...
Quoted: 13 Post(s)
Fizik makes a gel pad kit that installs under the existing tape. I put a set n Patti's bike today. It was 18 dollars on line. I have been using the pads on my bike and have had much less grief than Patti...
You can adjust the ratio of butt load to palm load by playing with seat aft and forward position, or changing stem length and height.
You can live with a numb butt, but Numb and tingly hands can be a precursor to more serious injuries. Favor your hands.
Quoted: 138 Post(s)
Liked 17 Times
The more hand positions you can ride with, the better. I've made and installed some homemade aerobars that give me two extra hand positions and several mount positions as well for things like, cyclecomputer, headlight, video camera, cue sheet, water bottle, etc. When I hold on to the aerobars by hands don't have to do much holding, it's my elbows that has all the pressure on the bike not the hands. Not only does it help to keep my head up better but it also takes the pressure off the hands.
Yeah, I know I'll still get numb hands when I climb since I stand up to climb most of the time and put all my weight on the hands.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
Never tried the good stuff. The discount stuff I used last was really discount: actually recycled from the girlfriend's bike when she insisted on pink tape over the black it had. Felt like all the other cheap cork tape out there for $7 a set. Worked just fine for my hands, though. Before that, though, I ran shakedowns for about 60 miles with nothing but hockey tape, and still no issues. All my bikes now have essentially the same stuff I hated when I first got drop bars.
What worked for me was padded gloves (again, just a basic set), and perhaps most importantly, core strengthening and playing with handlebar and seat positions to reduce the weight I was trying to support on my hands. And, as others have said, moving hands regularly. I don't stay in any one position more than two or three miles, and generally am moving my hands far more than that.
Sunshine
Quoted: 10899 Post(s)
Liked 7,390 Times
Cinelli Gel tape.
I love the stuff as its gel backed and not tape backed so its easy to remove and adjust. And it feels great to me. Plenty of cushion but not so much that I cant feel the bar. Many hand positions, as has been discussed, is most important to me though. The bars I use are full C bend with ample room on the ramps. That way, I have the tops, ramps, hoods, and drops to use.
Quoted: 226 Post(s)
Liked 45 Times
the cheap solution that is really cushy....
Wrap the handlebars with window weather stripping foam from the local hardware store. Sticky on one side. Wrap gorilla tape over the top of that. Looks ugly but super effective.
Quoted: 1324 Post(s)
Liked 927 Times
I have short fingers compared to the width and length of the palse of my hands. Thus I don't like thick bar wrap tape. Back in the 1980s it was common to cut strips from old inner tubes, wrap the bar with that and then apply cotton tape over the rubber. I sometimes do the same thing but I use quality (Renfrew brand) hockey tape instead of the harder to get cotton bar tape. The hockey tape lasts and is thin so it doesn't thicken the grip diameter too much.
Cheers
Cheers
Quoted: 671 Post(s)
Liked 49 Times
Started using Fizik gel strips recently & they're very comfy & easy to install. They give cushion where needed vs bulky bike gloves.
aka Timi
bar tape?
I made the mistake of buying Lizard Skins bar-tape a few years ago. Horribly expensive ... But I can't go back... Love 'em
Way back .. 'grab on' fat sleeves, of dense foam rubber, on the upper of drop bars , with cotton tape over them.
What do you do about the hoods though? I taped my bars today over the existing tape, and it's nice enough, but I spend 95% of the time on the hoods.
Careful raising your bars too much though, tends to take pressure off your hands and on to your butt....which can influence saddle choice.
Fair enough. On the hoods just feels like a good position for me. Only tend to use the drops if I'm really going for it. Top bar bar helps to briefly relieve some pressure now and again. With the double tape it's quite nice now.
Nashbar deluxe cork tape is pretty good for $6. I've used it 3-5 times over the years. I suppose there is better tape, but I'll never know since I'm not willing to pay much more than this for tape.
Before wrapping bars, I put a strip of tape on the handlebar tops and hoods, secured by 3M Super 88 electrical tape, plus a short strip across my brifters so that it will be hidden by the rubber hood. Then wrap as usual.
Bikes: Trek 520 total custom build, Cannondale Mountain Tandem, Oryx Mountain Bike
Quoted: 61 Post(s)
Liked 6 Times
I used Brooks bar tape last cross country tour, and non padded gloves. very comfortable.
If you spend 95% of time on the hoods I think you need either a) work on flexibility or b) raise your bars, but maybe you have some unique bodily limitations that don't allow for it. I think you should be comfortable on flat ground in the drops on a touring bike for an extended period of time. That is the whole point of having a drop bar after all.
Back in the day it may have been the case but with todays compact drop bars the hoods are the intended hangout point while the drops are for control and aerodynamics.
If you look at the pro peloton, most riders use hoods most of the time and swap to drops when the situation so dictates.
Back in the day when bikes didn't have functional brake hoods and had those horrendous deep drop bars even the pros spent a lot of time in the tops, and bars were often level with the saddle.
With today's bike design, the bar is placed so that the rider uses 95% of their time at the hoods as bars are lower than they used to while still having the drops in the same place (compact bars you see)
So no, if not doing a TT, one should not ride extended periods in the drops and if one does, the bar is likely too high
That's just not true..
https://roadcyclinguk.com/gear/buyer...wzXLRHAfbLr.97
“compact bars keep you higher and work well for people who are less flexible, or aren’t racing and therefore don’t need to be chewing the stem”
If you look at pro-tour rider, their position on the TOP of the hoods is likely to be lower than most touring riders in the DROPS – so not comparable at all. Seems like you are getting into frame design, current racing frame trends (short head tubes) and how to make an average guy fit on one.
I was offering my opinion to this point: if you are going to use drops make sure they are setup to be “able” to use comfortable (if required) for extended periods of time in them. If not, may as well get trekking bars….which is a 100% legit solution if it works.
Besides, todays touring frame are much closer to the ‘racing’ frames back in the day.
Liked 81 Times
Now that one of my bikes have cross top brake levers as well as the regular ones, I spend more time right on the tops, too. Really convenient in cities.
The whole point of having drop bars is to have multiple positions available at any given time. In reality, you could cut my bars off past my brake levers, and I'd rarely notice the difference. Only time I am in the drops is when I get a boost of wanna-go-fast or headed into a heavy headwind. I don't even really take ability to use brakes in drops into consideration when placing controls anymore.
Careful with lever position though, drops have their place on descents offering more control and much better braking.
