comfortable inflation vs. manufacturers recommended range
Reading a lot about best inflation values for tires, I wonder how much the manufacturers range which is expressed on the tire itself should be adhered to. Do I disregard this range and just experiment around to find what's most comfortable? I'm well aware of the danger of pinch flats if I go to low.
Try the pressure calculator at zipp.com. It allows for tire width, internal rim width, tubed or tubeless, rider weight and type of road.
Likes For DaveSSS:
Quoted: 6191 Post(s)
Liked 4,807 Times
You want to be somewhere between the recommended max inflation pressure and the lowest PSI that does not result in pinch flats for the hazards you might encounter during most of your riding on that bike.
I let my legs, my comfort and my data collected by my bike computer tell me what that pressure is. Online calculators might be right. But they haven't been right for me.
They for certain might be a good starting point. Then after keeping your tires at their recommended pressure for 6 -12 rides, change it up or down a few PSI and see what you think after 6 - 12 more rides. Judge by both by perceived effort and by how well your bike computer tells you you did on rides of the same routes.
Likes For Iride01:
Likes For DonkeyShow:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1942 Post(s)
Liked 1,464 Times
Likes For SoSmellyAir:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,531 Times
Everything I see on TV says inflation should be much less than it is.
Liked 1,464 Times
Past performance is not indicative of future results. Good luck
Why are you scared of going downhill at 35 mph with your tires apparently over-inflated by 2 PSI? And which "max" are even you referring to? The maximum pressure for your wheel, tire, or tube?
Quoted: 3948 Post(s)
Liked 7,291 Times
I thought everyone knew, inflation is on the rise.
Likes For tomato coupe:
Quoted: 2700 Post(s)
Liked 486 Times
The "max" pressure rating on a bicycle tires about half of what it takes to actually fail. You wouldn't ever be close to that, play around as much as you want. Cubewheels was claiming that the rim could blow out at high pressures, but idk if he is to be trusted and thats not a failure of the tire anyways. Its like how ladders are normally rated to 250 lbs but routinely take loads of 400+. also tubes don't have a max pressure lol..
The current consensus seems to be that wider tires with less pressure are preferable, but that has changed over the years, back in the day people were trying to get narrower than 23s. Who knows what people will be doing in 20 years
Quoted: 6958 Post(s)
Liked 10,959 Times
Likes For Koyote:
Liked 486 Times
There are some benefits, for instance I have a commuter bike that mainly sees nice tarmac but has a 37 knobby up front. When I pump it up to 100 psi the knobs aren't in contact with the road when going in a straight line. sucks in corners but its great for rough terrain and potholes
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
I don't exceed the max. recommended pressure - just to be on the safe side.
(having said that, I'm far from a super-heavy rider so I'm yet to see a tyre that squats much when I upload it to the max recommended pressure)
And I completely disregard the lowest recommended pressure.
(though, I'm usually heavy enough to not dare to go below that limit in order to avoid any pinch-flats)
I aim for about a 10 to 15 % drop in tyre height when I sit on the bike for the rear - and I use that same pressure for the front (explained with pics and in more detail here - optimal tyre pressure).
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
I hope he can be trusted. I'm testing new cog spacers made from a composite of newspaper, toilet tissue and old lottery tickets this morning.
Likes For Chuck M:
Liked 10,959 Times
Likes For Koyote:
As long as you have a cell phone and a friend or partner who’s willing to pick you up, go as low or as high as you want! I’ve just gone up or down 5psi at a time for a few rides to see how things feel, and eventually settled on a range that I’m comfortable with, which is about 78-85psi on my effectively 32mm front (28mm Conti Ultra Sport 2), and about 90psi on my effectively 28mm rear (25mm Conti GP4k - my last one). Both are higher than is ever recommended, but it’s what I like, and isn’t that what matters?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Quoted: 4393 Post(s)
Liked 4,837 Times
I find the Zipp/SRAM online tyre pressure calculator below the most useful guide, in addition to what the manufacturer advises
https://axs.sram.com/guides/tire/pressure
Liked 4,837 Times
Well in addition to "what you like", there are also safety factors to consider. For example if you are using hookless rims and you exceed the maximum pressure then you could have a sudden blow-out. So at the very least you have to know what the safe limits are for your particular tyre/rim combo.
Liked 4,837 Times
Fair enough, though I would hope people would stay within reason with regards to the min/max. I wasn't suggesting putting 200psi on a 32mm tire mounted to a hookless rim, but that within the min(rim, tire) and max(rim, tire) combo, you can experiment. And if you pinch flat while running tubed... well, that's what the cell phone's for.
Yes, of course you can experiment within the stated min-max range for your tyre/rim combo. It was the bit where you stated that you prefer to run your pressures "higher than is ever recommended" that prompted my warning. But as long as you know what the safe upper pressure limit is then it's your call.
Now, it may also be because the gauge on my Serfas pump isn't accurate, or maybe I'm just so used to riding on 23-25mm tires at 100-110psi for so long. But within reason (read: within the limits of what your tire/rim says), I say every rider should just go and experiment and see what makes the most sense to them - and different people will optimize to different criteria - personal comfort, perceived performance, time over a certain Strava segment, etc. After all, the calculators really are just recommendations.
Likes For aliasfox:
