curve handlebar stem qr problem
Bikes: Joey Sport; Mezzo D9;Curve D3; Surly LHT self build cargoesque
Quoted: 15 Post(s)
hi all, it is a long time - a very very long time - since I have taken my Curve out, and I can't work out what I am doing wrong with my handlebar stem extender QR. It is either too tight to lock, or too loose and the stem slides up and down. Any ideas what I am doing wrong ?
Pics if it helps, all advice gratefully received
Quoted: 15 Post(s)
Apologies I have double posted and don't know how to delete one of the duplicate thread.s.
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 452 Post(s)
Liked 405 Times
Can we see a photo with the QR closed in its ready-to-ride position?
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
Quoted: 452 Post(s)
Liked 405 Times
Well, the fastener is bent, so that may be part of the problem.
Paul Pinigis
Paul Pinigis
Bikes: 1999 Bike friday NWT, 2009 Bike Friday Tikit, 2023 silverock Dewy, 2008 Dahon Smooth Hound, 2023 Litepro Trifold
Quoted: 191 Post(s)
Liked 230 Times
Your local bike shop could sell replacement QR. If you don’t need to have the steerer tube collapse, you could replace the fastener with a screw. You would then need a tool adjust the hight.
Question, Was there a sleeve insert in the tube before? Some have this in the seat tube to prevent the post sliding.
Quoted: 452 Post(s)
Liked 405 Times
That's a standard part that should be available at any bike shop
Paul Pinigis
Paul Pinigis
Quoted: 15 Post(s)
Your local bike shop could sell replacement QR. If you don’t need to have the steerer tube collapse, you replace the fastener with a screw. You would need a tool adjust the hight.
Schwinnasaur
That one is a poor design. It seems to me that it is bent to begin with as part of the design. The force through the threaded section is not in line with the cylindrical part it threads into. Measure the diameter and do a search on eBay. . There should be many available. Try to find one with a stainless steel threaded shaft. Better ones are aluminum with stainless shafts and long closing handle for easier use. Also check the hole at the end of the slot on the stem riser for cracks.
Quoted: 3459 Post(s)
Liked 1,465 Times
Quoted: 463 Post(s)
Liked 567 Times
The clamp is a standard, commonly available part. Make sure you order the correct diameter as these clamps when used on steel frames tend to be narrower than those used on the typically wider Al-alloy tubing.
Quoted: 15 Post(s)
Can I just thank everyone (belatedly) for this. Bike and me temporarily seperated so not had chance to effect repair, but now confident it can be done. Thank you so much guys.
