Show me your 70's vintage Raleigh International
#52
Not entirely sure of the year in this one. Acquired as a bare frame and built up with a few Campy parts I had in the shed, and the balance from a donor ‘76 Centurion Semi-Pro. It looks surprisingly coherent and rides very nicely. It’s my brothers bike now.
#53
Friendship is Magic
Bikes: old ones
Quoted: 26393 Post(s)
Liked 10,367 Times
#54
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
His 1974 (front) and hers 1975 (rear). Neither in original configuration, but very functional set-ups,
#55
Quoted: 85 Post(s)
Liked 74 Times
I bought this as a frameset on Ebay at a relatively low price due to some issues. The chain stay cable stop was snapped off, so I found one that bolted on, and the seat tube would not allow insertion of a 27.2 post, so I carefully re-spread the ears and used a flexible reamer to clean up the seat post cavity. I was planning to install barcons and centerpulls, but I found the frame had been cold-set to 130mm and drilled for recessed mount brakes, so I installed some Tiagra STIs, Tiagra long cage RD and some long reach dual pivot side pulls. I’ll probably switch out the Technomic stem - I’d like a little more saddle to bar drop and the Technomic can’t be lowered any further on this 21.5” frame. Sugino compact double crank. It will accept 32mm tires, but I have 28s on it right now. It lacks the class of the more traditionally equipped Internationals above, but It’s a great, comfortable ride.
Likes For Whit51:
#56
Bikes: Specilized Roubaix, 71 Raleigh Professional, 74 Raliegh Intl, 74 Peugot PX-10, 82 Puegoet PSN, Olmo Competition , Schwinn High Sierra & Others
Quoted: 42 Post(s)
Liked 59 Times
Riding this always makes me happy:
Likes For LarryBSky:
#57
This is my 1974 International, the nicest bike I have ever had. A previous owner converted it to 27" clincher wheels using Campy NR low flange hubs and Weinmann rims. I removed the Campy rear derailleur and pedals, bagged them, and set them aside for safe-keeping. I don't own a pair of shoes narrow enough for those pedals! The current derailleur and levers are Huret Success.
Likes For daka:
#58
Bikes: Fuji Touring Series V 1985, Motobecane Grand Touring 1982, Specialized Stumpjumper 1993, Raleigh International 1972, Raleigh Grand Prix 1972, Kuwahara Count 1983, Trek Cirrus 1987, Shogun 2001 1983, Cannondale SM700 1990
Quoted: 90 Post(s)
Liked 174 Times
Front brake pads can’t go low enough but it has functioned well for over 100mi. It’s getting a mtb shifter to access all the gears and also an 11 speed 11-36 to get more speeds, and possibly one of those long reach tektros but those guys are expensive. Any other ways to fix the brake rub, other brake options?
Happy to finally post it here; this thread has been an inspiration.
Update: replaced front and back brakes with 750s, new cassette let me lose the extender bracket
#59
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 321 Post(s)
Liked 688 Times
Kind of a dark photo but plenty of brake reach in back.
#60
Quoted: 837 Post(s)
Liked 1,080 Times
What can one expect in the ride between an international and a super course? I’m imagining the SC is a little sportier and the international feels more akin to a tourer, but ive seen the ride of both described similarly.
#61
Other way around, in my experience. The International's wheelbase is shorter and it is the better part of two pounds lighter. In a straight line on flat ground it is difficult to tell the difference between the two bikes, but on a curvy descent the International is a thoroughbred.
#62
“Senior” Member
Guess i missed this thread?
..,as i have had this bike a while. Really nice barely touched bike when I bought it and even came with the original bike box.
It presents very well. The downtube decals are a bit tender though and i may have harmed one wiping down with Pledge?
Likes For obuckler:
#63
Quoted: 1827 Post(s)
Liked 3,367 Times
The paint is only slightly more durable.
My assumption is that they were intended to look good on the showroom floor, and not much longer.
... on the other hand, it is possible that other bikes of the era were even worse.
On the plus side, I've found it to be relatively easy to use a paint brush used for models, and some touch-up paint, to get the chipped decals looking quite good.
Steve in Peoria
#64
Quoted: 7346 Post(s)
Liked 2,452 Times
So your suspicion is not correct, at least in my experience, that the Super Course is sportier. The designs are close enough to each other.
I took a 32-mile ride through hilly country yesterday on my Super Course. I now have it equipped to be heavier than original. It did not feel slow. It weighs 30 lbs (13.6 kg) with nothing strapped onto it.
Super Course:
International:
Likes For noglider:
#65
“Senior” Member
my experience with Raleighs of this era is that the waterslide transfers used for decals are extremely fragile. They sit on the surface of the paint, just waiting for something to knock them loose.
Steve in Peoria
Steve in Peoria
AND referencing the question about ride comparisons between the International and a Super Course: i have two 74 Internationals and a 76 Super Course. To me they all ride and fit similar with the Internationals being livelier and lighter feeling and the SC feeling plusher.
I like all my rides for different reasons.
#66
Quoted: 3804 Post(s)
Liked 6,643 Times
I currently have two Int'ls and zero Super Courses, but I've had plenty of both over the years. As I think about it, I've never had the two frames built up the same way, so that makes comparison difficult. I tend to set Super Courses up with internal gear hubs or as single speeds, given the lack of a derailleur hanger. I've also found that frame angles and BB drop can vary quite a bit from build to build for both models, which makes comparison that much more difficult. Still, the Int'l is full double-butted Reynolds 531, and the Super Course (except for the last year or two) were 531 main triangle only, so the Int'l will certainly be lighter.
#67
Liked 3,367 Times
on the subject of comparing Internationals to S.C.'s or other bikes... there is first the task of describing the characteristics of the different versions of the International.
I'm no expert, but I have owned a 1971 International ("coffee" colour) and currently own a copper coloured 1974 International.
The most obvious distinction in the geometry is the longer chainstays on the '71 model.
I think(?) the seat stays were a bit narrower too, but I never made any measurements.
There is a difference in the curve of the fork too. The '71 fork has a tighter radius on the curve.
I recall the '71 as being more flexible. Hard to say how much of this was due to the frame and how much was due to being ridden as a fixed gear.
Pics...
Here's the '71, complete with wrap-over seat stays and the fun "anniversary" head badge.
and here's the '74.
Steve in Peoria
Pics...
and here's the '74.
Steve in Peoria
Likes For steelbikeguy:
#69
Quoted: 938 Post(s)
Liked 2,923 Times
1971.
Same bike, different days. First I built it in the spirit of the original, then it got rando-ized with a modern drivetrain, then it went IGH townie commuter/grocery hauler, it's current incarnation.
#70
Quoted: 3464 Post(s)
Liked 2,827 Times
Clement Strada 66... what a great tire.
#71
Liked 2,827 Times
Those with the Capella lugs were so attractive.
Mine is that color but Nervex.
I like the assembly but I really ,really want to hack saw off that brake bolt.
that bottle cage held with Rivnuts?
#73
Disraeli Gears
if you look through this thread you’ll notice that everyone who has the Weinmann 610 calipers nearly has this issue. I was able to get mine to just barely not rub the tire in front. You could try switching to a Weinmann 750 caliper if yours absolutely won’t reach. That’s what I had to do in back. That would give you a longer reach and it should be affordable. It will also lookJust the same. See my setup.
#74
Liked 6,643 Times
My impression (and I think the catalogs support this) is that Int'ls came stock with sew ups, i.e., 700c wheels. That said, my '74 takes shortish reach brakes front and rear!
#75
I concur with @nlerner that Internationals were shipped new with tubulars. In the early '70s, wire bead tires were considerably heavier than modern clinchers and there was a big difference in performance.
That said, my '74 International has 27" tires/rims, has short reach Weinmann 610 centerpulls front and rear and the pads are in the center of the adjustment slot, almost as though it was designed that way....
In contrast, the tubular-equipped Raleigh Professional Mk 1 that has recently appeared in the garage has the longer Weinmann 750 in the rear and the pads are nearly to the bottom of the slots - go figure.
