Why identical frames weigh more sometimes
Bikes: HVZ Meteor 1979, HVZ Champion 1962, HVZ SS Moskva80 1981, Dürkopp 1936
Quoted: 39 Post(s)
Liked 345 Times
Was modding a frame and found a suprise inside. Figured some here might get a laugh out of this.
blahblahblah chrome moly
Quoted: 1163 Post(s)
Liked 2,542 Times
At a shop where I worked once, there was a sales guy who got a new tri-bike and someone there thought it would be funny to fill the frame with steel shot, from a shot-blasting cabinet. I don't remember what the victim did to deserve that but I gather it was well-deserved. It took him a long time to notice, like after a few races. I also heard of a solid steel mandrel being dropped into another guy's seat tube, full length from the BB shell up to the bottom of the seatpost. Even heavier than steel shot, which has air spaces in it.
Could this be another prank, or was it an attempt to stiffen the frame, or repair a crack? The mind boggles.
Mark B
Team Beer
Bikes: Too Many
Quoted: 113 Post(s)
Liked 157 Times
Strategic ballast makes you go faster
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Quoted: 39 Post(s)
Liked 345 Times
OMG, can you tell what that material is? Lead solder maybe? That's effin' hilarious.
Mark B
Mark B
Likes For geeteeiii:
Quoted: 4172 Post(s)
Liked 3,792 Times
I suspect this frame was hearth brazed with a coil fed filler. Inattention, lack of skill, just because one can and a whole lot more filler was fed into the chainstay/shell joints. It would be interesting to see if the shell had a brass coating on most of it's interior surfaces too.
Or someone loaded the chainstays with a few too many preform filler rings. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Bikes: many
Quoted: 1434 Post(s)
Liked 1,363 Times
As someone who has now built the large bits of exactly one frame I can attest to lack of skill being at least one cause for much excess braze metal winding up in places where it does nothing but add weight.
Quoted: 2429 Post(s)
Liked 2,888 Times
Are you all talking about the shiny soldering material or the rust-colored plates that (especially in the left chainstay) look like tilted discs?
my nice bike is at home
Carbon-fiber frames are often ( slightly ) heavier or lighter than expected due to resin flow or drip-out,at least that was the case, anyway, 10 years ago.
For instance, BMC frame builders would badge/decal the lighter frames Roadmachine and the heavier ones Racemachine although the frames are outwardly identical.
BMC Race Machine / BMC Team Machine / Rossin Record / 80's Pinarello Traviso / Merlin MTB / Raleigh "Folding 20" / Ti-Swift (!)
Erikson w/C&C couplers / Trek's: 2300, 1200, 990 / Jamis 'Sputnik'
Liked 2,542 Times
Also on the subject of unintentionally funny decals, there's this one named after the 5 points where it'll break if it actually gets ridden:
And this one, also named after the point where it will break:
Likes For bulgie:
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 626 Post(s)
Liked 899 Times
I love this pic of a BMC Team Machine that tore in half, in the perfect place to where the decal now says "Tear" Machine. I wonder if tears were shed, over that tear?
Liked 2,542 Times
It seems obvious to me, the BMC broke its toptube only after the DT pulled out of the HT lug. No defect needed in the CF; nearly any TT of any material would break if the DT is not longer connected. So the defect is clearly in the glue joint between the CF DT and the lug, which appears to be aluminum. Al and CF have different electric potential, so in the presence of an electrolytre you will get galvanic corrosion. Also different thermal expansion coefficients, so heating/cooling cycles might tend to break the joints apart if not done right. Just guessing at reasons the glue joint came apart, but I don't think there's any question that the glue joint is 100% to blame here. I mean, the CF in the TT could also have a defect, but that's moot once the DT pulls out.
Quoted: 3449 Post(s)
Liked 2,800 Times
That is just wild.
hearth brazing or not, considering the "waterline" of the bronze, I would have expected the bottom bracket shell to be filled solid too. The shell does not appear to me to have a closed off wall at the chainstay spigots.
