Titanium rear derailleur hanger
Quoted: 790 Post(s)
Liked 348 Times
A friend of mine got a second-hand carbon-fiber road frame for pocket-change because it was cracked by the bottom-bracket. I told him to JB-weld it and try and have some fun with it, but he is not that adventurous. I think the carbon-fiber bikes are throw-away items, you will not see fifty and sixty year old carbon fiber vintage road bikes in the future that can be ridden like fifty and sixty year-old steel bikes can be ridden today as the day they were made.
I believe the only perfect bicycle frame material known is steel. The rest are compromises, jewelry or marketing tools.
Quoted: 1106 Post(s)
Liked 1,197 Times
I agree carbon-fiber is "frippery". Every now and then the manufacturers of consumer goods have to have something new to market to the public so they can get them to buy everything all over again, and most of the time there was nothing wrong with the previous generation of goods, in fact many older consumer goods are much better in many ways than current items. As time goes on consumer goods are being made that do more for those who made them than for those who buy them.
Likes For Camilo:
Quoted: 645 Post(s)
Liked 797 Times
Weight - Ti and CF certainly trump steel here - Al also, I imagine. You can certainly make light steel frames, but I think to rival the other materials weight wise, you're looking at ever more exotic and expensive thin-walled steel tubing, at which point longevity might become an issue, and repair becomes more of a specialist enterprise - not everyone can successfully weld thin steel. From your earlier posts, you seem to dismiss weight as something that should only matter to professionals, but weight matters, period. Why would I want to haul a boat anchor up a hill?
Ride quality - although I'm a big Ti fan, I'm skeptical about the "magic Ti ride" - frame geometry and tires easily trump frame material in determining ride characteristics. I don't see steel as a material having any more "magical" ride properties as Ti.
Flex - certainly Ti as a material is less stiff then steel, but the stiffness of the material is again trumped by tube diameter and frame design - you might have had a point about the flexiness of Ti as a negative if all frames were built identically, but obviously they're not
Corrosion resistance - no contest - steel is the most sensitive of the lot, although I think this is more of an academic weakness. For a steel frame to suffer fatal rusting, it would have to be seriously abused and/or stored outside. No steel frame of mine has suffered more than slight surface rust at paint chips, and I certainly didn't baby any of them. Still, not having to worry about the finish of a bare Ti frame is very convenient.
Longevity - Steel is real, but I think so is titanium. Both materials have excellent fatigue resistance, Ti has better corrosion resistance - but barring trauma or abuse, a well-made steel or Ti frame should outlive its owner. Of course, I can take a scotchbrite pad to my 22-year-old ~70,000-mile Ti frame and have it looking literally like it just left the factory - can't do that with painted steel. Yes, there are rideable 50-60-year-old steel frames out there, but honestly, they're sh1te: (i) they weigh a ton, and (ii) they're less compatible with modern componentry that has made cycling so much safer and more efficient over the decades. By way of comparison, I have a 50-year-old car that's a blast to drive and fun to tinker with, but by almost every objective measure, the cheapest modern Korean econobox is a faster, safer, more reliable and more comfortable car. "Longevity" isn't the be-all and end-all - sometimes things just need to move aside and let progress have its day. At this point, we don't know about the longevity of CF (again, barring accidents or trauma) - there's no reason to believe that a quality CF frame, looked after, won't last for decades - we just don't know yet.
Cost - getting harder to gauge - CF is getting cheaper - I imagine Ti is also. Certainly cheap steel is out there, but if you want to compete with good CF or Ti in terms of weight and performance, steel is becoming boutique and expensive.
The "X" factor/"tradition" - a nice steel frame is a thing of beauty - it's traditional, it rides well - if I could pick any frame, cost no object, it'd probably be a Battaglin Portofino or Colnago Master - both steel. But cost is usually a factor, and these puppies ain't cheap.
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
Lighter than steel and far more corrosion resistant.
More corrosion resistant than Aluminum.
More durable in most applications than carbon fiber.
More bio compatible for medical implants than surgical stainless.
Far less fatigue failures than aluminum or steel making it ideal for components that face repeated stress
Strong as steel at 40% of the weight (depending on the alloy)
More erosion/cavitation resistant than steel
can flex and bend quite easily in certain applications making it less likely to crack or break.
Listen .... I never said Ti was the best material for bike frames. You seem to be of the mind that steel is the only thing that should be used for bike frames. Fine I disagree. I have had steel, Ti , Carbon and Aluminum. They all work fine for me. I also tried to stick to answering the OPs post and not crapping all over everyone else's thoughts on different frame materials. Maybe make your own thread about "steel is real" or some such drivel. Treat this thread like an A to B thread and C your way out of it.
Klaatu..Verata..Necktie?
Quoted: 10243 Post(s)
Liked 11,596 Times
Ugh ...if I must.
Likes For genejockey:
Quoted: 790 Post(s)
Liked 348 Times
Ugh ...if I must.
Quoted: 790 Post(s)
Liked 348 Times
The same type of accident that would destroy the hanger on a steel frame would also destroy the hanger on a titanium frame. Steel is "tough stuff" too. How does it feel to have your imagination expanded?
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 460 Post(s)
Liked 539 Times
I have three Ritchey steel frames and three Lynskey titanium frames. The Ritchey frames all have fixed hangers, while the Lynskey frames all have replaceable hangers. None have been a problem.
Likes For DangerousDanR:
Liked 1,197 Times
None of those addresses the question the person who started the thread asked about derailleur hangers, and they are weak at best period. Titanium is hard and expensive to repair, Steel is easy and cheap to repair. So unless you can get a Titanium frame with a replaceable derailleur hanger, Steel wins. Again, titanium is for the pro, or those who are looking for jewelry, not a bicycle.
Liked 11,596 Times
"Titanium is for the pro"? What silly elitist hogwash. If something about titanium is useful for "the pro", it's also useful for the amateur.
Quoted: 790 Post(s)
Liked 348 Times
I said it is for the pro or it is jewelry. Which means if you are a pro then a titanium bike might actually be worth the cost, and if you are not a pro then you are not buying it for any practical reason, but as jewelry for your ego. But I guess the only way you could attack what I said was to alter what I said, so no gold star on your forehead today.............
Liked 11,596 Times
Quoted: 790 Post(s)
Liked 348 Times
Lighter is only practical if it is cost efficient, and titanium is not. Especially if the person who started this thread crashes or chain-sucks his hanger off the bike and has to find someone to competently repair it. In most cities in the USA there is not going to be anyone that will be able to do it, which means driving or shipping the frame far away and ending up maybe with as much as you paid for the frame to repair it. Whereas most any city in the USA is going to have a competent steel fabricator. A pro will not even have to pay for his titanium frame, and if it is crashed it will not cost him anything to replace it. Saying that a non-pro will benefit from titanium frames like a pro getting their bikes for free and making tons of cash for riding because the frame is a little lighter is nonsense no matter how slow or fast you say it. So go pour yourself a nice big cup of DUH.
Liked 11,596 Times
Liked 1,197 Times
As for your OPINION that there's no reason for a mere enthusiast to have a titanium bike other than ego, jewelry, whatever. I bow to your superior knowledge and values and will be ashamed of my own in the future.
It's refreshing though - we haven't been entertained by an arrogant steel devotee for a while. Thanks for that.
A
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
I did it for the sheer fun of it. I think it rides way better than my old aluminum ...maybe it rides like steel. I wouldn't know because I didn't want a steel frame. I bought what I wanted. Do I buy Italian racing motorcycles because my ego demands it or because I like the way they look, sound and ride.
Now this thread has devolved from the OP asking and getting answers about his question to you essentially saying ... if its not a steel bicycle you are doing it for your ego and its inferior to steel blah blah blah.
Here's a thought. Stop it.
Liked 11,596 Times
You have certainly not expanded my imagination or anything close to it. You seem to be utterly unable to understand the concept of people buying things because they like it. Did I buy a 21 year old used Ti frame off Ebay and throw Dura Ace on it and smile because I needed to do it for my ego ? According to you that would be the only reason since I am not a pro. I could have got the same level of functionality out of components thousands of dollars less. I didn't even need another bike FFS.....but I always wanted a Ti bike and now I have one. Yay for me ....I think my ego is unaffected since I don't ride in groups and I don't ride to impress anyone since I am slow and kinda old.
Quoted: 460 Post(s)
Liked 539 Times
I bought my first Lynskey for a winter commuter. No worries about the mixture they put on the roads here in the winter.
I didn't want to ruin a nice old Ritchey steel frame, so I bought Ti.
Quoted: 4742 Post(s)
Liked 3,860 Times
My experience with aluminum in general is that it doesn't like being bent twice. Derailleur hangers get that second bend every time the bike falls over and the hanger straightened again. I'm not saying it will break after that second bend, but it has been compromised. Might well become a JRA failure some future year.
Liked 3,860 Times
So you just have to look at the chances of you destroying the hanger vs. the cost of having it repaired vs. how much good a titanium frame will really do you. I don't think the weight saving of a titanium frame, and it's cost, is going to make any difference in anyone's life unless they are a pro-cyclist making a living at it, for anyone else it is just jewelry.
Likes For 79pmooney:
