Best frame for heavy rider
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
I'm amazed I missed that old article, thanks for the link.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
PeopleCode delaminator
My weight has fluctuated between 240 and 270 for far longer than I'd like.
As others have pointed out, wheels will most likely fail before a decent frame. Eight years ago I built up my current road ride. I went with a set of wheels built with Mavic Open Pro 32 spoke 700C rims, DT Swiss spokes and Shimano 105 (5800) hubs - from Velomine. They've held up to everything I've put them through.
Likes For RandolphCarter:
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 553 Post(s)
Liked 747 Times
That's the difference between a race bike with a very short wheelbase (which was fashionable for a few years starting in the mid-to-late '80s)---the R800---and the more modern Emonda ALR, which represents the reversion to designing bikes to be easier to handle and more comfortable.
11mm is the difference. 54cm R800, 58cm Emonda. I can't see 11mm making such a big difference in ride quality. Tire width differed by 3mm and 5psi... night and day difference in ride quality between the frames.
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,860 Times
59 cm frame for a 6' guy:
Note there's less exposed seatpost and a 110mm stem.
Plus, aren't you the guy who asks whether you REALLY have to heed the "Max Height" markings?
climber has-been
Quoted: 3415 Post(s)
Liked 3,543 Times
Frame size (cm) = rider height (inches) - 14
So a "normal" 6' rider would mostly likely fit best on a 58 cm frame.
Ride, Rest, Repeat. ROUVY: terrymorse
Quoted: 7649 Post(s)
Liked 3,465 Times
Frame size depends on way more than rider height.
Habitual User
Quoted: 4929 Post(s)
Liked 8,062 Times
Your formula gets me 55. My frame size preferences have tended to be 53-54. That said, I could probably make a 55 work. For making a quick guess for people with little to zero experience, your formula is useful.
Likes For Eric F:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,463 Times
This is not a precise definition, but "entry level" generally refers to using carbon fibers having a lower modulus (i.e., less stiffness), so more material must be used to build the frame, thus making the frame heavier compared to building the same frame with carbon fibers having a higher modulus, e.g., Cannondale's Hi-Mod frames.
Quoted: 18353 Post(s)
Liked 4,502 Times
As mentioned above, you're probably find on a road bike. Many people will find 28mm, or even larger tires would be comfortable, so don't look for one with super tight clearance.
However, also consider the cyclocross, gravel, and light touring bikes. They would be made slightly tougher than the average road bike, and would be able to take larger tires.
Since I posted this question originally, I switched from the 56" specialized frame to a 58" serotta frame. I would say that the difference is notable, not only because I'm now riding on a better frame, but because of the improved efficiency.
Quoted: 4387 Post(s)
Liked 4,828 Times
Quoted: 553 Post(s)
Liked 747 Times
That formula currently works for me. Just under 6’ on a 58 frame.
But bikes vary. My old road bike was a 54 and actually had a longer seat tube.
Liked 4,502 Times
I've estimated that around 6' is 60cm, and subtract (or add) about 1cm per inch either way. Then considered a bit of a range of sizes.
Your formula would be 6' for 58cm, then add or subtract about 1cm per inch which is probably a slightly better estimate.
Quoted: 8264 Post(s)
Liked 9,000 Times
I've had 62, 63, 64, and 65 frames. My Seven fits me even though it measures 65 (virtual seat tube) because it has a shorter top tube and tall head tube.
My CAAD 5 size 63 was a bit stretched out. My 64cm Tesch fit great.
Now we have frames sold as small, medium, large, etc.
Liked 11,860 Times
Yep. All the bikes that fit me are in the 57-59cm range. Variations in TT length and HT and ST angles lead to variations in stem length and seatpost height to put things at the same place relative to the BB.
Liked 4,828 Times
Same here at just over 6' tall. I find that most 58 cm bikes will fit me out of the box. I could also fit on most 56 cm bikes with a bit of reach/stack tweaking.
There are many 80's and 90's Cannondales that are uber strong and stiff. People are still racing on older framesets. By the way, Trek rates the max rider weight of their carbon bikes at 250 lbs (113 kg), whereas their aluminium bikes have a max rider weight of 300 lbs (136 kg). Carbon's weight to strength ratio is higher than aluminum, but manufacturers offset that by using less to make it lighter. So, it's really not stronger overall in it's application, plus it's weakness is still impact. I have owned (and still own) carbon frames and they were and still are great. So is aluminium.
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 666 Post(s)
Liked 964 Times
Sunshine
Quoted: 10947 Post(s)
Liked 7,474 Times
Habitual User
Liked 8,062 Times
Sunshine
Liked 7,474 Times
The same poster did a similar thing in a different thread- added pics of someone(himself? not sure) and they are apparently before vs after pics for weight loss. The before pic is shirtless and the after pic is fully dressed in a loose button down shirt. No context given, just a couple of pics even though nobody asked. The after pic didnt even show a difference due to clothing.
So odd.
Anyways, what I did notice with the bike pics is that second one, the Specialized Aethos, has what looks to be a level saddle and level bar-hood transition, but if you drop the rear wheel the 1" or more its in the air, that saddle will be pointing upward ready to do its best impression of a proctologist.
...at least thats what it seems like to me based on the angle of the picture.
So odd.
Likes For mstateglfr:
Bikes: I have a few
Quoted: 340 Post(s)
Liked 209 Times
I was around 220lb and I rode various vintage steel bikes regularly. I bought a carbon SuperSix and put 20,000 miles on it before I sold it to someone else. Frame was great but I did go through a couple sets of wheels. My weight did drop to around 190 but now after covid I ballooned up to 250lb before I tried biking again. I am back on my vintage stuff mostly a 2000 Pinarello
(steel/carbon frame) and a 2022 Trek 920.touring bike. I just built up a Master x Light for some motivation trying to get back down to at least 200lbs. I am 6' tall and have bike that range from 56 to 60 cm. My most comfortable ones are the 58cm (Colnago Master, Bob Jackson, Trek 920) and the least comfortable bike was the 56cm SuperSix I sold.
