R55c brake shoes
R55c brake shoes
Ordered some shimano brake shoes and when I got them I noticed they said "ceramic rim only". Never noticed this in the info when I ordered them, my questiom is, does anyone know if these will work on aluminum rims? If the braking performance will be poor or they produce excessive wear on the rim I don't want to use them.
Quoted: 6191 Post(s)
Liked 4,807 Times
I wouldn't use them on aluminum rims. The manufacturer doesn't want you to use them on aluminum rims.
Go back and check out where you bought them and see what their description said. Shimano makes several models of the R55c and you have to pay attention to the letters/numbers after the R55c or better yet, the exact part number.
WP-Y8FA98150 is for rims made for ceramic
WP-Y8FA98132 is for aluminum rims.
Probably other part numbers in the realm of R55c too.
Call or email your vendor and see what you can do to exchange them.
Welcome to BF
Welcome to BF
Likes For Iride01:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Clark W. Griswold
Quoted: 4347 Post(s)
Liked 3,984 Times
Use SwissStop black or BXP pads some of the best pads out there. The SRAM pads at least for a while were SwissStop black. Their King and Price compounds are for carbon rims so avoid those. You could also do quite well with Kool Stop Dura Type pads just stick with Black, Salmon or Dual Compound. Green is for Ceramics and their carbon pads are well for carbon. They also make the thicker Dura2 pads and those add a Triple Compound and pink color to the mix as well as some other pads for carbon.
I would not use Ceramic pads on non-ceramic rims as the packing says "Ceramic Rim Only".
I typically will only use Shimano pads in an emergency and keep some as backups usually for friends who need pads as I typically use SwissStop or KoolStop on all my rim brake stuff. Not that they are bad pads they are fine but the Stops are just better. The Shimano is a B and the Stops are A to A+
