QR skewer for BOB trailer?
It seems that BOB has stopped making trailers, and I can't find any sources for a skewer. Does anyone know where I could get one? I want a longer one for a bike with 135mm dropouts.
Quoted: 2494 Post(s)
Liked 738 Times
I might have one actually, but the only part that is special is the ends. The threaded axle is common to all quick releases. Get the threaded rod part from the hub that is already on the new bike and swap.
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
https://www.bobgear.com/accessories Scroll down a bit and they have trailers and accessories for trailers. Now they probably don't have any stock but that is mostly pandemic related.
Thanks for the tip. However, before I read your post I managed to find a skewer at a local bike shop. Too bad they stopped making the BOB; I thought it was a fine product.
Clark W. Griswold
Liked 3,993 Times
Though probably strollers for units were selling better for them especially now that people are inside together and have nothing better to do than to make more units. I prefer doing it for pleasure not for unit production but you know we are so dangerously underpopulated.
Quoted: 18375 Post(s)
Liked 4,510 Times
REI lists it as "No Longer Available".
https://www.rei.com/product/885816/b...s-bike-trailer
Campfire Cycling lists:
https://www.campfirecycling.com/prod...s/bob-trailers
The BOB Trailer is no longer being manufactured by its parent company Britax. The parts should continue to be available into 2022 and we’ll be supplying them as long as we can. Get your spares while you can!
We carry all the parts and accessories, plus bags and cases designed to get the most out a BOB trailer.
https://www.amazon.com/dp/B000RH5DJY...hebestebike-20
https://arcus-www.amazon.com/BOB-Yak.../dp/B000RH7GKS
Back on the Bob website, the trailers definitely are buried down at the the bottom with strollers apparently being the primary focus at this time.
Burley has something very similar now: https://www.burley.com/product/coho-xc/
Clark W. Griswold
Liked 3,993 Times
Hmm.. this is odd. Yes, the https://www.bobgear.com/ site seems to list the trailers as if nothing has changed.
Amazon lists the trailers as "Currently Unavailable".
Quoted: 254 Post(s)
Liked 182 Times
Bikes: Past:Witcomb USA 1976 tourer; Specialized Allez Cro -Mo, Lemond Zurich, Nishiki International, MKM. Current: Salsa Vaya, Dahon P-8.
Will anything else work? A long regular skewer couldn't work, could it, because the qr lever would have to clamp against the Bob instead of the bike dropout, and that doesn't sound right. Any help appreciated!
