Trash Panda Works “Special Projects”
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
I have a titanium spindle Italian threaded O.M.A.S bottom bracket kicking around somewhere. Gimme a sec to measure it...
EDIT: It's 112mm from the vertical face of one side of the spindle to the vertical face of the other. It's... kinda... symetrical? One side is a mm longer than the other.
I'm assuming it is ISO, as I don't think O.M.A.S. made a JIS tapered BB.
Sugar "Kane" Kowalczyk
Bianchi Goddess
Liked 2,923 Times
Is the Unabomber or small parts shipping
The Unabomber sent me a little holiday surprise.
Mad Honk was nice enough to send me a bottom bracket. I’m not sure it will work being JIS taper and 1.5 mm longer on each end but I’ll give shot.
PeopleCode delaminator
Quoted: 1872 Post(s)
Liked 692 Times
I went with this for my build: https://www.amazon.com/Campagnolo-11.../dp/B01IS1ZJUS
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Quoted: 586 Post(s)
Liked 612 Times
The minute I saw that color it reminded me of my Waterford 1200 road bike. I am looking forward to more progress on the bike(s). Green and yellow rocks, by the way.
Likes For TugaDude:
Quoted: 1303 Post(s)
Liked 1,908 Times
BG,
I went to the archives and found this specimen that may work for you. Campy Italian threaded NR thick cups, 70ss spindle, with the following dimensions. 113.1 total spindle length - 69.5 lock-ring to lock-ring - 18.4 drive side offset and 19.4 off drive side offset. It is not totally symmetrical but pretty close. I could install it and check for chain line clearances using an NR set of arms. Lemme know, Smiles, MH 812-336-3283
Took a while to get pics. I had to work on the War Department's car this afternoon. This is what I have found so far. I doubt I can find anything else even if I dig deeper in the trunk.
Likes For Mad Honk:
Quoted: 2337 Post(s)
Liked 2,820 Times
what sheldon has to say on iso/jis
https://www.sheldonbrown.com/bbtaper.html
places it farther outboard on the spindle.
Conversely, if you install a J.I.S. crank on an ISO spindle, it will wind up about 4.5 mm farther in than it would on a J.I.S spindle of the same length.
Theoretically, ISO cranks should only be used on ISO spindles, and J.I.S. cranks only on J.I.S. spindles.
In practice, you can very often get away with mixing these sizes, as long as you select a spindle length that gives the desired chainline.
Taper matching was fairly important back in the day of loose-ball cup-and-cone bottom brackets, because these required regular maintenance/overhauls, and this required removal of the cranks. Every time you remove and re-install a square-taper crank, the hole in the crank is liable to get very slightly larger.
This was particularly an issue when using J.I.S. cranks on ISO spindles, because over time, as the crank went on farther and farther, you could run out of taper, and the square end of the spindle would become flush with the surface the crank fixing bolt/washer pushed against. At that point, further tightening of the bolt won't make the crank any tighter, since the bolt is bumping onto the end of the spindle.
Tolerances on older spindles may not be closely held, and dimensions may vary enough even with the same model number to affect crank/spindle compatibility.
The if end of a bolt-type (hollow, internally-threaded) spindle is too small, it may be ground down, as long as the spindle does not bottom out on the back of the crank and the spindle's internal threads are long enough to hold the bolt.
These days, however, most folks are using sealed cartridge bearing bottom brackets. With these, there is no routine maintenance required, so typically the crank will be installed once, and will stay in place unless/until the bottom bracket needs to be replaced. This greatly reduces problems of wear to the interface.
I generally avoid mixing sizes on customers' bikes, but I have a lot of experience mixing ISO/J.I.S. in both directions on my own personal bikes, and it has never given me a lick of trouble.
ISO/J.I.S. Interchangeability
If you install an ISO crank on a J.I.S. spindle, it will sit about 4.5 mm farther out than it would on an ISO spindle of the same length.ISO crank on J.I.S. spindle -- small square-taper hole in crankplaces it farther outboard on the spindle.
Likes For squirtdad:
Bianchi Goddess
Liked 2,923 Times
Thank you for the pics and while this is very tempting I think I’ll pass. I’m a bit concerned about about…..well let’s just say weight limitations, I suspect these are much better for more petite riders.
I hadn't even considered a weight limit. And I'm about as far away from a petite rider as you can get. Or maybe even more than two petite riders.
Good luck with your build!
Likes For RandolphCarter:
Bianchi Goddess
Liked 2,923 Times
Well I solved the bottom bracket issue for now. While I was breaking down the Red Proto I realized I could simply kick the can down the road a few months by using the BB for the mystery build and source another for that frame.
Then another issue arose. While I had the correct too to remove and install it, when it came time to twerk it I discovered I didn’t have a socket to fit the tool. How did that happen? It took most of mental strength to reach all the way back to 2009 and I recalled I did not install this BB the great gang at the now defunct Danzel and Quiggly in Cherry Hill NJ did it for me. So do I buy a socket? Or……. I loaded the mystery bike into Morticia’s bier and off to my LBS. After a rocky start on my first time there in a while the guys and I getting along very well. They were nice enough to torque it fir me whilst I waited and chatted about the bike and build. the best part is they didn’t charge me!
Oddly they had to use my BBT 6 as it fit better than theirs. So now we’re one step to being done unless some other obstacle rears its ugly head.
Likes For Bianchigirll:
Bianchi Goddess
Liked 2,923 Times
So as my grandmother used to say….”Roseanne Roseannadanna, it’s always something”
For some stoopid reason I put a fancy pants Sugino self extractor on this crankset. Unfortunately the unique tool is currently MIA. funny thing is I swear I saw it the other day and was going to post a pic and see who knew what it was.
Let’s see…. Sugino chainwheel bolt too, a few Dura Ace tools, some modified for other uses, Diadora cleat tools, tap handle but no tool that need.
On a positive note I managed to get the brake cables installed on the secret project as well as derailleur cables run. I do need to look for FW tomorrow though. Pics tomorrow
Top Seeded Amateur
Bianchi Goddess
Liked 2,923 Times
I actually have some of the darndest stuff you ever laid eyes on.
That’s a stray Ritchey dropout.
Bianchi Goddess
Liked 2,923 Times
So despite yet another setback with the cranks, the crew at Trash Panda Works made a little progress.
I’m not sure I’m going to get these cables again, this one piece with a fancy end on both ends is for the birds.
I think Esmeralda is coming along quite nicely. too bad one of the fabulous old gold Mavic Record Du Monde rims I have is cracked
I think this is the first time I’ve put yellow tape on a bike of my own. I may have to try and shine up a brass bell rather than the copper one but they tarnish pretty quick.
Beautiful brakes with a little bling for them.
This Campanutella RD is back but I’m still not sure it’s staying. The GPX I just got from the bay is messed up so I’m back to square one
This saddle isn’t staying
Edumacator
Quoted: 2436 Post(s)
Liked 3,119 Times
What’s wrong with the centaur RD?
Bianchi Goddess
Liked 2,923 Times
Aside from being NOS nothing, but I’m just hesitant to use it. The more I look at it I think I need a silver one
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1225 Post(s)
Liked 3,542 Times
Looks good.
Likes For AdventureManCO:
Edumacator
Liked 3,119 Times
Friction or click?
Bianchi Goddess
Liked 2,923 Times
Edumacator
Liked 3,119 Times
Crap...forgot that. Let me know if you need me to scour the collecione da partas for a silvery RD.
Likes For jdawginsc:
Bianchi Goddess
Liked 2,923 Times
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 391 Post(s)
Liked 812 Times
I have a full gruppo of that dark Centaur I got for less than a handful of peanuts a while ago and next week will be their time (if my recently lost by parcel service and yesterday found again wheelset arrives). But every now and then when I bump into them in the parts box, sometimes I marvel at their color, other times I say, hmmm maybe these will be short lived on the long planned target, so we'll see. Mine are far from NOS, but still good.
Likes For Lattz:
Bianchi Goddess
Liked 2,923 Times
Still no joy on the Sugino tool, I just don’t understand where it could be…..
I have discovered, again, I have too much stuff and some of the weirdest stuff too. I think I found enough random silver dollars, half dollars, Loonies, Toonies, and other assorted coinage to buy another set wif the tool
Not sure how I came to poses three Campanutella crown races but sadly I’m not sure they are worth using. I must have a half dozen of the washers, this weird double ferrule and gross of brake ‘star’ washers.
The races don’t look so good
So Esmeralda will have to earn her keep as a cup holder for the holidays.
Bianchi Goddess
Liked 2,923 Times
Despite the holidays we here at Trash Panda Works are pretending to be hard at work.
I’m still annoyed at myself for not being able to locate this tool however someone gave me an idea, which I had thought of in slightly different manner but dismissed it. His version worked.
This looks much better and matches the cables and other accents
The office Christmas party was a blast but the folks over at supplies and spares were told to grab a plate and get back to work looking for that tool
Now to finally decide on an RD. OH and it seems I’ve divested myself of all but two freewheels, one 5spd and one 7 on a spare set of wheels, need to get that switched
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 668 Post(s)
Liked 967 Times
753 reynolds frame and green color , can't go wrong with that
Likes For georges1:
