Giant Defy 2 2012 fork replacement - is it possible?
Quoted: 5 Post(s)
Hello, I've bought a used Giant Defy 2 (2012) - ML size.
I'm 5' 10.5'' so the ML size sounds just about right. Although I experimented with bunch of different saddle settings (for/aft, height), and stems from 80mm/8deg to 100mm/7deg I couldn't get rid of this weird feeling of being pushed too much forward when riding. I felt too much pressure on my hands.
I started with the original stem (100mm/7deg) and then moved to 80mm/8deg thinking that it will shorten my reach, thus releasing pressure from my hands. Turned out, that it was even worse (!), as by shortening my stem, my position went down as well. Counterintuitive, I know...
I installed my original stem back, and started googling for this bike, to see how people set it up. To my surprise, the internet pictures revealed, that the original model, should have at least 35mm spacers below the stem (not sure what the exact number is, because I measured it with Kinovea app taking as the reference, the cup that's just below the spacers). Seems like the previous owner decided to make it a racing bike by getting rid of the unnecessary steering tube part. I don't have any spacers - just a head tube, a cup, and a stem.
My first thought was like, ok let's just get some spare steerer, and weld the missing 35mm back...No no no - turned out it's alluminium. Started looking for used parts but, to my surprise it's not that easy to get a used Giant fork - especially from 2012. Went for a new one. Same thing, couldn't find any. Contacted my local Giant Dealer, and now waiting for their resposne. In the meantime I started looking if there are any replacement options. Not that much info either. I'm not even sure, how to decide if a non Giant, tapered fork (in Giant terms - overdrive) will fit my frame. Is it normalised in some way? Are there any good online stores with this kind of parts? Whenever I go, I see just a couple of forks for about 200-300 USD, which is what I paid for the whole bike! (and I'm not even sure if they would fit the frame).
One thing that I could do, would be to get 90mm +17deg stem, to bridge the saddle - handlebar drop difference. This is some kind of a remedy, but when looking from the handlebar height perspective, all that would give me is just a starting position of this bike with 100mm/-7deg stem and stock steering tube length.
What are my options here when it comes to replacing the fork? Anyone aware what the price of the original one might be? Any replacement options?
Thanks!
Thanks!
Quoted: 6100 Post(s)
Liked 4,732 Times
ML sounds too big to me. I guess you are stuck with it now?
Quoted: 1067 Post(s)
Liked 259 Times
I am your height and ride a ML Defy.
It depends on your bike fit and body proportions.
Have you previously ridden a drop bar bike that you were comfortable on?
If so transfer the "fit" to the Defy (saddle set back/height/reach/ drop).
Then see what sort of stem you need and if that is reasonable.
Quoted: 608 Post(s)
Liked 352 Times
The size of the bike sounds fine for your height, the problem is the slammed stem. If the saddle to bar drop is too much as you articulated then getting a 17 degree stem is the right thing to do. The second thing I would buy are Specialized Hoover bars. The have a rise in the bar that will help get your hands higher by 15 mm. The combination of the stem and the bars may be close enough.
Quoted: 5 Post(s)
I think M might be a bit better, but with ML I don't feel like I can't reach the bar. Seems like the distance is just about right, but the problem is they are too low. I haven't ridden much on a road bike before, so I'd probably need to get more flexible until it gets comfortable...
Nope, this is my first road bike.
Thanks for pointing out these bars, wasn't even aware such exist! 17 deg stem is on the way. If it's not enough, I think it'll be worth trying them out (unless giant dealer pops up with a decent price for a new fork )
Thanks for the answers!
I tried slamming my Felt AR5….and hated it. Sure…it looked “cool”, but the riding position sucked for me.
Quoted: 5 Post(s)
Im new to cycling…..but maybe give it some time before making a bunch of changes. When I bought my 2020 Defy…..I thought it was way too big/stretched out on the first couple of rides. Now I’m used to it….and am incredibly comfy and happy with the bike.
How long did it take you to get used to yours?
Yes, thanks for pointing that out. Not sure however, how much is enough to get used to a road bike. I've made around 1600 km on mine. Maybe it's enough, maybe it's ridiculously small - I don't know. I haven't found any exact figures for that. The reality is, when I go for more than 1 hour trip, I'm still getting some hand numbness, and sometimes pain, which leads me to believe that it's not adjusted properly. I'm even more convinced after seeing pictures of the original model, with a couple of spacers below the stem - that looks a lot more comfy than what I have now.
I’ve also now realized that the bike is a touch too small for me. 54cm frame and I’m 6ft tall.
The Defy is much roomier and stretched out. From what I’ve read….having the seat too far forward can shift weight onto the hands. Some vids online showing how you should be able to take hands of the bars and continue pedaling without falling forward(on a trainer)…..if your setback is correct. Don’t know how true that is….but it worked for me.
Liked 4,732 Times
I was partly just saying that about the ML size just to shock you. Your "sounds just about right" Sort of made me want to be snarky.
Though the medium might have been a little better fit. But with out seeing you on both bikes I'd not really know.
Likely the previous owner had the steerer tube cut after removing the spacers that it came with. I just put mine on top the stem so I can change my mind if I ever want to at a later date. Looks dorky I know, but hey, I won't have to spend big bucks to solve that issue.
You might look at riser handle bars and a more angled stem. Riser handlebars alone can get you a couple cm or so higher. And bars and stem will likely be way less than a new fork.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
You might want to experiment with tipping the saddle back a very small amount, in between test rides. A forward tipping saddle puts more weight on your hands.
Quoted: 5 Post(s)
Before I bought it, I had checked giant sizing charts, and for my height M and ML were fine. I was kind of on a lower end for ML, and about in the middle of the recommended height for M. Hard to say if this choice was right or wrong - nothing actually was against it Now maybe my thinking would be to first check a similar frame and a smaller one in a local LBS. Maybe that would give me some reference point.
The thing you mentioned about putting the spacers below the stem, just in case you changed your mind, is something obvious I would do as well. It's not only more flexible in terms of the bike set up, but you also need to put so much more thought into measuring it right, making sure the cut is stright, and being 100% sure you won't want to change it back. Anyway, it's been done and cannot be undone sadly....
Just a question - what exactly do you mean by "riser handlebars"? Is it something like the mentioned Specialized Hoovers?
Thanks!
Quoted: 5 Post(s)
As of now it's leveled. Wouldn't tipping the saddle back put too much pressure on the perineum? Sometimes I ride on drops and I'm afraid it would introduce another numbness But I'll give it a try of course
Liked 4,732 Times
Good luck finding stuff in stock. I need a shorter stem and the one I want has been out of stock for a while.
